Anyone have the Smittybilt M1 Slider Wheel To Wheel Step Bars?
Discussion in '2nd Gen Tundras (2007-2013)' started by jgraphix73, Dec 16, 2018.
  1. Dec 16, 2018 at 4:14 PM
    jgraphix73
    jgraphix73 [OP] New Member
    Richard
    2010 Tundra Crewmax
    Hi folks,
    I am thinking about getting these Slider Wheel step bars on my Tundra instead of the AMP research power steps. I understand they serve two different purposes, but I like the fact that the Smittybilt does both.
    Any feedback would be greatly appreciated!
  2. Dec 16, 2018 at 4:36 PM
    CMB
    CMB New Member
    Cecil County MD.
    2010 Tundra DC 4X4 SR5
    Not nearly enough room here!
    1012180846.jpg I don't know about Smitybuilt's 'Slider-Type' bars but I've never had a use for Cab Length bars or Boards on any of my trucks. The ones I have on my 2010 are by ICI. They're 4 inch Stainless, very stout and holding up fine after 8 years of use. Wheel to Wheel models like this just makes sense to me, when needing access to the truck bed from the sides. Our Tundra's bed-sides are higher than other brands.
    jgraphix73[OP] likes this.
  3. Dec 16, 2018 at 5:03 PM
    jgraphix73
    Richard
    2010 Tundra Crewmax
    These are the ones I am talking about...
    equin and Rica25 like this.
  4. Dec 16, 2018 at 7:08 PM
    11SilverPlatinum
    11SilverPlatinum New Member
    Dave
    2011 Platinum Tundra
    Plastidip emblems, Pace Edward bed cover w/lumber rack, remote start, TRD intake and exhaust, TRD front and rear sway bars, color match grill surround, LED headlight upgrade.
    I like them. They look like they would make it easy to access the bed in the front.
  5. Dec 16, 2018 at 8:11 PM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    These are just steps that look like sliders. They can’t hold the weight of the truck. If you’re looking for protection for off-roading, don’t get these.
  6. Dec 16, 2018 at 8:18 PM
    InfernoPRO
    InfernoPRO Technicolor BASTRD
    Scott
    Sacramento
    2015 Inferno TRD PRO
    I had them on my truck. They were good as steps. They will protect your truck against rocks, but only once. Got bent after the first time using them. Like Joon said, the steel can't support the weight of our trucks.
  7. Dec 17, 2018 at 9:27 AM
    jgraphix73
    Richard
    2010 Tundra Crewmax
    Thanks for the input!
    Any recommendations for a decent slider/step? Or should I just get the AMP power steps?
    joonbug likes this.
  8. Dec 17, 2018 at 9:37 AM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    SDHQ, White Knuckle, P&P, All Pro. Pros and cons to each of them but they're all pretty good. Personally, I'd choose sliders over power steps... for the protection and just one less thing to break.
  9. Dec 17, 2018 at 9:39 AM
    InfernoPRO
    Scott
    Sacramento
    I now have the AllPro Apex sliders. They come with a full top plate, which was required by my wife. They function really well as a step/slider. There are more expensive options like White Knucle that have a good top plate slider.
    If you are local to NorCal, I know of a good deal on the AllPros.
  10. Dec 17, 2018 at 9:39 AM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
  11. Dec 17, 2018 at 11:33 AM
    jgraphix73
    Richard
    2010 Tundra Crewmax
    @InfernoPRO please share the info for the AllPros! Thank you
  12. Dec 17, 2018 at 11:35 AM
    jgraphix73
    Richard
    2010 Tundra Crewmax
    @joonbug Thank you! Much appreciated!
    joonbug likes this.
  13. Dec 17, 2018 at 12:53 PM
    InfernoPRO
    Scott
    Sacramento
    PM sent!
  14. Dec 17, 2018 at 1:43 PM
    BlueBottle
    BlueBottle not a PRO
    '16 Platinum 4x4
    See fine print
    Hey Scott. Are the all pros 100% bolt on? I know some have to drill from the bottom.
    joonbug and equin like this.
  15. Dec 17, 2018 at 2:59 PM
    InfernoPRO
    Scott
    Sacramento
    They are 100% bolt on, but you do have to drill 4 new holes on each side. The All pros have countersunk flat head screws, so they will run flush with the bottom of the sliders. Which is a huge advantage over White Knuckle with their exposed bolt heads on the bottom.
  16. Dec 17, 2018 at 3:21 PM
    sr5shark
    sr5shark Shop smart. Shop S-Mart.
    Alan
    Walnut Creek, CA
    2016 SR5
    Fox & ADS | SCS SR8 | Nitto RG
    The P&P sliders are also 100% bolt-on with no drilling required. The advantage to the All Pro sliders is that they wrap around the bottom of the frame - the P&P do not.
    BlueBottle[QUOTED] likes this.
