Anyone found black door handles for the 2021?
Discussion in '2.5 Gen Tundras (2014-2021)' started by Bentarm13, Jul 10, 2021.
  1. Jul 10, 2021 at 8:46 AM
    Bentarm13
    Bentarm13 [OP] New Member
    Anyone found matte black door handle overlays for the 2021? Are they worth it or should I just replace the entire assembly?
  2. Jul 10, 2021 at 8:49 AM
    frichco228
    frichco228 Valued Member
    2016 Crewmax 4WD, TRD Offroad
    Just get the actual handles you want, black, chrome or color match, not an overlay. You can often find used take offs locally, check marketplace here or buy new- sparksparts
    The swap is super easy, can do all 4 in less than half hour.
  3. Jul 10, 2021 at 8:52 AM
    Bentarm13
    Thanks dude!
  4. Jul 10, 2021 at 9:49 AM
    RainMan_PNW
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
    Takes a little longer on a ‘21 because the front doors have the sensors - you have to pull the door panel and get inside the plastic to the wiring connectors.
    the front handles are also a bit more $$$ for that reason too
  5. Jul 10, 2021 at 12:38 PM
    AggiePhil
    AggiePhil Texas Chapter President
    College Station, TX
    2020 Smoked Mesquite Platinum 4x4
    Pretty rare to find takeoffs in black or body match. All the ones I’ve seen have been people getting rid of the chrome.
    I just ordered new ones from Sparks.
  6. Aug 30, 2021 at 5:54 PM
    Bentarm13
    Can anyone point me towards the handles with the smart key? I’m not having any luck searching the inter-web.
  7. Aug 30, 2021 at 7:30 PM
    normagene
    normagene New Member
    Normagene
    New England
    2021 Cement DC Limited Texas Edition
    Texas Edition
    Expensive
  8. Aug 30, 2021 at 7:49 PM
    Bentarm13
    Holy sh<÷t?? Really?
  9. Aug 30, 2021 at 8:03 PM
    French Avocado
    French Avocado Double Entundra
    Utah / Wyo
    Yep but Use tundras.com as the discount code to save 5%.
    However if you want matte black handles then you should try searching for 2021 TRD Pro handles from a dealer like Lewis Toyota of Topeka Kansas and see if it is a little less expensive.
  10. Aug 30, 2021 at 8:04 PM
    normagene
    Normagene
    New England
    Texas Edition
    YouTube has a vid of a guy swapping it out. Not a quick swap like those without smart. Inside door panel has to come off and you need to slice one the protective film barrier, unplug, remove, insert new handle, reconnect then reseal the film/plastic barrier and put the door panel back on and your good to go!
    It’s definitely doable but takes some time, probably an hour+. If the passenger side doesn’t have smart then it will take you 15-20 minutes for the other 3 doors.
    https://youtu.be/YgLtWDVpLm8
  11. Aug 30, 2021 at 8:37 PM
    French Avocado
    Utah / Wyo
    I think these are the correct ones for a Crewmax, with prices and links to Lewis Toyota (please verify before you spend $457.83):
    Front door handle assembly for push button start 69210-0C070 - 2 needed - $146.20 each
    https://parts.lewistoyota.com/p/Toy...-57L/HANDLE-ASSEMBLY/78905294/692100C070.html
    Left Front Cover (small piece) 69217-0C090 $12.62
    https://parts.lewistoyota.com/p/Toy...UTSIDE-HANDLE---LEFT/78905250/692170C090.html
    Right Front Cover, Right Rear Cover, Left Rear Cover (small piece without key hole) - 3 needed - $12.45
    Right Rear Door Outside Handle 69203-0C010 - $57.73
    https://parts.lewistoyota.com/p/Toy...TSIDE-HANDLE---RIGHT/63489974/692030C010.html
    Left Rear Door Outside Handle 69204-0C010 - $57.73
    https://parts.lewistoyota.com/p/Toy...UTSIDE-HANDLE---LEFT/63291353/692040C010.html
    Note FREESHIP code for free shipping for a total cost of $457.83
  12. Aug 30, 2021 at 8:40 PM
    French Avocado
    Utah / Wyo
  13. Aug 30, 2021 at 8:44 PM
    French Avocado
    Utah / Wyo
    This video is by our trusted vendor and friend Colton at Hotshot Off Road - also known as @memario1214 .
    normagene[QUOTED] likes this.
