ARB Air Lockers?? Who has them ?
Discussion in '2.5 Gen Tundras (2014-2021)' started by ONTHEEDGE, Apr 13, 2020.
  1. Apr 13, 2020 at 4:46 PM
    ONTHEEDGE
    ONTHEEDGE [OP] New Member
    2016 Tundra TRD Off Road.
    20” Fast HD Wheels Black TRD Exhaust TRD Pro Grill Bilstein 5100’s Debadged
    I have a 2016 Toyota Tundra and am thinking about an arb air locker, wondering what the experience is like and how does it effect the trac control/electronics
  2. Apr 13, 2020 at 4:49 PM
    JimboSlice413
    JimboSlice413 Super Nice Guy
    Bakersfield
    2016 Limited 4x4, 2003 Sequoia
    Bilstein 5100/5160 Toyo at2 295/70r18 Ray10 GunMetal
    I hear those Eaton E lockers should be hitting the market anytime. Just another option
  3. Apr 14, 2020 at 4:58 AM
    Tundyfundy
    Bay Area, CA
    Magnetic Grey DC SR5 4x4 2016
    SUSPENSION: Bilstein 6112 coilover (1.9") w/ Powder Coated Springs and Spring Perch (TRD Red), JBA Upper Control Arms, Bilstein 5160's w/Billet Aluminium Reservoir Brackets, +2 Coachbuilder Shackles, Diff Drop Kit, Carrier Bearing Drop Kit, Brakeline Extensions, ABS Extension, Poly Bushings for Leafs, Coachbuilder Shims (2 Each Side), Coachbuilder Bumpstop Extensions, TRD Rear Sway Bar, TRD Front Sway Bar, Air Lift 5000 airbags w jounce bumpers, Daystar Airbag Cradles WHEELS AND TIRES: BF Goodrich KO2's 275/70/r18, BORA wheel spacers 1.25", TRD Wheel Caps,TRD Valve Stem Caps, Spare Tire Lock PERFORMANCE: Bullydog GT Tuner(Performance Tune), TRD Intake, TRD Dual Exhaust (with Modified Exhaust Hangers for Levelling Tail Pipe),TRD Brake Pads, TRD Oil Cap (US), TRD Radiator Cap, TRD Oil Filter, Optima Yellow Top Battery,GP Battery Distribution Blocks, StopTech Slotted Cryo Treated Rotors, Goodridge G-Stop Steel Braided Brake Line Kit PROTECTION: PNP Engineering Type 4 Rock Sliders (With Full Dimple Plate) ,ADD Stealth Fighter Rear Bumper w Red/Blk Shackles and Custom Stomp Pad, TRD Skid Plate with ReadyLift Spacer Kit, Victory 4x4 LCA Skid Plates, JOMAX ABS Sensor Armor, Rear Diff Breather Mod, ARK splash guards INTERIOR: Husky Liners X-Act (Front and Full Coverage Rear and Front Weather Beater Trans Hump), Interior LED Bulbs, WheelSkins Genuine Leather Steering Wheel Cover(EuroPerf), Clazzio Genuine Leather Seat Covers(BLK/DRK GRYwith custom stitching and embroidered headrests), Clazzio Seat Heaters (Front and Rear), Entune Startup Screen MOD, Entune Off Screen Mod, Tinted Windows with Windshield Visor, AJT Key Fobs,Eagle Claws Floor Mat Clips, Bodyglove Visor Organizer,Custom Door Cup Inserts, Glass Break Sensor,AJT Radio Knobs, Custom Dior Cup Inserts EXTERIOR: Full Debadge, LED Brake Light Bulbs, LED Rear Turns, LED Reverse, LED Plate Lights, LED Cargo Lights, LED Third Brake Lights, LED Front Marker Lights, LED Fog Light Bulbs, Lamin-X Fog Light Covers (Amber),2018 OEM LED Headlights, iHacker harness, VLED Universal Puddle Lights, VLED Interior Footwell Lighting (Front and Rear),VLED Extreme Amber Fornt Turns, NSV Knight Rider Light bar, Baja Designs Sport Squadron Pods in Rear Bumper (Driving/wide), Painted Red Tow-hooks, Bed Rail System, Blind Spot Mirrors, Hitch-safe, Tail-gate lock, EAG Raptor Grille, Custom Grille Badge,Full Vinyl Wrap (Matte Black/Matte Pine Green Mettalic), Charvonia