Auto-high beams, 21 mph threshold
Discussion in '2.5 Gen Tundras (2014-2021)' started by PA452, Oct 2, 2018.
  1. Oct 2, 2018 at 12:06 PM
    PA452
    PA452 [OP] New Member
    2021 Tundra SR5 CM TRD O/R
    Anyone know if it's possible to set the truck so it doesn't turn off the high beams if driving under 21 mph with the auto high beam feature engaged?
    Thanks
  2. Oct 2, 2018 at 2:24 PM
    Bergmen
    Bergmen New Member
    Ukiah, California
    2018 Blazing Blue Pearl DC 4X2 SR5
    If I need high beams below 21 mph I just switch off the auto high beam function. Eezee peezee. I do this when I drive down our 100 yard driveway in the dead of night.
  3. Oct 2, 2018 at 2:40 PM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    Auto high beams? Must be a newer feature 'cause I don't have that on my '16 limited.
    15whtrd likes this.
  4. Oct 2, 2018 at 2:42 PM
    PA452
    On my new '18. Never thought I'd really care about that feature but I actually like it a lot. On smaller two-lane roads in rural areas it works great.
    Boerseun likes this.
  5. Oct 2, 2018 at 2:43 PM
    PA452
    That's what I do now but sometimes I'm back and forth on back roads going slower and faster, it gets annoying. Great feature otherwise.
  6. Oct 2, 2018 at 2:49 PM
    Vizsla
    Vizsla ☠️☠️☠️
    There is no way around the mph cut off. The sensitivity can be reduced, but it resets to default when the vehicle shuts off.
  7. Oct 2, 2018 at 2:56 PM
    Bergmen
    Bergmen New Member
    Ukiah, California
    It's an interesting feature and I use it sometimes but not nearly as much as I thought I would. Biggest problem for me is it waits until it sees oncoming headlights before switching to low beams. That means the oncoming driver's eyes get hit with my high beams until their headlights come into view. Also, it gets fooled sometimes with high reflective road signs or bright street lamps if they get into line-of-sight (hilly country). I fond I over-ride it very often and just shut it off.
  8. Oct 2, 2018 at 6:24 PM
    netranger6
    netranger6 New Member
    Jeremy
    2021 Crewmax. 4x4, SR5, Blacked Out package
    None. Keeping this one stock.
    Where is sensitivity adjustment.
  9. Oct 2, 2018 at 6:31 PM
    Vizsla
    Vizsla ☠️☠️☠️
    silverhack likes this.
  10. Oct 3, 2018 at 4:41 PM
    netranger6
    Jeremy
    Huh. Like a cheat code. Sweet