  14. Aug 30, 2021 at 9:16 PM
    memario1214
    Colton
    Missoula, MT
    '21 Limited MGM CrewMax
    :wave:
    Hey, that's me!
    normagene likes this.
  15. Aug 31, 2021 at 5:00 PM
    normagene
    Normagene
    New England
    Texas Edition
    Great job on the video. Lots of good info and tips. Want to color match my handles but don’t want to do this mod. Pretty intense for a novice
  16. Aug 31, 2021 at 5:07 PM
    memario1214
    Colton
    Missoula, MT
    It's actually not too bad! I certainly understand the hesitation though which is why I put it together in the first place. Get the right tools and another set of hands and you can do it!
  17. Aug 31, 2021 at 5:11 PM
    French Avocado
    Utah / Wyo
    Have confidence - you can do it Marilyn Monroe!
  18. Aug 31, 2021 at 5:22 PM
    normagene
    Normagene
    New England
    Texas Edition
    Hmm…something to think about for sure. I don’t know if the smart handle is only on the drivers like on my Tacoma or both sides. Hope it’s only the drivers side.
    Not sure if a paint shop could color match while in place, probably not, so the passenger side if not smart, I know is a breeze to remove. I’ll ask if he can paint it after I remove them then reinstall the original handles. Can’t imagine I’d have to get replacements.
    So many questions…lots of stuff on the “to do” list.
  19. Aug 31, 2021 at 5:37 PM
    memario1214
    Colton
    Missoula, MT
    I guess I don't KNOW, but I would anticipate that if a truck has smart key on the driver's side, they have it on the passenger's as well. I only see them sold with 2 smart key handles. I guess you could pull off the end piece and attempt to slide out the big part of the handle. You'll know right away if there's a cable attached.
  20. Aug 31, 2021 at 5:41 PM
    normagene
    Normagene
    New England
    Texas Edition
    I’m going by my Tacoma. It only has it on the drivers side. I have to use the clicker if I’m on the passenger side.
    I don’t have the truck yet, it’s in “transit” and should land 9-17th-22nd. So I won’t know until I take custody.
  21. Aug 31, 2021 at 5:41 PM
    Or just go grab the passenger handle and see if it unlocks?
    French Avocado and normagene like this.
  22. Aug 31, 2021 at 5:43 PM
    memario1214
    Colton
    Missoula, MT
    GOOD. GOD. I am such an idiot... Sometimes you go down such a rabbit hole line of thinking you completely disregard the obvious.
  23. Aug 31, 2021 at 5:46 PM
    :rofl::rofl::rofl:
    Forest for the trees... We all do it, and I do it more than most.
  24. Feb 10, 2025 at 1:33 PM
    ADKcampAdventures
    ADKcampAdventures New Member
    2021 Tundra Platinum
    Eibach stage 2R Wireless charger Dashcam Overland rack with RTT and 270 awning RCI skid plates
    I know this is an old thread but I'm looking for the attitude black door handles and the only part that I can't find is the key hole cover on the drivers door. Does anyone have the part number for this?
  25. Feb 10, 2025 at 4:29 PM
    BrandonL812
    BrandonL812 New Member
    Brandon
    This may help. Last item on list. $20 one.
  26. Feb 11, 2025 at 6:23 AM
    ADKcampAdventures
    Perfect, thank you!
    BrandonL812[QUOTED] likes this.
