Anytime fog light mod with factory on/off
Discussion in '2nd Gen Tundras (2007-2013)' started by Brocksw, May 22, 2019.
  1. May 22, 2019 at 10:56 AM
    Brocksw
    Brocksw [OP] New Member
    Spruce Mica 2012 SR5 Off-road DC
    Elka 2.5 reservoir front(+3") and rear, JBA UCAs, toytec +1.5" shackle, Falken Wildpeak 285/75r18.
    I've seen the DIY fog mods threads and I'm pretty close to electrically illiterate so I'm more confused than I was before.
    What I would like to be able to do is use my factory on/off switch (second twist switch) for the fogs and be able to turn them on anytime. So that could mean turn them on when the low beams are on or when my high beams are on. I also want to be able to turn them off any time because I'm going to be installing some BD fogs and dont want them running all the time around town.
    Is this possible to do without adding a new button in my dash and losing my factory twist switch?
    I'm also planning on cutting my daytime running lights, will this affect any of the fog mods?
  2. May 22, 2019 at 11:00 AM
    Fotnot
    Fotnot SSEM #69; LRCS#1
    Andy
    SW Louisiana
    Swimmers gonna swim
    have you read this thread yet? i did it before on my last tundra (2011 sr5) and it worked just as you're stating. lights had to be in at least park lights mode, and fogs could be used independently with brights or dims.
    https://www.tundras.com/threads/diy-fog-light-mod.371/
    Comfort likes this.
  3. May 22, 2019 at 11:01 AM
    Brocksw
    which mod did you use?
  4. May 22, 2019 at 11:11 AM
    Brocksw
    I'm thinking the Eddies V1 is the one I'd want to do...I think... this electrical shit might as well be written in mandarin
  5. May 22, 2019 at 11:24 AM
    Fotnot
    Andy
    SW Louisiana
    Swimmers gonna swim
    i had done a jumper wire. it's been about 4 years since i had done it, but all i had to do was cut 2 wires (i think a grey and pink one) and jump together and it worked great and never had any issues at all!
    CMikeB likes this.
  6. May 22, 2019 at 11:29 AM
    Brocksw
    That sounds like Eddie's V1 if I'm reading that diagram correctly.
    How far back did you cut the wires? Not sure how much room I need to give myself.
  7. May 22, 2019 at 11:35 AM
    Fotnot
    Andy
    SW Louisiana
    Swimmers gonna swim
    i gave enough room to be able cut and resplice/solder if needed for any errors. so i think i was about 4 inches away from the harness plug.
    Brocksw[OP] likes this.
  8. May 27, 2019 at 8:52 PM
    redmont94
    redmont94 New Member
    i would check out "the brite box" its plug and play by aspire auto :thumbsup:
    thats what i got. keeps my fogs on with my highs
  9. May 27, 2019 at 11:59 PM
    xtyfighterx
    xtyfighterx New Member
    Ty
    North Idaho
    2015 Black Crewmax Mid Travel
    NewImprovedRon likes this.
  10. May 30, 2019 at 4:56 AM
    tapeworm
    tapeworm New Member
    Aaron
    2019 Cement Grey Tundra SR5
    3.5" Rough Country Lift Fuel Cleaver wheels
    Hoping this mod works on my '19 tundra! :)
    redmont94 likes this.
  11. Feb 22, 2020 at 10:02 PM
    jwarren2
    jwarren2 New Member
    James
    Sugar Land Texas
    2014 Black Tundra Platinum 4x4
    None yet but making a list and looking at the budget.....
  12. Feb 22, 2020 at 10:59 PM
    xtyfighterx
    Ty
    North Idaho
    I don’t see why not? Mines an off road. Can’t tell you 100% but my instincts say it should.
    Looks like a guy with a platinum same year posted on my thread that it work.
  13. Feb 22, 2020 at 11:12 PM
    jwarren2
    jwarren2 New Member
    James
    Sugar Land Texas
    I guess it won't hurt to try. Sure is cheaper than purchasing the "Bright Box" product to do the same thing. Thanks..
    xtyfighterx[QUOTED] likes this.
  14. Nov 11, 2021 at 6:24 PM
    Octave
    Octave New Member
    2021 Sequoia TRD Pro (Super White)
    ALL incandescent lights to LED Added LED footwell lights TRD CAI TRD Catback exhaust Side de-badging Westcott Designs Lift Kit Front TRD sway bar Rear TRD sway bar TRD cup holder coasters TRD seatbelt pads Lots more mods to come!!!
    Did anyone get this working for a 2021 Sequoia TRD Pro???
  15. Nov 12, 2021 at 6:56 AM
    Fotnot
    Andy
    SW Louisiana
    Swimmers gonna swim
    My 21 pro has it available already. Put your fog lights on, then put your lights to this setting. I verified it today while in the drop off line and also following behind someone looking in their tailgate reflection. It works.
  16. Nov 12, 2021 at 8:46 AM
    Octave
    Octave New Member
    If I put it in that setting only the parking lights will be on with the fogs……I’m confused.
    I would rather just install a mod that I don’t have to worry about switch settings……..
