Anyone know what temp the transmission cooler thermostat opens?
Discussion in 'Towing & Hauling' started by Cody530, Jul 25, 2023.
  1. Jul 25, 2023 at 5:36 PM
    Cody530
    Cody530 [OP] New Member
    cody
    2019 tunda 5.7 sr5 4x4 dbl cab
    Bone stock baby going for that 1mill
    Just picked up my tundra a 2019. After a bit of google bit of youtube and scrolling this forum looks like I missed the mark on the cooler. I will be towing heavy (for the tundra) in 100+ temps up very steep grades and would like to know at what temp dose the thermostat open I've yet to find a answers. Anyone toss that sucker in a pot of water on the stove with a gauge? Thinking about just leaving that thing pinned open all summer since our heat is quite extreme.
  2. Jul 25, 2023 at 5:41 PM
    NWPirate
    Zach
    WA
    Sorry to break it to ya but 2018 was the last year for the transmission cooler!
    Many others have added the oem cooler setup, should be plenty of threads on that if you search it up on here.
  3. Jul 25, 2023 at 5:54 PM
    Cody530
    cody
    Sorry probably could have worded that better I know the cooler when out the window on the 2019. I will be adding one to my 2019 I'm just curios at what temp dose it open?
    NWPirate[QUOTED] likes this.
  4. Jul 25, 2023 at 5:58 PM
    NWPirate
    Zach
    WA
    Gotcha, no worries!
    I'm not positive on the temp but I'm sure someone around here knows
  5. Jul 25, 2023 at 6:02 PM
    Black Beauty 5.7
    Black Beauty 5.7 New Member
    Cannon
    2007 Black 5.7L Tundra SR5
    250,000 miles and always adding more :)
    I think its around the 175-185 degree mark. Towing 10k plus I've never had issues with overheating BUT it wasn't very long distances and it definitely wasn't 100+ degrees outside. Some say you don't need it but it's better to be safe than sorry especially if your overloading with long distances.
  6. Jul 25, 2023 at 6:15 PM
    2mchfun
    I have added one, and I don't exactly watch to see when it opens. However I can tell you it's far before you get to 230. Maybe around 195-210 would be my ballpark guess.
  7. Jul 25, 2023 at 10:31 PM
    Cody530
    cody
    I got a little worried seen a Youtube video in which the guy was says he heard 250, I was thinking about leaving it open all summer but if its opening up around 175-210ish I'll just pull that pin and let it do its thing.
  8. Jul 25, 2023 at 11:27 PM
    BillyB
    BillyB New Member
    Billy
    AZ
    2021 SR5 TRD Sport 4x4
    I've seen right around 240 off-roading
  9. Jul 26, 2023 at 4:23 AM
    MadMaxCanon
    MadMaxCanon New Member
    '21 CM SR5 4x4 6 seater
    Too many, but not enough....
    Pretty sure it's about 195ish
    2mchfun likes this.
  10. Jul 26, 2023 at 4:32 AM
    Doxiedad
    Doxiedad Distinguished Member
    James
    Charleston, SC
    2020 Tundra SR5 TRD Off Road Cavalry Blue
    After I had my cooler installed I noticed that it warms up till about 195 then plateaus. If it goes above it during hard use it will cool down below 195. So I think 195 is about the open point
    MadMaxCanon likes this.
  11. Jul 26, 2023 at 5:36 PM
    Cody530
    cody
  12. Jul 27, 2023 at 7:22 PM
    _none_
    _none_ Poser
    2020 DC SR5 4x4
    Starts opening around 180-185. Probably fully open around 195. Seems to be closed again around 177.
    with the cooler I installed, I haven’t seen over 190 yet. Usually get to 185 then drops back down to 180. Stopped it’ll rest around 177-180. No need to pin the thermostat if you put on a big enough cooler ;).
  13. Jul 29, 2023 at 1:28 PM
    Melikeymy beer
    Melikeymy beer No cooler for you!
    Muscogee Nation
    2019 Platypus Tundra
    I'm still looking for all the 2019+ transmission failure threads. Do they have a sticky thread for them yet in the 2.5 gen forum?
    Retired...finally and _none_ like this.
  14. Jul 29, 2023 at 2:11 PM
    Retroboy1989
    Northern Utah
    2012 SR5 TRD OR (prev) 2025 SR5 TRD Rally (now)
    2012 here. My transmission holds 200° in any ambient. I'm assuming that means the thermostat is around 200°
    2mchfun and Terndrerrr like this.
  15. Aug 19, 2023 at 11:47 AM
    Cody530
    cody
    Finally got around to adding a Hayden cooler with the cooler/hoses and the loss of fluid from adding that therm what do you think about a quart low now?
    2mchfun likes this.
  16. Aug 19, 2023 at 12:03 PM
    Terndrerrr
    Terndrerrr 925000 miles to go
    Music City
    6UR-FE
    I have the Hayden as well. I pinned my new thermostat open, added 1.5qt, leveled the transmission pan, and warmed the truck up to let the fluid cycle through the system.
    Once the pan temps reach fluid level check range (99-111ºF, if I remember correctly), open the transmission drain plug until the flow of fluid reduces to a trickle.
    2mchfun likes this.
  17. Aug 19, 2023 at 1:13 PM
    Cody530
    cody
    Ok thanks. I plan on changing the fluid as soon as it cools down. The fluid that’s in it is pretty stinky/dirty sitting at 50k. Where are you gets getting your Toyota atf fluid dealers only? Online?
  18. Aug 19, 2023 at 1:21 PM
    2mchfun
    A little more like 1.5 quarts after installation. Ordered my fluid from Amazon a little cheaper than my dealer price.
  19. Aug 19, 2023 at 2:46 PM
    Doxiedad
    James
    Charleston, SC
    Shouldn’t it be the overflow plug not the drain plug ?
    AZBoatHauler likes this.
  20. Sep 13, 2024 at 9:24 AM
    Pman
    Pman New Member
    Paul
    2019 Tundra sport
    Transmission coolee
    I know this is well past your original post date. I just installed on my 2019 tundra sport crew the factory stat, hard pipe but used a setrab 15 row series 9 cooler. Total cost with factory hoses. Just under 700 bucks.
    Well worth the investment. Stat works at 180 to 185 with running water temp is 200 on 75 degree day. Well below the trucks old normal of 220/225 at a 75 degree day without trailer. Have not had the opportunity to hook up trailer.
    _none_ likes this.
