Anyone using Mobile One for Hybrid engines?
Discussion in '3rd Gen Tundras (2022+)' started by Dabutcher, Jan 28, 2025.
  1. Jan 28, 2025 at 5:30 AM
    Dabutcher
    Dabutcher [OP] New Member
    D
    Twin Cities
    2022 Tundra 1794 Supersonic Red
    Nitto Ridgegrapplers 175/60/20
    Just got a deal on fifteen five quart jugs. If Walmart would have honored my other two orders for 20,20 I would have had 135 jugs to flip! I guess I am lucky to get the fifteen for one bill.
    I am going to use these in my 22 1794 non hybrid.
    Love yours. D
    SnrDisregardo likes this.
  2. Jan 28, 2025 at 5:35 AM
    SnrDisregardo
    SnrDisregardo New Member
    Wade
    IL
    2018 Platinum CrewMax 4x4
    TRD Sport Suspension, TRD Front & Rear Sway bar, TRD Pro Shift knob, Charcoal Filter Delete, aFe Pro Dry S w/SABM, LineX bed, Remote Start, OEM tonneau cover, DIY pop'n lock, DIY TRD cold air intake, TRD skid plate, DD SS3 amber fogs, HotShot Offroad Hot Tails, 2020 OE radio with tech12v amp and sub.
    Just make sure you shake them before use.
  3. Jan 29, 2025 at 9:09 AM
    Dabutcher
    D
    Twin Cities
    A lot of hybrid engines on here.
    Thought this would be a good choice for them? peace. D
  4. Jan 29, 2025 at 9:41 AM
    jctmundra
    jctmundra New Member
    Northern VT
    '23 1794 Hybrid Stunning Mesquite/Cream
    Tundrastruck91 likes this.
  5. Jan 29, 2025 at 12:01 PM
    SnrDisregardo
    Wade
    IL
    HA! I used to work for HPL in the lab. I calibrated all those foam testers. Prior to this, unless you knew you were getting the latest batch, shake the product. Good to see Lake did a video about it.
    Hank Hill likes this.
  6. Jan 29, 2025 at 1:28 PM
    Raven67
    Raven67 It wasn't me.
    Kentucky
    24 Limited, 21 Redeye
    Hybrid engines are the same as non hybrid engines as far as oil is concerned. No difference whatsoever.
    Twin2turbo, Soupbean77 and WILLINH like this.
  7. Jan 29, 2025 at 2:42 PM
    GREENPUS
    GREENPUS New Member
    Scott
    2024 Black Tundra Limited TRD Off-Road
    Yes the hybrid bits separate and float and when you flip the jug to empty they float away from the hole and don’t get dumped into the engine
  8. Jan 29, 2025 at 2:49 PM
    ARB1977
    ARB1977 New Member
    Anthony
    24 Tundra CM SR5 4x4 CSM build date 05/24
    These aren’t your traditional hybrid design. It’s an electric motor for additional power that’s it. The engine runs all the time. If these were true hybrids you would be getting by far better mpgs. My non “hybrid” gets 20-24 mpgs. I don’t see these hybrids getting any better.
  9. Jan 29, 2025 at 3:10 PM
    WhiteSR5
    WhiteSR5 New Member
    SC
    2021 DC SR5 4x4 (guess the color)
    Look at the viscosity specs on the Mobil1 website. I’m betting the viscosity is a bit lower than a standard 0w20.
    in a truck, especially a turbo charged truck, Ideally you’d want something at the higher end of the range for its grade.
    Will it hurt anything? Probably not… especially if not used under severe service. I would not push it to 10,000 miles.
  10. Jan 29, 2025 at 3:42 PM
    LightTheBeam
    LightTheBeam New Member
    Sacramento, CA
    2024 Tundra Limited
    Bone stock (for now)
    How does it taste compared to regular Mobil 1?
