Avg Life of Bilstein Shocks
Discussion in 'Suspension' started by Borgunit, Feb 12, 2022.
  1. Feb 12, 2022 at 4:21 PM
    Borgunit
    Borgunit [OP] New Member
    JR
    Ohio
    2013 Black Rock Warrior
    What would be the average life of factory bilstein shocks? My 2013 Rock Warrior came with. Also. Is there true tale signs they need replaced? Thanks for any replies.
  2. Feb 12, 2022 at 4:34 PM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Depends upon how you use the truck.
    If they're leaking, that's a pretty obvious.
  3. Feb 12, 2022 at 4:36 PM
    Kanobi13
    Kanobi13 New Member
    I think most only last a few k as they needed to be upgraded lol how many miles?
  4. Feb 12, 2022 at 4:48 PM
    WBW
    WBW Resident lurker
    Bruce
    Surface of the Sun - AZ
    2015 CM Tundra SR5 2WD
    At 45,650 miles my 2015 rear Bilstein shocks blew a seal and leaked out the oil. I feel that I may have shortened their life expectancy because I tow a rather heavy trailer with a 940 pound tongue weight when fully loaded. The Bilsteins are more of an off road tuned shock and less load carrying shock. Rapid compression and rebound strokes while lightly loaded versus heavy load management with large but slower compression and rebound strokes. Just a different purpose shock.
    I replaced the rear shocks with Monroe shocks. I've been happy with them so far both empty and loaded.
  5. Feb 12, 2022 at 5:14 PM
    Borgunit
    JR
    Ohio
    Not leaking and I am at 159K miles. Picked up this truck in September and was wondering if I am jusr paranoid r need to think about it. It was a company work truck. Not much towing but carried supplies and trash in bed.
    Peeeheeuuu likes this.
  6. Feb 12, 2022 at 5:28 PM
    Factory shocks are usually shot by 50k miles if not way before then. Some get longer depending on use.
    Signs shocks are shot:
    tire wear
    Bouncing after a bump.
    Poor handling/braking.
    Take a shock off and see if it still has a N2 charge. A lot of times the shock will stay compressed instead of extending back out.
    snivilous, AZBoatHauler and WBW like this.
  7. Feb 14, 2022 at 4:03 PM
    Borgunit
    JR
    Ohio
    Not seeing or experiencing any of the issues stated. I will just go with them until I find a great deal on a set. Thanks for replying.
  8. Feb 14, 2022 at 4:23 PM
    ATV25
    ATV25 Young at heart
    Terry
    Redding, CA
    2019 Platinum
    5100s, Icon Rebounds, Maxxis Razors
    I had a 2001 with the factory TRD Bilsteins, lasted 112k miles.
  9. Feb 14, 2022 at 4:49 PM
    Borgunit
    JR
    Ohio
    Makes me wonder if these have been replaced once already.
  10. Feb 15, 2022 at 10:38 AM
    frichco228
    frichco228 Valued Member
    2016 Crewmax 4WD, TRD Offroad
    The stock black tundra shocks are usually done by 50k miles. The OR package shocks and Sport Package shocks (yellow and blue, red and blue) fare better and will last 60-80k miles. Of course all that depends on use. Frequent off-roading will reduce the life as will heavy loads/towing.
    Shocks should be replaced when they lose their dampening ability. You will notice that by feeling more road vibrations, more harsh feeling on bumps, looser handling, wandering and of course if the seals fail and the shock is leaking- regardless of miles a leaking shock should be replaced.
  11. Feb 15, 2022 at 10:49 AM
    MadMaxCanon
    MadMaxCanon New Member
    '21 CM SR5 4x4 6 seater
    Too many, but not enough....
    If you brake normal, not slam on the brakes, and the nose of the truck takes a noticeable dive, thats a good sign.
  12. Feb 16, 2022 at 4:14 PM
    Borgunit
    JR
    Ohio
    Thanks for great tips. Appreciate the replies.
