Are you tired of wind noise in your Tundra? Solution provided
Discussion in '3rd Gen Tundras (2022+)' started by txtundra311, May 17, 2023.
  1. May 17, 2023 at 10:10 PM
    txtundra311
    txtundra311 [OP] New Member
    Apparently Toyota decided to remove this weather stripping from 2022 tundras but they had them on Sequoia, and 2023 tundras.
    What irks me is Toyota heard their most loyal customers complain of wind noise for 20 months and pretended they didn't know the cause, when in fact they had the missing part number all along. If this missing weatherstrip in fact fixes the wind noise, they need to recall all 2022 tundras and install this piece for their customers at no charge. This is pathetic that a youtuber has to investigate and provide a solution while we still wait on toyota.
    I'm sure toyota is saying, oh just buy a new 2023 tundra, the wind issues are fixed on those models, what a bunch of low life degenerates car dealers and manufacturers have become.
    Video and part numbers below:
    Driver side weatherstrip : 67866-0C040
    Pass side weatherstrip: 67865-0C040
    https://www.youtube.com/watch?v=60Ygbwhmzsk
    Selene, CycoMike, curryca1 and 13 others like this.
  2. May 17, 2023 at 10:38 PM
    Fxclm5
    Fxclm5 New Member
    Hope they do a recall for 2022
    Here I was thinking its the shit poor quality of the adhesive on my seals themselves around the doors, I still want to show pics of my 9 yr old and 13 yr old camry window/door seals vs my new tundra.
    Not missing a entire trim piece that wedges the main door seam :boink:.
    txtundra311[OP] likes this.
  3. May 17, 2023 at 10:39 PM
    topdec
    topdec New Member
    AWD Sprinter, 2023 4R ORP, 2 3rd gen Tundras - sold
    Agreed. Seems like a deliberate action to leave them out for whatever reason. Toyota needs to get these weatherstripping retrofitted on the 22s.
  4. May 17, 2023 at 10:47 PM
    SC4333
    SC4333 New Member
    Grant
    2022 Tundra Limited TRD OR 4x4
    I just went out and verified that my June 2022 production Limited does indeed have the “missing” seals. Here’s the catch - I had a tremendous amount of wind noise. It took sealing the windshield which has multiple air leaks from poor initial seal, and adding 3M automotive weather stripping adhesive to the the window seals that leaked like a sieve. It was a real pain in the add and tested my sanity, but I just about eliminated the wind noise at this point. None the less, this is unacceptable with a brand new vehicle that cost as much as they do.
    Taikowaza likes this.
  5. May 18, 2023 at 2:02 AM
    Taikowaza
    Taikowaza New Member
    I have significant wind noise on my passenger side (22 TRD OR). For those who have had this addressed at the dealership can you LMK what service they provided (did they add the weatherstrips you mention here TXTundra?)
  6. May 18, 2023 at 3:29 AM
    MetalManEd
    MetalManEd New Member
    Just went out and looked at my Limited I picked up last Thursday and it indeed has these on it. I drove it home 650 miles and didn’t have any wind noise
    pwpblue and Mattedfred like this.
  7. May 18, 2023 at 5:15 AM
    Alex261
    Alex261 New Member
    Alex
    Boston, Ma
    2024 Tundra Platinum LR
    My June 22 build Platinum has the seals. I don’t have wind noise but I did have a whistling noise coming from my mirrors around 30 mph. I was able to pinpoint where it was coming from and fixed it myself.
    ryanwgregg and Mattedfred like this.
  8. May 18, 2023 at 6:02 AM
    Fatone
    Fatone New Member
    2022 Tundra TRD Sport Premium
    My 22 does not have excessive wind noise either. A very slight one around 80 on the expressway in windy conditions that is consistent with other tall vehicles I have owned. So the model or root cause seems still be an open ? Seems like a large company with a wind tunnel could narrow it down one would think.
  9. May 18, 2023 at 6:16 AM
    DMC11
    DMC11 New Member
    22 Tundra LR Limited OR
    My 2022 Limited OR built in Jan 2022 HAS these “missing” seals. Wind noise is the worst of any vehicle I’ve owned. Dealer has replaced the window runs(some twice) with no improvement.
    Folding in my mirrors eliminates the slight whistle I get on the passenger side. Wind noise still persists.
  10. May 18, 2023 at 6:24 AM
    topdec
    topdec New Member
    Can you share what the root cause of the wind noise was, and how you fixed it?
  11. May 18, 2023 at 6:30 AM
    superfluous
    superfluous 2023 Tundra SR CM 4X4
    metro Detroit, Michigan
    2023 Tundra SR Crew Max 4x4, and I have no seals. Also, I don't get heavy deep wind noise, only higher pitch, I don't think from this area of the door
  12. May 18, 2023 at 6:33 AM
    devron11
    devron11 New Member
    Ron
    Denver
    My SR5 Double Cab does not have these seals and I do have a mild amount of wind noise above 30 MPH. Do you have wind noise ? Did your vehicle already have the seals ? Did you add them yourself ? Is the noise gone or not ? TIA.