Designs Tie Bed Tie-Downs, Bull Ring Bed Rail Anchors, Line-X, Tundra Bed Mat, Bakflip F1 Bed Cover SOUND: Noico 80Mil Sound Deadening and Noico 170 Mil Thermal Insulation (All 4 Doors, Roof, Floors, Rear Panel, Dash). Hertz Uno K170's Component Speakers (Front Doors with Upgraded Sail Panels), Hertz Uno K170 Coaxial Speakers (Rear Doors), JBL C1-075ct Tweeters (Total 4) in Side Dash and Center Speaker, JBL Stadium 5 Amp w/Remote Bass Adjustment Knob and Amp Rack, 12" Infinity Reference Subwoofer in Custom Enclosure w/ “TUNDRA” Logo, Fast Rings Foam Speaker Rings System(4 Doors), Fix 86 DSP
    E lockers are good but not as good as ARB. The e locker disengaged between forward and reverse which, if technical wheeling, can be dangerous as you need to let the vehicle roll back or forward after shift before it engaged. Not always a bad thing but something to think about. https://www.theengineblock.com/debate-air-lockers-or-e-lockers/
    Sunnier and Brown Bear like this.
  4. Apr 14, 2020 at 5:35 AM
    Jimes
    Jimes New Member
    Bay Area, California
    2015 toyota tundra trd pro
    I have both front and rear arb lockers. Both leak. Maybe just bad install at two separate shops. But the front will still work but compressor cycles after ever 10 seconds. As for the rear. I’ve had to replace the copper line that jumps over the ring gear(design flaw). It over the ring gear too close and I would say washboard roads killed it both times. The copper line gets nicked and no more locker just compressor never stops cycling and you can hear the air spewing out in the diff and in the diff breather relocation if you have one like I do. It’s really quite annoying as it’s not a cheap fix for the part or the labor. But when it works it works great. On my third copper line and still need to get it replaced. Third and final shop asking 600 for rear and 900 for the front. I will fix it at some point, but I am strongly considering buying the e lockers. I know other have no issues, but this shit sucks for the amount of money sent. The second time they were fixed they were fixed for free as I had my 5.29s installed at the same time so they just did it to help me out cause I told them they were both leaking. Not sure why the front leaks. I unplugged the front line and used my finger to stop the compressor from cycling and it holds fine. The moment it goes back into the fitting the locker leaks somewhere and compressor cycles every 10 seconds but works. Quite annoying.7EEDB68B-CFAE-45EE-8DEE-62D6E6AB4C37.jpg72D95569-3397-4C0B-8DE2-DF6D6BF7B868.jpg600737A2-4467-4C64-BF0B-FE0A933CEFD7.jpg
  5. Apr 14, 2020 at 6:33 AM
    ZappBrannigan
    Canada, by way of Hawaii
    2018 1794 MGM
    NVS light bar
    Has there been any news on the release date for the E-Locker?
  6. Apr 14, 2020 at 6:34 AM
    tttrdpro
    tttrdpro Former Naval Person
    SWGA
    2024 GMC 2500 AT4
    In progress…
    I refuse to get an ARB air locker for this reason. Leaking is a common issue.
  7. Apr 14, 2020 at 7:26 AM
    Hugemoose
    Hugemoose New Member
    David
    Philly
    2016 Tundra Crewmax
    Not enough....
    I wouldn't mind one, but as @Jimes pointed out, air leaks are a common issue. I'm waiting for Powertrax to finally release the Grip Pro.
