Anyone running 128/125R Load Index E Rated Tires?
Discussion in '1st Gen Tundras (2000-2006)' started by Diablo169, Nov 27, 2023.
  1. Nov 27, 2023 at 2:47 PM
    Diablo169
    Diablo169 [OP] ROKRAPR
    Max
    Santa Cruz
    06 Double Cab 360k+
    2” Lift, Bilstein 5100’s and 885’s second notch, Rear 5100’s Icon 3 Leaf Pack and Firestone Air Bags w/Daystar Cradles. Spider Trax 1.25” Wheel Spacers, 4Runner Pro Wheels, Falken AT3W 285/75r17 (34x11).
    I currently have a little over 100k miles on my Toyo ATII’s (285/70R17) and they are Load Range E, but are 121/118S. (My opinion best tires on the market hands down)
    I’m trying to take advantage of some Cyber Monday sales, as well as move up in tire size.
    I found a killer deal on some Falkin AT/3W’s in a 285/75R17. I’ve been wanting to try these out for anwhile now. Out the door, 4 shipped for $1,128. But they are 128/125R load rated. That’s a higher rating than my dually that’s rated to tow 34,400lbs.
    I’m happy with the current ride of the Toyo’s, but I’m worried the step up in Load Index may give a brutal ride.
    Not bad for 100,989 miles :rofl:
  2. Nov 27, 2023 at 3:28 PM
    cran2
    cran2 New Member
    Folly Beach, SC
    07 Crewmax 4x4 and 03 Sequoia 4x4
    I’d think they would ride like bricks! I have e loads on my gen 2 and I can't wait to rid of them.
    Diablo169[OP] likes this.
  3. Nov 27, 2023 at 4:12 PM
    blenton
    blenton New Member
    It all depends on how much air you put in to them. When I ran LT275/70R18's, they had a higher load index rating than the LT275/65r18's but the rode a touch better. I even had the exact same tire in both sizes so it should be apples to apples. I attribute the better ride of the larger tire to the bigger case volume - meaning you had more air and sidewall to cushion the ride. I always inflated them to recommended tire pressure based off of load/inflation tables.
    I think going from Toyo's to Falkens, then changing a tire size is going to make more of a difference in the ride than the load index. They are both E rated, meaning they have the same ply rating/carcass construction (kind of, but not really since we no longer rate tires on the number of plies that they have). Going to a tire with more sidewall should improve the ride, IMO.
    Oh, and those Falkens are usually HEAVY...
  4. Nov 27, 2023 at 4:16 PM
    Orions Dad
    Orions Dad New Member
    2007 Tundra 4.7L
    I am on my 2nd set of ATII tires first set got me 100k miles the 2nd set presently has 80k miles and expect to get 100k when it’s time for new tires I rotate each oil change(5k miles). I agree what you said about them being the best tires available. Mine are 275/65/18 and are 123 E rated and I am good with the ride, 128/125 will be a stiff ride
    Tire Rack has Toyo ATIII your size 121 rated 4 tires $1405. If it was me $50 a tire isn’t enough of a savings to gamble on especially you know the Toyo will last 100k miles not sure about the Falken
    Diablo169[OP] and Elevatorguy like this.
  5. Nov 27, 2023 at 4:30 PM
    Elevatorguy
    Elevatorguy Yotas and JD Green!
    James
    05 DC, 4.7, 4wd, LSD.
    No way I’d consider that load rating on a tundra.
    Hbjeff and Diablo169[OP] like this.
  6. Nov 27, 2023 at 5:08 PM
    whodatschrome
    whodatschrome New Member
    North of North Plains, Oregon
    lots of dents
    WARNING: unsolicited information below-
    Keep in mind that the shear weight of the heavier tire will sap your engine's power...on top of the fact that you're also stepping up to a tire that about 1" taller than what you currently have, which is also going to sap power, mpg's and acceleration. I'm not against anyone who wants to install oversized tires, just make sure what you're getting yourself into. I suppose that since you also have a dually, then you don't really ever have a reason to tow or haul anything in your tundra, but if it were me i'd still install a lower R&P gears with a taller tire.
  7. Nov 27, 2023 at 10:40 PM
    Diablo169
    Max
    Santa Cruz
    06 Double Cab 360k+
    Thanks for the feedback everyone.
    I went ahead and ordered the 121/118 version of the Falkin AT/3W’s. They cost about $160 more than the heavier 128’s. I think it was the better option.
    My truck has 4.10’s so I think it will pull well. I only tow my 4 Seat RZR or my Pop-Up trailer with the Tundra, and with the current 285/70R17’s I could tow at 75mph everywhere.
    My Tundra is my work vehicle and I put about 30k each year on it of reimbursed mileage. Even if I loose a little in mileage, the smiles per gallon will make up for it :rofl::frusty:
    Even though the Toyo’s are the best tires I’ve ever owned, and I have owned a lot the big names, I always like trying something new.
    ColoradoTJ, dirtnsmores and shifty` like this.
  8. Nov 29, 2023 at 9:07 AM
    dirtnsmores
    dirtnsmores New Member
    Southern CA
    2006 DC 4WD TRD OFFROAD
    Bilstein 6112/5100s, JBA UCAs
    Let us know how they compare. Ive been happy with my 255/80/17 Toyo open country e rated. Might step down an inch to 255/75/17 next time around.
  9. Nov 29, 2023 at 11:10 AM
    Warreng
    Warreng New Member
    I had toyo at2, fine in the dry but were flat out dangerous in the winter. Never again.
  10. Nov 29, 2023 at 12:17 PM
    dirtnsmores
    Southern CA
    At3 haven't had that issue. But I definitely have that issue on my KO2s
    Elevatorguy likes this.
  11. Nov 29, 2023 at 12:47 PM
    whodatschrome
    lots of dents
    It must be all subjective. I’ve never tried the Toyo, but i really like my KO2’s up here in the PacNW’s winters.
    FirstGenVol likes this.
  12. Nov 30, 2023 at 1:39 AM
    Elevatorguy
    James
    Why are you dropping the inch? Stock gearing suck with the 255/80?
  13. Nov 30, 2023 at 7:59 AM
    dirtnsmores
    Southern CA
    I noticed a small difference. And I still get a little bit of a rub. The smaller tire is a little lighter and Load C instead of E in these Toyos. The little things add up. Not 100% sure on this plan since my tires have plenty of life
    Elevatorguy[QUOTED] likes this.
