Are y’all using OEM radiator cap or aftermarket (that you think is better) ?
Discussion in '2nd Gen Tundras (2007-2013)' started by alexusw, May 20, 2023.
  1. May 20, 2023 at 1:24 PM
    alexusw
    alexusw [OP] New Member
    2007 Desert Sand Mica Tundra LTD
    I need to replace my radiator cap and trying to decide if I should stick with OEM or go for an aftermarket one. While I’m at it, I’m also getting the radiator hoses replaced and at some point the radiator.
  2. May 20, 2023 at 1:32 PM
    alexusw
    I also noticed coolant in a weird spot. I’m not sure if it was spilled or been there. I had my water pump replaced a few months ago and valve cover gasket. As you can see in the picture it looks like coolant is around a sensor and some hose underneath the engine cover area.
  3. May 20, 2023 at 1:34 PM
    alexusw
    The level is fine in the reservoir and radiator
  4. May 20, 2023 at 2:02 PM
    biebs96
    PA
    That looks like it could have been an error/spill.
    When my water pump was replaced (under warranty, at a dealer) there was pink stuff everywhere under my engine. I cleaned it all off and it never reappeared and none of the coolant/pink stuff ever showed up again.
    I chalked it up to lazy dealer mechanics.
    Tundrastruck91 and alexusw[OP] like this.
  5. May 20, 2023 at 2:09 PM
    blackdemon_tt
    blackdemon_tt Battery Slayer
    Looks like your radiator cap is leaking and the radiator fan is flinging it back. I got an aftermarket one.
  6. May 20, 2023 at 2:21 PM
    alexusw
    I think you’re right. This comes from shoddy work at the dealership.
  7. May 20, 2023 at 2:28 PM
    alexusw
  8. May 20, 2023 at 2:33 PM
    Winning8
    Winning8 New Member
    Da Bay Area
    2019 MGM DC 4x4 SR5
    That’s a noob job for sure, can’t even put the radiator hose clamp right
  9. May 20, 2023 at 2:38 PM
    alexusw
    I thought so too. I’m going to have to order some new ones and find someone better than the dealership.
  10. May 20, 2023 at 2:41 PM
    Winning8
    Winning8 New Member
    Da Bay Area
    2019 MGM DC 4x4 SR5
    He should match the old groves, factory clamps are the best. Don’t need to change it just need to put it back the same way
    alexusw[OP] likes this.
  11. May 21, 2023 at 9:39 PM
    grave
    grave New Member
    SD CA
    2007 4.7 SR5 4X4
    OEM cap. i've had two aftermarket radiator caps crack on me, one on my tundra and one on my subaru. not an expensive purchase. same with gas caps.