    However I wish Powertrax made the No-slip (https://www.powertrax.com/product-info/no-slip-traction-system/) for the new gen Tundras. I had one in my first gen for over a decade, only rebuilt it with new springs once (around $20), and it can easily be done at home without special tools since it just replaces the spider gears. No need to reset backlash or any of that trouble. It was otherwise flawless. No ratcheting, fully locked when on the gas, unlocked when off. It was a monster off road and in the snow during winter. And a fraction of the cost of other lockers too.
    Maybe one day they'll make it for the 10.5" diff :boink:
  8. Apr 14, 2020 at 8:05 AM
    Hattori
    Hattori STOP SHIMMING COILOVERS!!!!
    Tommy
    Nashville
    2012 Tundra CM TRD
    Me.......
  9. Apr 14, 2020 at 8:20 AM
    Jimes
    Jimes New Member
    There’s a few guys on here that have had zero issues with theirs. I wish I was one of them. Just blows for the price you pay. That’s the only part on my Toyota that’s not reliable. I believe @joonbug has them without issues. Maybe he’ll chime in since I just tagged him on his experience.
    Tundyfundy likes this.
  10. Apr 14, 2020 at 8:25 AM
    Jimes
    Jimes New Member
    Someone in Australia I believe made a bracket for their locker to hold the line away from the ring gear, but it wasn’t for a tundra, but it had the copper line go over the ring gear as well and it fixed the issue. Nobody makes the bracket for our model locker though. I looked for weeks. I wish arb made one considering its a design flaw. Plus getting the replacement parts isn’t fun either. The part cost like 90 dollars each I believe. Then you have the o ring issue, but I never had that issue. It even says to replace the o ring with a different one that arb does not sell. Again, they know about these issues and do nothing about it.
    Sunnier likes this.
  11. Apr 14, 2020 at 8:29 AM
    Jimes
    Jimes New Member
    Here it is. But it’s for an rd128. Not sure if it would work for ours but I can’t buy it either as well. Now if someone made one for ours I would buy it in a heartbeat.
    https://www.youtube.com/watch?v=jbrdI2rLsxs
  12. Apr 14, 2020 at 9:09 AM
    JimboSlice413
    Bakersfield
    I've read countless posts about the ARB's leaking. In fact, check out Jimes post right under yours. If it wasn't for so many members having problems with them, I would have put in a rear already
    ZappBrannigan likes this.
  13. Apr 14, 2020 at 9:15 AM
    blackoutt
    blackoutt YEAH BUDDY!
    Indy
    07 DC Long Bed - Old Man Tan
    OEM+
    Eaton/harrop e locker can be sourced state side through a couple of vendors, mainly cruiser brothers that I've heard of. It's pricey!
  14. Apr 14, 2020 at 11:10 AM
    Jimes
    Jimes New Member
  15. Apr 14, 2020 at 11:11 AM
    ONTHEEDGE
    Yeah im gonna avoid the ARB judging by the experience everyone is having. I don’t like issues. I really don’t off road my truck i use it while hunting and going into my camp. I really wish they just had a good posi single wheel burnouts blow lol. Thanks to all
  16. Aug 4, 2023 at 6:49 PM
    Bayou Spartan
    Bayou Spartan New Member
    Black 2019 TRD PRo
    None
  17. Aug 5, 2023 at 9:18 AM
    breynolds
    breynolds New Member
    Future Tundra owner
    I've owned 3 ARB lockers and have had no issues. I take that back, the one I have in my current 4runner had damage to the copper wire from the previous owner but after silver brazing a new copper line on, zero issues. Problems are usually associated with poor installation
  18. Aug 5, 2023 at 9:22 AM
    FrenchToasty
    Mo
    The SoAz….. big surprise
    Bone stock
    I’ve recently talked to one of the best gear installers in the country and he won’t install ARB lockers, he’s seen to many failures and won’t put his name on that installed.
  19. Aug 5, 2023 at 1:45 PM
    bfunke
    bfunke Tundra Curmudgeon
    South Carolina
    The ARB 3rd members are beautifully machined as you can see in their video. The issue is the air line needs to be improved.
    FrenchToasty likes this.