  13. May 18, 2023 at 6:36 AM
    Alex261
    Alex261 New Member
    Alex
    Boston, Ma
    Yes I did put a post out there somewhere but mine was from the spot where the mirrors pivot. There are plastic “pads” on the mirror and on the base. They are a little raised to the touch and a little jagged. I used clear hockey tape and carefully covered those pads up so there is no lip. It instantly solved my problem. Clear hockey tape is thin and very pliable. It worked like a charm. It took a lot of trial and error but it was easy to finally pinpoint because of the low speed mine happens at. I think this is why when most people folded the mirrors in the noise went away.
    Mattedfred and ryanwgregg like this.
  14. May 18, 2023 at 6:48 AM
    topdec
    topdec New Member
    Thanks. I found and liked your post.
    https://www.tundras.com/threads/wind-noise-concern.98646/page-14#post-3147702
    ryanwgregg likes this.
  15. May 18, 2023 at 7:03 AM
    topdec
    topdec New Member
    It doesn't seem like the parts involved should be model-specific, regardless of whether or not there is wind noise.
    We're all passionate about our trucks. That's why we are on this forum. If Toyota does not retrofit the parts, I bet most of those who come across the information that are missing said parts will end up spending the $80 to get them.
    DFS likes this.
  16. May 18, 2023 at 7:04 AM
    riotkayak284
    riotkayak284 New Member
    2023 SR5 4x4 and I have no seals described above. Actually have very little wind noise either.
  17. May 18, 2023 at 7:14 AM
    topdec
    topdec New Member
    I get what you mean. I was thinking the same, but in the end my logic is that this is not a direct comparison since we're talking about features vs. just basic parts.
  18. May 18, 2023 at 7:26 AM
    taschmidt86
    taschmidt86 New Member
    2022 Tundra 1794 W/ TRD Package
    None
    This is not missing on my 2022 1794. So we can dispel the theory that no 2022 came from the factory with it. But I appreciate that you took the time to find out the fix because it definitely prompted me to check and see if mine had it.
  19. May 18, 2023 at 7:53 AM
    topdec
    topdec New Member
    I think we'll need to agree-to-disagree on this topic 'cause I'm taking the side of the consumer.
    DIYReid, DFS and (deleted member) like this.
  20. May 18, 2023 at 8:01 AM
    korslite
    korslite New Member
    Justin
    Bellingham, WA
    2022 SR5 TRD OR 6.5' Bed
    Just spent the $80. It certainly can't hurt to have them vs not...
  21. May 18, 2023 at 8:08 AM
    Breathing Borla
    Northern Illinois
    my recent build 2023 platinum has these FWIW
  22. May 18, 2023 at 8:32 AM
    FLYH2O
    FLYH2O Earth First. We will log the other planets later.
    British Columbia , Canada.
    2023 Limited Double Cab TRD Off Road
    2/1 lift, Bedrug, Leer 180 cap, BFG At 285/65/18
    My 2023 has no front door seal. Mine is a Limited
  23. May 18, 2023 at 8:39 AM
    Breathing Borla
    Northern Illinois
    maybe its just a higher trim thing and not a year thing, kinda like the acoustic glass
  24. May 18, 2023 at 8:53 AM
    DFS
    DFS New Member
    2022 Capstone Tundra
    Leaving these door seals off any trim is asinine, given the base price of any trim of new Tundra they should be given adequate noise reduction parts to mitigate (such door seals) as a standard option on all trucks, it's not a Tacoma.
  25. May 18, 2023 at 9:11 AM
    Tundrafarm
    Tundrafarm New Member
    22 hybrid limited 4x4
    22 limited HV build june 2022 I do have the seals, dealer replaced window seals 2 times still have light wind noise.
  26. May 18, 2023 at 7:34 PM
    PBNB
    PBNB Needy
    Peter
    Vancouver, BC
    2023 Z71 3500 HD
    Lots of stuff!
    I have them on my 22 Limited (sept 22 build date).
    I haven’t noticed much if any wind noise.
  27. May 18, 2023 at 8:10 PM
    Jkwolfe09
    Jkwolfe09 New Member
    Jerren
    Lol I used to drive a jeep y’all have no clue about wind noise
  28. Oct 26, 2023 at 3:01 PM
    Markysharky
    Markysharky New Member
    I got a November 2022 build eary 2023 base model. Bad wind noise around window-mirror area. Tried in the window jam window visors to see if a tighter fit would quiet it down. To no avail it didn’t work. I just ordered these door seals. Have a whistle noise that gets much worse with a slight cross breeze. Audible above 50mph. Definitely annoying. Hope this fix’s it.
  29. Oct 26, 2023 at 5:30 PM
    Willard
    Willard New Member
    2024 F250
    You guys with wind noise issues should really try the painters tape trick. Tape off one gap at a time on the outside of the truck, go a mile on the freeway to test it, then exit, remove and apply new tape to a different gap, and so forth.
    I did this to narrow down a whistle on my 2020. Taped the perimeter of the windshield, then around the entire door panel, and finally around the window which was the issue.
    earlwright239 likes this.
  30. Oct 27, 2023 at 12:27 AM
    Kap1
    Kap1 New Member
    San Francisco, CA
    Did that... Dealer replaced driver side window twice within half year to fix the whistling...
    No more whistling sounds but still some wind noise can be heard. I test drove 24 platinum and that thing was about 15-20% quieter and no wind noise heard at all....
    So, it's better yes... But we can't them make our 2022 and some early 2023s as good as it should be