  17. Nov 12, 2021 at 8:48 AM
    Octave
    Octave New Member
    The reason why it works in the parking light mode is that the fogs and brights are 4 lights out the front. That is all you can have on at one time by law……
  18. Jan 26, 2023 at 10:46 AM
    hoopin4you
    hoopin4you New Member
    I have the same stalk on my '14 Sequoia, and the fogs do NOT come on when the switches are in the same position as yours...must be something different between the two models.
    Fotnot[QUOTED] likes this.
  19. Jan 26, 2023 at 10:51 AM
    Fotnot
    Andy
    SW Louisiana
    Swimmers gonna swim
    you got me wanting to double check it again now. lol
  20. Jan 26, 2023 at 3:41 PM
    Jeff_5_7
    Jeff_5_7 New Member
    Jeff
    Houston Tx Area
    I was studying the wiring diagrams last week. This mod can be done.
    You can do the Eddie’s mod which basically makes the fogs on anytime the headlights are on.
    OR you can wire it to a keyed ignition source so that anytime the key is on, the fogs can be turned on/off with the factory switch. Nobody that I know of has done this yet but it will work.
    If anybody wants to tackle it I think it takes $20-$30 in parts from the auto chain stores.
    hoopin4you likes this.
  21. Jan 28, 2023 at 6:22 AM
    Joewildlife
    Joewildlife New Member
    Joe
    2006 Access Cab TRD
    Fog light mod
    First post on this forum. I'm looking to buy a 2nd gen and if it has fogs I will be looking into it. I figured it out on my 2006 access cab and posted on another forum, it was easy to do and enabled the fogs to burn anytime the ignition was on, independent of any other lights. My 06 has been that way for about 16 years with no problem, I run them like DRLs since my truck didn't come with DRLs. I'm going to get the wiring diagram for the 2nd gen and check out all the posts and go from there...
  22. Jan 28, 2023 at 6:29 AM
    hoopin4you
    I completed the mod yesterday, and now it works. :thumbsup: Even though Eddie's write-up says '07-'08, I can confirm that my '14 Sequoia has the same wiring schematic.
  23. Jan 28, 2023 at 6:37 AM
    Jeff_5_7
    Jeff_5_7 New Member
    Jeff
    Houston Tx Area
    Read here https://www.tundras.com/threads/easy-5-min-anytime-fog-light-relay-mod-diy.20508/page-8#post-3065517
    I explained a little more on how I would do it or have total control with fog switch and key only
  24. Jan 28, 2023 at 7:34 AM
    hoopin4you
    I prefer running the fogs with the DRLs for more visibility. The amber DRL always catches my eye from other vehicles I see on the road. The only time I run the fogs/DRLs is from early dusk to before it's too dark to just have them on by themselves.
  25. Dec 10, 2023 at 9:13 AM
    Octave
    Octave New Member
    Still looking for a write-up (or advice) for my 21 sequoia to get this mod done.
    Worried that the wire colors and locations are not the same as EddieV1 write-up……
    I got a Britebox from Aspire and it didn’t work. He said he was going to help me get it working, but then stopped answering my emails texts and phone calls. Totally ghosted me!
    Bummer.
    Please help!
  26. Jun 26, 2024 at 6:36 AM
    84runner
    84runner 2016 Limited, Premier Package
    Arroyo Grande, CA
    2016 Tundra Limited, Silver, crewmax, Leer shell,, Premier Pkg, TRD OR,
    3" lift up front / stock rear.
    Still looking for a way to run fog lights anytime mod for my 2021 Limited. I want fog lights to be able to be on anytime the ignition is on. Anyone know how to do this?
  27. Jun 27, 2024 at 10:18 AM
    socaldiablo
    socaldiablo New Member
    Carlsbad, CA
    2013 White Tundra SR5 Rock Warrior
    Leer camper shell, slight lift kit, TRD Pro BBS wheels
    I'm slightly confused at how this adds any value. On my 13', my headlights and fog lights are controlled by toggles on the left side stem of the steering wheel. On that stem, the outer-most toggle controls the headlights. There is a separate toggle in from there that turns the fogs on and off. I leave that fog light toggle in the on position full-time. When I turn the toggle for the headlights to turn on, those fogs come on with the headlights and they turn off with the headlights when I turn that toggle to off. In the thread write-up on this mod, what is gained by disabling the fog light switch? I don't get it.
  28. Jun 28, 2024 at 5:59 AM
    COTundie
    COTundie Whoa Black Betty
    Trey
    Black 5.7 DC TRD 4x4
    Pretty things
    Because without the mod(s), most (if not all) 2nd gen Tundras/Sequoias are not able to run the fogs w/o the headlights on.
    I like to run fogs with DRLs during the daylight hours. Other drivers can see me better...And it just looks cool.
    I did the 5min version grounding out the relay, so I can return to factory by putting the original relay back. Worked great for the past 3 years-ish
    84runner and Fotnot like this.
  29. Jul 2, 2024 at 11:12 AM
    socaldiablo
    Carlsbad, CA
    OK, I see now. I re-read the original poster's write-up and I missed that the fogs come on with the parking lights, somehow missed that and saw that they come on the low and high beams. Thanks for that clarification.
