Anyone running 35 x 11.50r20
Discussion in 'Wheels & Tires' started by Jeffro22, Sep 25, 2022.
  1. Sep 25, 2022 at 7:41 AM
    Jeffro22
    Jeffro22 [OP] New Member
    2013 platinum crewmax 4x4
    Have a 2.5" leveling kit (5100's) on front and shackles on back
    Factory 20" wheels with 1.25" spacers
    Anyone running 35x11.50r20 with similar setup?
    Looked like it would fit
  2. Sep 25, 2022 at 9:56 AM
    Medic343
    Medic343 5+4+3=2
    Kenny
    New Mexico
    '22 SR5 TRD off-road
    I'm not anymore because I bought a '22 but my 2017 had that same setup with no issues.
    Jeffro22[OP] likes this.
  3. Jul 3, 2023 at 6:29 AM
    Jeffro22
    Finally got the 295/65/20 mounted. Looks like it’s rubbing the body mount and the front plastic liner. Was really hoping I wouldn’t have to do anything with the mount. Will see if I can re-shape the plastic
  4. Jul 4, 2023 at 4:00 PM
    Chad D.
    Chad D. New Member
    Western Oregon
    2018 CrewMax Platinum
    Take care of the plastic, and I’d recommend heading to the alignment shop to see about setting your caster as far “positive” as you can while remaining in the acceptable range. That’ll push the LCA forward, adding a little more space for body mount clearance.
  5. Jul 4, 2023 at 6:51 PM
    Cthulhu
    Have you tried the setup without the spacers?
  6. Jul 5, 2023 at 5:27 AM
    Jeffro22
    thanks. Will give that a try
  7. Jul 5, 2023 at 5:27 AM
    Jeffro22
    No. I haven’t
  8. Jul 5, 2023 at 8:14 AM
    Cthulhu
    You might want to try that. I've seen 2.5 gens with a level (spacer "puck" or lifted coilover) use 35x11.5x20 WITHOUT wheel spacers, and the only things that had to be modded were trimming the "ears" off the OEM skid plate, removing the front air dam/mud flap, and sometimes, heating and pushing in the front liner. The tires on their set-ups did NOT contact the body mount. When you go to a 12.5 wide tire, it gets a little trickier with the body mount, in which case caster needed to be adjusted as mentioned above. YMMV as set-ups can be, if you read a lot on this forum, very custom depending on the rig. Definitely not "one size fits all."
  9. Jul 5, 2023 at 8:16 AM
    Jeffro22
    Ok, thanks, will give it a try and see how it does. Not sure i will like the look without the spacers though. Feel like the tires will be tucked in too much
  10. Jul 5, 2023 at 8:24 AM
    Cthulhu
    If you're looking more for the "poked out" look versus function, you're right, you might not like it. I've always been a fan of covering the tires with the wheel well or with fender flares, as it performs the function of protecting the side of your truck, your trailer and/or boat, and other vehicles following you, from slinging up mud/dirt/road debris.
    Saltyhero13 likes this.
  11. Jul 6, 2023 at 8:47 AM
    Jeffro22
    don’t really need or want a poked out look. I just think the stock spacing looks funny on the tundra. Like it’s tucked in too much.
    I appreciate the suggestion. I think I would almost rather keep the spacers and just get the body mount chopped if the alignment doesn’t fix it
    Cthulhu[QUOTED] likes this.
  12. Jul 6, 2023 at 9:04 AM
    Cthulhu
    :thumbsup:
  13. Jul 6, 2023 at 5:55 PM
    Chad D.
    Chad D. New Member
    Western Oregon
    I think you should be able to make it work. 1.25” spacers with a +60mm OEM wheel will net you +30mm, which is right in the sweet spot for Tundras. The 8” width on the wheels, compared to 8.5” to 9” aftermarket, will only help….
  14. Aug 1, 2023 at 10:41 AM
    Jeffro22
    Went ahead and ordered a body mount chop kit. Cut the body mounts today. Just have to find someone to weld the plates on now.
    D4x4TRD likes this.
  15. Aug 1, 2023 at 10:50 AM
    D4x4TRD
    D4x4TRD New Member
    Định
    Va beach, VA
    2012 Sr5 DC TRD 4x4 Blaaaaaack baby 4.6liter
    Blacked out front grill badge Bigger tires 305/60r18 Tonneau cover
    Local welder should be able to do that for cheap
  16. Aug 11, 2023 at 2:35 PM
    Jeffro22
    Any worries on melting those rubber mounts when welding the plates?
