ARB Twin Air Compressor with Wifey Kit for lockers AND air up???
Discussion in '2.5 Gen Builds (2014-2021)' started by NoSoulToSell, Jun 29, 2020.
  1. Jun 29, 2020 at 11:03 AM
    NoSoulToSell
    NoSoulToSell [OP] New Member
    Zachary
    2016 Black Tundra SR5 Crewmax 4x4
    DB Customz LED Grille Bushwacker Fender Flares Blackout Badges
    Hey guys, sorry for noob question here, but this is my first 4x4 and I am new to all of this... I recently bought a 2016 Tundra SR5 Crewmax 4x4 and am in the process of doing a lot of modifications and could really use some help on the topic of ARB Air Lockers and the Rago Fabrications "Wifey" kit. I recently purchased the Switch Pros RCR-Force 12 to control lights and other accessories, so I really have 2 questions here....
    1. Do I need to buy 2 ARB Air Lockers for the front & the rear? And should I buy the ARB differential covers for them?
    2. If I install the "Wifey" kit, will I be able to control the air lockers and airing up with the "wifey" kit from 2 independent switches on the Switch Pros?
    Any help would be greatly appreciated. Thank you =]
  2. Jun 29, 2020 at 11:33 AM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    I wouldn't put a locker in the front end, I did put one in the rear. I wouldn't buy diff covers either, nothing wrong with the OEM covers. Yes, it needs to be 2 switches, one for compressor and a separate one for locker. Also, before the wifey kit was offered I made my own and air up and deflate all 4 at once. Cost me just over $100 to create my own system with 5 outlets.
    GodlessPro, TG705, joonbug and 2 others like this.
  3. Jun 29, 2020 at 2:55 PM
    NoSoulToSell
    Zachary
    Oh, nice. Ok, thanks for the advice! Can you tell me why I wouldn't want a locker on the front?
    831Tun likes this.
  4. Jun 29, 2020 at 3:30 PM
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    I've heard our front diffs might not be up to the punishment. I've got no evidence other than 1 guy I know with a 1st gen who kept breaking stuff. So, it's mostly hearsay but worth investigating. No one I wheel with has a front locker and only a couple guys have rear lockers. When considering a locker it's wise to consider what tire size you think you'll end up with and whether or not gears are a good idea. I re-geared so I figured might as well throw a locker in there at the same time. I rarely use it but I'm glad I have it.
    GodlessPro, TG705 and joonbug like this.
  5. Jun 29, 2020 at 6:48 PM
    NoSoulToSell
    Zachary
    Cool man. Thanks for your input. I appreciate it. I'll look into it some more. I'm doing a 7" BDS lift with BDS UCA and Fox 2.5 Coil-Overs and 17" Methods with 37" Nitto Ridge Grapplers. I was putting off the regear for now, so maybe I'll do that same time as the lockers too.
    831Tun likes this.
  6. Jun 29, 2020 at 6:51 PM
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    Yet again, just my opinion, but with 37s you will really benefit from 5.29s. I love mine.
    TundraPHX and GodlessPro like this.
  7. Jun 30, 2020 at 8:51 AM
    NoSoulToSell
    Zachary
    Cool cool. Thanks man! =]
    831Tun likes this.
  8. Jul 2, 2020 at 11:39 AM
    NoSoulToSell
    Zachary
    Hey man I was looking at regear options and came across these, but they are 4.88 and you mentioned 5.29's? The listing says 07-2014 but the guy on the phone said they should work for my 2016. I def don't want to order these and have to return them while my truck sits on a lift in pieces! I'm also confused about whether or not my truck has 9" or 10.5" rear differential. Do you know how I can check that? Trying to order gears and lockers asap! =]
    https://www.lowrangeoffroad.com/200...ckage-kit-by-nitro-gear-gptundra5-7-4-88.html
  9. Jul 2, 2020 at 12:29 PM
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
  10. Jul 2, 2020 at 12:32 PM
    rock climber
    rock climber New Member
    2001 Sequoia 4X4, 2000 AC 4X4
    The 1st gen aftermarket CV axles are too thin and tend to break pretty easily. So if he had those I wouldn't be surprised he kept breaking them.
    OP, what kind of offroading are you planning to do?
  11. Jul 2, 2020 at 2:37 PM
    NoSoulToSell
    Zachary
    I'm going to be doing a lot of offroading in the mountains of Northern Cali, but would really like to be able to handle almost anything I come across...
    This is what I've ordered so far... Regear and Lockers TBD...
    BUMPERS, WINCH, LIGHTS, LIGHT CONTROLLER, ARB TWIN AIR COMPRESSOR
    Front Bumper - Addictive Desert Designs Stealth Fighter Front Bumper w/ Winch
    https://www.addictivedesertdesigns.com/toyota-tundra-winch-front-bumper-F741202860103
    Rear Bumper - Addictive Desert Designs Stealth Fighter Rear Bumper
    https://www.addictivedesertdesigns.com/toyota-tundra-rear-bumper-R741121280103
    Warn 9.5 CTI-S Winch
    https://www.warn.com/95-cti-synthetic-winch-97600
    1" Factor 55 Hawse Fairlead
    https://factor55.com/product/hawse-fairleads/
    Factor 55 FlatLink MultiMount
    https://factor55.com/product/flatlink-multimount-new/
    40" Baja Designs OnX6 Arc White Combo LED PN#524003DC
    https://www.vividracing.com/baja-de...erwhite-arched-led-light-bar-p-151863936.html
    2 x 10" Baja Designs S8 White Combo LED PN#701003
    https://www.vividracing.com/baja-de...driving-combo-pattern-series-p-151863948.html
    Switch Pros RCR-Force 12 Switch Panel System
    https://www.utvsource.com/switch-pros-rcr-force-12-switch-panel-power-system/
    ARB Twin Air Compressor The "Wifey" Air System LIFT, SUSPENSION, UPPER CONTROL ARMS, ADDITIONAL COMPONENTS
    BDS Suspension 7" Lift Suspension System w/Fox Coil-Overs w/DSC Adjusters
    https://bds-suspension.com/product?ma=12&mo=78&ty=1&yr=2016-2018
    BDS Suspension Upper Control Arm Kit
    https://www.jackit.com/bds-128253.html
    BDS Suspension Rear Recoil Traction Bar System
    https://www.jackit.com/bds-128408-123409.html
    BDS Suspension 1.5" Carrier Bearing Drop Kit
    https://www.jackit.com/bds-128409.html
    BDS Suspension 1" Rear Lift Shackles
    https://www.jackit.com/bds-128109-b.html
    WHEELS & TIRES
    Method MR702 Wheels - 17 x 8.5 0 offset
    https://www.customwheeloffset.com/buy-wheel-offset/MR70278558500/method-mr702-17x85-0?year=2016&make=Toyota&model=Tundra&drive=4WD&suspension=Suspension+Lift+6"&bolt_patterns=5x5.91,5x150
    Nitto Ridge Grappler Tires - 37" x 13.5" R17"
    https://www.customwheeloffset.com/buy-wheel-offset2/217450/nitto-ridge-grappler-37x1350r17lt-tires?year=2016&make=Toyota&model=Tundra&drive=4WD&suspension=Suspension+Lift+6"&bolt_patterns=5x5.91,5x150
