Apple CarPlay and Iphone
Discussion in 'Audio & Video' started by Tomcom01, Mar 20, 2023.
  1. Mar 20, 2023 at 10:39 AM
    Tomcom01
    Tomcom01 [OP] New Member
    Tom
    2021 Limited
    stock
    Hello All, my phone only works in the truck when it’s connected via Bluetooth, when it’s plugged into the CarPlay port I can’t be heard. Happens with my wife’s IPhone also. Anyone else have this issue ?
  2. Mar 20, 2023 at 11:03 AM
    RainMan_PNW
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
    Have you gone into your phone and activated CarPlay after plugging in the USB cable? And have you made sure you are using the LEFT-most USB port? (That is the only one that works with CarPlay)
  3. Mar 20, 2023 at 12:07 PM
    Tomcom01
    Tom
    2021 Limited
    stock
    I should have added that CarPlay comes up on my home screen and everything else on my phone (google maps, music) works, only the phone doesn’t work. It will respond to voice command to dial a contact but they can’t hear me.
  4. Mar 20, 2023 at 12:30 PM
    Tripleconpanna
    2021 TRD PRO CM; 2008 SR5 CM
    Even when it was 'working' functionality was very quirky in my '21 when using CarPlay; I'd have stupid issues like could access a playlist but would have to start playing from the first song (couldn't scroll through the list and pick a song to start with), and also had issues if I unplugged while the car was running, did something w/phone (like drive-thru order), then plugged it back in, it would be all screwed up.
    Went w/this item (on the recommendation of a couple of dudes from here) to create a 'wireless' car play environment, and life w/my truck and iPhone have been seamlessly pleasant since...
    https://www.amazon.com/dp/B09Q176WHH?ref=ppx_yo2ov_dt_b_product_details
    Basically, the dongle stays plugged in always and the phone automatically connects to the dongle. Just note that on a long drive your phone will be draining since it's connecting wirelessly, so you'll need to plug into one of the USB 'power only' ports while connected so it doesn't affect the connectivity.
    *** since you're running an iPhone you'll want the U2-Air version of the dongle.... :thumbsup:
    ljburns and Sierradevil like this.
  5. Mar 20, 2023 at 12:51 PM
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
    I hope setting it up again works for you. I noticed you're new here. Welcome from LA (Lower Alabama)!
  6. Mar 20, 2023 at 3:10 PM
    Clemsonman14
    Clemsonman14 New Member
    2020 SR5 Crewmax 4x2
    How does it work connecting another iPhone for CarPlay once you have established the connection with your phone?
  7. Mar 20, 2023 at 3:57 PM
    Tripleconpanna
    I wouldn't know. My phone is the only one that is set up to connect in my truck; my wife doesn't drive it. However, if you do a quick search, you can find demo videos all over the place, so I'm sure they'd have something on that concern :thumbsup:
  8. Mar 20, 2023 at 4:38 PM
    TaquitoBandito
    Joel (AKA Bif)
    I have the Air 2 version and you disconnect it from your bluetooth on one phone, connect it to bluetooth on the other. There may be another way but that's what worked for me.
    Clemsonman14 likes this.
  9. Mar 27, 2023 at 7:03 AM
    Tomcom01
    Tom
    2021 Limited
    stock
    I have tried everyones suggestions, the only thing I haven't tried is changing the cord which I really doubt is the problem but you never know. After that I will just go the wireless route. Thanks everyone and I will post an update if the cord makes a difference.
  10. Mar 27, 2023 at 7:23 AM
    DFW_SoldTacoBoughtTundra
    DFW_SoldTacoBoughtTundra New Member
    DFW
    2021 Limited 4x4
    6112s, Icon add-a-leaf pack, Icon 17s
    I have issues with apple carplay as well (plugged in). If I'm using a navigation app, especially Waze and take a call Waze will start to glitch: screen image gets all scrambled, screen is frozen, etc. and requires me to unplug and plug back in. Randomly when I take a call I will notice that the sound seems choppy and delayed. When this happens I notice that the phone call elapsed timer frozen and the buttons on the screen are unresponsive. Very frustrating experiences.
  11. Oct 19, 2024 at 6:45 PM
    dKinzer
    dKinzer New Member
    Any fix to this?? The ios18 update with iPhone 16 messed up everything. My iPhone 13 worked fine with a few errors here and there. Now the phone function is completely bricked. Glitches the screen, call timer freezes, person on the other end can’t hear anything except broke words. Etc. my friend also has the exact same issue
  12. Oct 21, 2024 at 2:03 PM
    Tomcom01
    Tom
    2021 Limited
    stock
    I'm pretty sure it my phone that is causing the issue because it does the same thing in my wife's Mazda. I'm due for an upgrade so I'll know soon.
