Auxiliary fuel tank/cell
Discussion in '2nd Gen Tundras (2007-2013)' started by Will mic, Nov 20, 2023.
  1. Nov 20, 2023 at 11:10 AM
    Will mic
    Will mic [OP] New Member
    Will
    08 tundra 5.7
    I have 2 08 tundra’s 1 is a limited crew cab other is SR5 extra cab.
    I’m looking for information for an auxiliary fuel tank/cell to get more range than the oem 26.4 gallon tank can.
    My buddy has a 17 tundra and it came with the 36.4 gallon tank.
    What have any of you come up with?
  2. Nov 21, 2023 at 5:32 AM
    PhotoNerd
    PhotoNerd New Member
    Tony
    Waterford, CT
    2008 Salsa Red Tundra DC SR5 4x4
    Chrome delete, Sequioa grill, bed lights, LED + head, fog & tail lights, Dynamat throughout, front & rear cameras, Pheonix PX6 13" head unit, 8" subwoofer, JBL speaker upgrades, tonneau cover, custom shifter, steering wheel cover
    PermaFrostTRD and Mike59 like this.
  3. Nov 21, 2023 at 8:59 AM
    Will mic
    Will
    08 tundra 5.7
    Really looking for an auxiliary tank to drain into the OEM 26.4 gallon tank or a 36.4 gallon to replace the small tank with.
  4. Nov 21, 2023 at 9:28 AM
    PermaFrostTRD
    Northern NY
    @PhotoNerd linked you directly to a "replacement" tank that would solve your issue. Likewise, an additional 2 seconds on transfer flow's website will yield several "auxiliary" tank options to choose from.
    Also, your "buddy" has a 38gal tank. Toyota does not manufacture a 36.4gal tank for these trucks.
  5. Nov 21, 2023 at 9:30 AM
    VWTim
    VWTim Mid-Travel Crew
    Corvallis, OR
    There are good write ups on what it takes to swap in the 38gal in here, do a search and see if it's something you want to tackle.
  6. Nov 22, 2023 at 7:39 AM
    Will mic
    Will
    08 tundra 5.7
    I’m leaning hard to the 38gallon Toyota tank, seems the most cost effect
  7. Nov 22, 2023 at 8:00 AM
    PermaFrostTRD
    Northern NY
    OEM 38 gal used to be costlier (when the transfer flow was like $1600-1700). There are additional parts to source which contribute to that. Check out some of the write-ups. If you can find one off a wrecked/pick-n-pull then you'd be in better shape cost-wise.
  8. Nov 22, 2023 at 1:37 PM
    DSMTundra
    DSMTundra New Member
    2008 Tundra Limited
    I have the transferflow tank in my 08 and it is well worth the money. Can go close to 250 miles before filling up pulling our fifth wheel. My limiting factor is how long I can sit before wanting to stop. Before I got the transferflow tank I researched adding a secondary tank and found out it is a lot more work doing it correct in a gas truck then a diesel. Aux Gas tank have different standards and cannot be gravity feed if done right. I also looked at getting a larger factory tank but it seems it would cost about the same as the transferflow. Hope this helps.
