Anyone use Tube Sand in Winter?
Discussion in 'General Tundra Discussion' started by RookieEP, Feb 9, 2021.
  1. Feb 9, 2021 at 10:19 AM
    RookieEP
    RookieEP [OP] New Member
    2020 Tundra Limited TRD Magnetic Gray
    None
    Loving my 2020 CM limited. This is my first pickup truck. Debating if I should put some tube sand in the bed for traction/safety. If so how many pounds? Think bags come in 60-70lbs
  2. Feb 9, 2021 at 10:26 AM
    frichco228
    frichco228 Valued Member
    2016 Crewmax 4WD, TRD Offroad
    folks usually add 150-200lbs
  3. Feb 9, 2021 at 11:47 AM
    Tmd_mn
    Tmd_mn New Member
    I usually just buy the water softener salt bag as weight, come spring it will save me a trip to Costco when I need to refill the salt. Saves me the trouble to try to store it, as these sand bags usually fall apart after each season.
    Black Wolf and RookieEP[OP] like this.
  4. Feb 9, 2021 at 11:54 AM
    Anohibian
    Anohibian New Member
    Anchorage, AK
    2018 Inferno Crewmax
    I run 6 bags of gravel at #60 so 360lbs placed at the back half of the fender wells in the bed.
    Black Wolf likes this.
  5. Feb 9, 2021 at 11:55 AM
    shawn474
    shawn474 Lego connoisseur
    MoCo, Maryland
    Trigger warning (the below statement is meant as a joke and looking to make people laugh - I am sarcastic by nature)
    Be careful........we don't want to get into a payload debate here and god forbid we add that much weight without a transmission cooler...........
    rockmup, Black Wolf, Hbjeff and 2 others like this.
  6. Feb 9, 2021 at 4:01 PM
    Notarobot
    Notarobot Jagged lines!
    2013 CM
    I have 300lbs over the axle of my CM with Defender LXT tires and drove 20 miles in 4" of snow in 2wd. I didn't even consider 4wd.
  7. Feb 9, 2021 at 4:45 PM
    Gotyour6
    Gotyour6 New Member
    Fairport, NY
    2019 Tundra Pro
    I have never in my life added weight to my bed but I am not in mountains or anything.
  8. Feb 9, 2021 at 4:52 PM
    BravoDeltaRomeo
    Bruce
    MB Canada
    2019 Cavalry Blue Tundra CM
    Let it fill up with snow and park it outside. Free bed weight.
    I don't add anything to mine. Good snow rated tires would probably be a better solution.
    T500 and FlyingWolfe like this.
  9. Feb 9, 2021 at 4:55 PM
    FlyingWolfe
    FlyingWolfe Wolfie
    Crystal
    Maine
    2018 TRD Off-Road Inferno
    I live in Maine and drive my Tundra and my work Silverado daily (drove in todays snow/ice storm several times back and forth to a job site, backroads, etc). If it sucks bad enough I use 4wd to help when needed and dont drive like meat head. I have BFGs on both trucks *cue falken arguments* and Im sure having chonk tires helps as well.
    I did put 300# of sand in the trunk of my rwd 1990 Camaro with bald assed tires though.. That was a fun winter vehicle as a teenager :rofl:
    Black Wolf and BravoDeltaRomeo like this.
  10. Feb 9, 2021 at 5:42 PM
    DZ_
    DZ_ New Member
    Frederick Co., MD
    2019 Tundra Crewmax Limited TRD DadWagon
    I keep about 200# up by the cab, in addition to the weight of the tool tray and cover. Seems to be a good setup.
  11. Feb 9, 2021 at 5:44 PM
    TelemarkTumalo
    TelemarkTumalo New Member
    Mark
    Bend, OR
    2020 Tundra TRD Pro Double Cab Army Green
    Driver side grab handle Door sill protectors Falken WildPeak 295/70 R18 X-Pel clear front paint protection 20% front window tint Go Rhino RB20 side steps - Bedliner finish Lock'er Down 1/2 console safe Toyota bed cargo divider Toyota auto tail gate lock
    mineguy, FlyingWolfe and 70m4h4wk like this.
  12. Feb 9, 2021 at 6:11 PM
    70m4h4wk
    70m4h4wk New Member
    Paris of the Praries
    23 Silverado LT, CCSB, 2.7L Turbo
    2/2 Drop, Ram Daytona Spoiler
    I keep about 200 lbs of sandbags in the bed during the winter. I wedged a board in behind the wheel wells and I just drape the bags over it, and they almost always stay put.
    The rest of the year, I usually leave 100 lbs in the bed to help with the bouncing.
  13. Feb 9, 2021 at 6:23 PM
    DeesCrewMax
    DeesCrewMax New Member
    Deric
    2018 Cement Crewmax SR5
    Accutuned Fox 2.5 DSC/2.0 rr, SnugTop Rebel, Alpine Amp, OEM LED headlights, LED fogs, Remote Start, RB20 steps, RCI Skids, 10" BA Muffler, 17" Icon Alloy Six Speeds, 15" Tint, Pro-clip mount
    I do. I keep 2 (60lb each) of them over the rear axle pushed up against the wheel wells.
    I find it helps the truck feel more balanced on ice. Even with a topper, roof rack, box, gear, and snowtires (blizzak), the back end feels better when i have a little extra weigh back there and i notice less wheel spin in 2wd. I wouldn't say its required, but i feel it helps in dicey conditions.
  14. Feb 9, 2021 at 6:34 PM
    chuffaluffigus
    chuffaluffigus New Member
    2021 Limited
    I work in the third snowiest place in the United States. We don't use salt, and they only sand very sparingly in my area - usually in town. The road is essentially always either fresh powder, hard pack snow, or ice. I commute there every day from 35 miles outside the park. I haven't found the need for any additional weight in the Tundra. I throw it in 4 hi when the snow on the road is deeper than 6 inches or so. Other than that I just drive reasonably. The traction control and ABS systems are pretty incredible. The truck hasn't let me down yet.
  15. Feb 9, 2021 at 7:39 PM
    chuffaluffigus
    2021 Limited
    Here's my work parking lot. Those walls are cut with a blower. That's not snow mounded up with an end loader or anything.
    720f43b2-fb82-4536-a31c-e298039a3e0b.jpg 6f4ee5a1-c311-488b-827d-33bf0759168e.jpg
  16. Feb 10, 2021 at 3:24 AM
    Bammer
    Bammer I'm disinclined to acquiesce your request.
    Monroe, CT
    2019 Tundra SR5 TRD Crew Max 4x4
    Expensive alternative, but I use dedicated rims with snow tires for winter use.
    TelemarkTumalo likes this.
  17. Feb 10, 2021 at 3:42 AM
    T-Guy69
    T-Guy69 New Member
    Long Island
    Black 2020 Tundra SR5
    I should. My Bridgestone's suck in the snow. Should have asked for Michelins on my 20 inch rims.
