Anyone running the Front Runner bed rack bars?
Discussion in '2.5 Gen Tundras (2014-2021)' started by Clrems77, Nov 12, 2021.
  1. Nov 12, 2021 at 11:14 PM
    Clrems77
    Clrems77 [OP] New Member
    I’m looking to combine the front runner bar system with a Retrax XR cover to carry my Tepui RTT.
    Is anyone running this combo and cod so, can you tell menos it’s solid/sturdy enough?
  2. Nov 12, 2021 at 11:37 PM
    Cruzer
    Cruzer Wheeling Full Size
    Cruz
    Sunnyvale, CA
    Um so when you say FR bar are you talking about the rack itself? Otherwise you could be talking about the mounts that bolt to the bed rail because that’s all there is to it.
    I’ve had the FR rack for years. The original mounts are not stiff enough on the rails so they squeak a lot. I then bought the VooDoo bars and had the same problems, lots of movement = lots of noise. I recently got the Victory4x4 rack and put my FR rack on top. Solid. No squeaking. So it sounds like you want to do something similar, which will work no problem. You may have to drill holes to line up the bolts.
    The rack is solid. You can put your RTT on it and additional accessories - just as long as the base rack is solid and can support the total weight then you’re good. I actually just took mine off and am considering selling it. The FR rack on top of another rack plus all the equipment is making my truck too top heavy for what I want to do.
  3. Nov 13, 2021 at 3:37 AM
    Spyker
    Spyker I’m a dude,playin a dude,disguised as another dude
    I would be interested if the OP isn’t.
  4. Nov 13, 2021 at 6:02 AM
    Cruzer
    Cruz
    Sunnyvale, CA
    Where you located?
  5. Nov 13, 2021 at 6:19 AM
    Spyker
    Opposite end of CA haha, East Coast
  6. Nov 13, 2021 at 6:28 AM
    Cruzer
    Cruz
    Sunnyvale, CA
    Oh man. Even though it's made of aluminum that mofo is not light and would probably cost a lot to ship.
  7. Nov 13, 2021 at 7:41 AM
    Clrems77
    I’m interested and just south of you!!
  8. Nov 13, 2021 at 9:21 AM
    Cruzer
    Cruz
    Sunnyvale, CA
    FYI the FR uses slots on the top and under side. Put a bolt into the slot and slide it into position.
    Looks like the Retrax uses a Rhino Rack bar that appears to be solid and is mounted by bolting it down on either side with some sort of mount.
    You'd have to figure out a way to secure the FR rack onto the RR bar.
  9. Nov 14, 2021 at 3:10 PM
    Clrems77
    Thanks. I’m actually just looking for the cross bars to hold my RTT. I’m trying to find something that’ll work with the Retrax XR T slot rails.
  10. Nov 19, 2021 at 10:28 AM
    fireman_pete
    fireman_pete New Member
    Pete
    2021 SR5 Trail Edition
    Not to hijack the thread, but I have a set of like new FR load bars for a Tundra for sale. They were installed on my 2017 for about 2-3 months, before getting my new 2021 CM. I am location in So Cal (Temecula)
  11. Nov 20, 2021 at 8:13 AM
    Clrems77
    I appreciate the offer and wish I had known a bit earlier. I just bought a FR rack.
  12. Nov 20, 2021 at 11:13 AM
    a522467
    a522467 Life’s short. Live now.
    Michelle
    Ohio
    2020 Black Tundra Doublecab 4X4 SR5 with SX pkg
    Rear spring upgrade, rear shock upgrade, front & rear sway bars, bed step, bed mat, console organizer & tray, black lug nut covers, rear underseat storage box, black seat covers, Bluetooth CarPlay adapter, LED fogs, blue footwell lighting, LED cargo, reverse, tail, and stop bulbs, tinted tail and 3rd stop/cargo lights, tinted glass all around, tinted front emblem, matte black tailgate emblem inserts, retractable tonneau cover w/trac system and load bars, front facing camera, 8” exhaust upgrade, LED bed lights, 8-ball shifter knob, shifter boot, LED headlights, custom wheel center caps, 3”x30’ tow recovery strap, bed rail clamps, LED puddle lights, phone mount, OBD2 scanner, touchscreen glass protector/overlay, trailer hitch lock, tire traction aid, tinted license plate cover, power relay module, 6-way fuse block with cover, stainless mesh cowl screens, LT265/70R18 A/T tires, driver’s side swing case toolbox, dual air horn kit, rear Husky Liner, cat converter theft deterrent covers, front & rear dash cam, LED tail light bar, trailer plug wiring harness, locking fuel door, matte black interior door handles, glovebox & fuel door keyhole decals, TUNDRA sill plates decals, chalk bag cup holder / trash can, HD Roadmaster active suspension kit, HD front struts, Backlit window control panel, tailgate gap cover, matte black radio surround. https://www.tundras.com/threads/740-yota-2020-sr5-4x4-dc-w-sx-pkg.79742/
    I have FR bars for my Retrax. They seem sturdy enough for hauling stuff, but not sure how they would handle the strain of an RTT’s axial load (when folded open). Might be too much. They are just barely long enough to reach. Be careful not to over tighten the Retrax rail bolts or they will deform the rails.
    https://www.tundras.com/threads/wha...5-gen-tundra-today.713/page-1681#post-2053311
    I also have Yakima Overhaul HD bars for longer items (like lumber, ladder, kayak, etc).
    https://www.tundras.com/threads/wha...5-gen-tundra-today.713/page-1902#post-2224784