  11. Jan 29, 2025 at 3:47 PM
    GREENPUS
    GREENPUS New Member
    Scott
    Mobil 1 Hybrid Ow20:
    Density @ 15.6 C, g/ml, ASTM D4052: 0.841
    Kinematic Viscosity @ 100 C, mm2/s, ASTM D445: 8.7
    Mobil 1 AFE Ow20:
    Density @ 15.6 C, g/ml, ASTM D4052: 0.8399
    Kinematic Viscosity @ 100 C, mm2/s, ASTM D445: 8.190
    Mobil 1 Regular Ow20:
    Density @ 15.6 C, g/ml, ASTM D4052: 0.845
    Kinematic Viscosity @ 100 C, mm2/s, ASTM D445: 8.4
    Soupbean77 and WhiteSR5[QUOTED] like this.
  12. Jan 29, 2025 at 3:56 PM
    ZappBrannigan
    Canada, by way of Hawaii
    2018 1794 MGM
    NVS light bar
    At least someone is Asking the real hard hitting questions over here.
    Gonefishingdave and Soupbean77 like this.
  13. Jan 29, 2025 at 4:00 PM
    DRP
    DRP Old Member
    Dave
    Interesting. My wife bought some lube with the same kinematic viscosity as the mobile 1 hybrid oil. A 5 quart jug would last a lot longer..... Not sure I could remember to shake it first though.:thumbsup:
  14. Jan 29, 2025 at 4:00 PM
    WhiteSR5
    WhiteSR5 New Member
    SC
    I must’ve been thinking about the AFE - Advanced Fuel Economy version.
    Curious what the difference with the Hybrid… maybe more moly to help with starting/stopping? Then again, most new cars are doing that strategy at stoplights. Got me. Hope OP has some miles to drive, because that’s a lot of oil!
    ETA: “Mobil 1 Hybrid full synthetic motor oil is specially formulated for hybrid engines and their unique technical needs. Hybrid engines run differently than non-hybrid (internal combustion) engines - they generally run at lower operating temperatures as the power source rotates between the engine and battery. These lower operating temperatures can allow contaminants, like fuel and water, to accumulate in the engine oil. Mobil 1 Hybrid is formulated with extra additives to help fight damage from these harmful contaminants and to provide that extra protection your hybrid engine needs.”
    also, I’m seeing KV at 8.2@100c. But that’s trivial
    GREENPUS[QUOTED] likes this.
  15. Jan 29, 2025 at 4:03 PM
    GREENPUS
    GREENPUS New Member
    Scott
    AI says hybrid has more additives. I’m too lazy to research that lol
  16. Jan 29, 2025 at 4:45 PM
    olafman1
    olafman1 New Member
    North Carolina
    2024 TRD Pro
    Here's a video about that same oil (sponsored video).
  17. Jan 29, 2025 at 6:16 PM
    Raven67
    Kentucky
    Hybrids have a flux capacitor, it runs best on used French fry oil.
    Don't forget about the hybrid air for the tires as well. And the differences in summer air & winter air & why you should change it.
    You guys are getting complicated.
    Even dealer oil changes come from the same big bulk oil tank out back.
    kirkb, Soupbean77, BlackNBlu and 2 others like this.
  18. Jan 30, 2025 at 5:01 AM
    Dabutcher
    D
    Twin Cities
    Wally World screwed up. The three packs of five quarts ,multipacks were at the single jug sale price of $28.76. So I bought as many as I could. 15K miles guaranteed! I will change every 5K.Current ride 2022 1794.
    Peace. D
  19. Jan 30, 2025 at 5:25 AM
    BlackNBlu
    BlackNBlu Justa Member
    Rich
    MN
    24 Limited CM 5.5 Blueprint TRD OR
    5100's, 285/75/18, Air Lift bags, bits and bobs
    I'm surprised no one had mentioned "Protects for 15,000 miles - Guaranteed*", until now, and Triple Action Formula (!!!)
    Seriously, I'm sure it's perfectly fine oil, but the marketing BS is just that.
    There are 15 different varieties of Cheerios.
    There are 16 different varieties of Mobil1.
    Something for everyone.
    Soupbean77 likes this.
  20. Jan 30, 2025 at 11:00 AM
    Raven67
    Kentucky
    Whatever sells more! To more people.
  21. Jan 30, 2025 at 3:36 PM
    GREENPUS
    GREENPUS New Member
    Scott
    This is for peoples that buy gluten free shampoo and conditioner
