Anyone have luck resetting TPMS after tire rotation?
Discussion in 'Wheels & Tires' started by Tundra234, Aug 21, 2022.
  1. Aug 21, 2022 at 9:55 AM
    Tundra234 [OP] New Member
    Rotated the tires on my 2020 and cannot get the pressures to come back up. Anyone have any luck getting them to reset? The manual is worthless and the TPMS tool isn't cooperating either. Yes, they are OEM sensors and worked until I did the rotation. The drive cycle does not work no matter how many times I try it.
  2. Aug 21, 2022 at 10:16 AM
    Totmacher
    Totmacher New Member
    Daniel
    West TN
    mesquite Tundra or blue 4Runner
    Some
    Curious what you find out.
    since I got new tires and new oem sensors, it takes a few minutes driving before dash will display pressures. Old ones use to show up pretty quick at startup.
  3. Aug 21, 2022 at 10:38 AM
    Stumpjumper
    Stumpjumper Not a new member
    Fate, Tx
    2017 Tundra TSS 4x4
    Glad I have a 2017 so I don't have these problems.
  4. Aug 21, 2022 at 10:44 AM
    JaxJacket
    JaxJacket New Member
    21 DC
    Got mine to register ok. Started the truck and waited for the tpms light to stop flashing, did the 3x button press, went for a drive and they registered. A little curveball, I added a 5th for a spare and first time it got the tire positions confused. Went back and rotated the spare under the bed so the valve was all the way to the back, repeated the process and now it is right.
  5. Aug 21, 2022 at 10:56 AM
    The driving doesn't work at all on mine.
  6. Aug 22, 2022 at 7:03 AM
    Totmacher
    Daniel
    West TN
    Some
    Maybe drop by a local tire shop to ask about it since nothing you've tried is working?
    Ive had local shop register sensors with their handheld tool in the past at no charge.
  7. Aug 22, 2022 at 7:41 AM
    I have a TPMS tool and it's of no help at all.
  8. Aug 22, 2022 at 7:51 AM
    Mine was a nightmare when I put new sensors in. It took a while for them to register and initialize but I was good after that. I rotated the tires and the display went to dashes. I know that the truck sees them. If I deflate a tire, the low pressure warning and light will come on.
  9. Nov 13, 2022 at 1:41 PM
    Ok so the latest on this annoying BS. I rotated tires a couple of months ago from front to rear. The pressures went to dashes and never came back. Well today I disconnected the battery while I was doing a power panel in the bed. Once I hooked the battery back up, my tire pressures read on the display now. They are reading correctly for being on the front and rear, however, they are reading on the opposite side of the truck. The RF and RR tires are showing on the driver's side. :annoyed:
  10. Nov 13, 2022 at 3:14 PM
    shackleford rusty
    shackleford rusty New Member
    TEXAS!
    for my '19, i need to "initialize the tire pressure warning system" after rotating the tires. this process is detailed in the manual, page 496-497.
    this worked for me, as i tested it with different pressures in each tire. i needed to verify for my ocd.
    i would imagine this would be the same w/ ur '20. manual pages may differ some, however, all this is detailed under the do it yourself maintenance section, tire pressure warning system subsection.
    CaptainNemo likes this.
  11. Nov 13, 2022 at 3:21 PM
    Ragnarkov
    Ragnarkov New Member
    Stephen
    2021 Silver Sky Metalic Platinum Tundra
    Nothing.... yet.
    Are you talking dash or on your deck? My dash shows my correct pressures, but my deck has them rotated 90°.
  12. Nov 13, 2022 at 4:00 PM
    Dash and deck both have them backwards.
  13. Nov 13, 2022 at 4:13 PM
    That process didn't work after several tries.
  14. Nov 10, 2024 at 3:02 PM
    Mirg
    Mirg New Member
    2021 Tundra Limited TRD OR
    Anybody find a fix for this? Last week I had a screw in my rear driver side tire. I ran the spare for a day while getting the tire fixed and now that it's back on I can't for the life of me get TPMS to reset and display pressures.
  15. Nov 10, 2024 at 3:50 PM
    It's a pain in the ass on the 2020 and newer models. That's why I have two Autel TS508's.
  16. Nov 16, 2024 at 8:26 AM
    Mirg
    Mirg New Member
    100% a PITA! The other day after driving for 40 minutes I put the truck in park while at a red light and went through the recalibration process. It registered the tire pressure after a couple of minutes. On my way home from work I lost the pressure reading and couldn't get it back for a couple of days. I've got it back again, hopefully it doesn't drop. Super annoying considering all I did was take a wheel off for a flat repair.
  17. Nov 16, 2024 at 3:34 PM
    It's definitely a pain. When I do tire rotations, I don't touch the button any more. Having the TS508 is a lifesaver.
  18. Nov 16, 2024 at 7:36 PM
    Thumper_6119
    Thumper_6119 I've seen things you people wouldn't believe.
    2011 Toyota Tundra SR5 Texas Edition (Crewmax) 4x4
    What TPMS sensors do you use?
  19. Nov 16, 2024 at 7:56 PM
    OEM sensors.
  20. Nov 16, 2024 at 8:59 PM
    Thumper_6119
    Thank you! I'll get an Autel and some OEM sensors ordered. (Your methods and advice have always been spot on and have always worked for me). :thumbsup:
  21. Nov 16, 2024 at 11:23 PM
    I have two of the Autels. I need to sell one of them. :)
  22. Nov 18, 2024 at 4:44 AM
    pvn.beluga
    pvn.beluga New Member
    Phuc (Phooc)
    Connecticut
    What was the process like with the Autel?
    I think the 2020 was when the new TPMS were installed right?
    I have 5 sitting around and 1 tire on without a TPMS cause the tire guy snapped it right off…
  23. Nov 18, 2024 at 5:24 AM
    Easy. I would have made him fix it.
  24. Nov 18, 2024 at 12:57 PM
    BrandonL812
    BrandonL812 New Member
    Brandon
    2021 Tundra Platinum
    Can you explain how to use the Autel when you need it? Like where in the setting and what to look for to get the truck computer to register the sensors, even for oem sensors. Thanks
