AVS Bug Deflector 2
Discussion in '3rd Gen Tundras (2022+)' started by Newtonfb, Sep 19, 2023.
  1. Sep 19, 2023 at 6:51 AM
    Newtonfb
    Newtonfb [OP] New Member
    Has anyone installed this? I just got this yesterday, but it came with no mounting screws/clips or holes, just adhesive to stick on the hood. I'm not sure how I feel about just sticking it on the hood. Every bug deflector I've had in the past, has clipped on underneath the hood. Anyone install this?
  2. Sep 19, 2023 at 6:54 AM
    TundraWorkHorse
    TundraWorkHorse New Member
    2023 Toyota Tundra Platinum
    Just ordered mine . Not sure
  3. Sep 19, 2023 at 5:20 PM
    machd08
    machd08 New Member
    CLARENCE
    Sumter, South Carolina
    2025 Land Cruiser/Land Cruiser
    I put one on about a month ago, stuck on using the adhesive tape.
  4. Sep 20, 2023 at 6:55 AM
    Newtonfb
    So it just stuck right on top of the hood? Hows it working? Vibration at all?
  5. Sep 20, 2023 at 11:00 AM
    machd08
    machd08 New Member
    CLARENCE
    Yelp right on top, it is easier if you have someone helping. No vibration
  6. Sep 20, 2023 at 12:49 PM
    RatPanda
    RatPanda New Member
    Ryan
    2022 Tundra 4x4 CrewMax 5.5
    I’ve got one. Looks sharp, no vibration, and keeps the paint from chipping. Very happy with it. Had it about a year.
  7. Sep 20, 2023 at 12:57 PM
    RatPanda
    RatPanda New Member
    Ryan
    wtrainer likes this.
  8. Sep 20, 2023 at 4:05 PM
    machd08
    machd08 New Member
    CLARENCE
    Here is mine works good and looks good
  9. Sep 20, 2023 at 4:23 PM
    Blufin
    Blufin Seasoned member
    Bob
    23 Capstone
    Looks slick man!
    Any chance you could take an angled pic,say stand by one of the front quarter panels and take a pic looking from the hood perspective to the back of it the deflector.
    And is there any gap on the transition.
  10. Sep 20, 2023 at 4:26 PM
    machd08
    machd08 New Member
    CLARENCE
    Sure can, will be tomorrow
  11. Sep 20, 2023 at 4:28 PM
    Blufin
    Bob
    23 Capstone
    Thanks Dude much appreciated
  12. Sep 21, 2023 at 8:39 AM
    machd08
    machd08 New Member
    CLARENCE
    Hope this what you were looking for
    Tundrastruck91 likes this.
  13. Sep 22, 2023 at 1:18 AM
    Blufin
    Bob
    23 Capstone
    Nice! Thanks Man I appreciate your time for doing that,so it's pretty much peel and play huh...
    The glossy looks slick for sure.
    machd08 likes this.
  14. Sep 22, 2023 at 9:07 AM
    Ransom122
    Ransom122 New Member
    22 Tundra SR5
    Are these the Aeroshields y’all have installed or the bugflector?
  15. Sep 22, 2023 at 10:28 AM
    TRDoffroadPRO
    TRDoffroadPRO New Member
    2023 Hybrid CM Limited TRD OFR
    yep, I have one and have had it since the first week I have owned the truck. They work good and if you want to remove it then a hairdryer, fishing line or dental floss and some goo off can take it off in around 15 minutes
  16. Sep 23, 2023 at 1:10 PM
    Jim2023
    Jim2023 New Member
    2023 Limited Crew Max
    Retrax bed cover
    Does the whole deflector sit tight to the hood ?
    No gaps for dirt etc to get in ?
  17. Sep 23, 2023 at 5:20 PM
    TRDoffroadPRO
    Yes it sits flush but had double sided 3M tape up high and low so it is an air tight seal. Rain and dirt does not get in.
  18. Sep 24, 2023 at 2:40 AM
    Jim2023
    Jim2023 New Member
    Retrax bed cover
    Thanks, that was my concern that a small gap would let dirt in with no way to clean it.
    Time to order one !
  19. Oct 2, 2023 at 2:02 PM
    TundraWorkHorse
    Mine had alot of hardware from 6 c clamp hood clips to alot of screw plus 2 sided tape . This is the Toyota part for the Tundra so im not sure what you guys got that only uses 2 sides tape
  20. Nov 27, 2023 at 3:01 PM
    TRDoffroadPRO
    Autoventshade is the maker with double sided tape. Toyota uses something different which looks the same as what you have except the avs aeorskin attachs directly to the hood without any of those screw clip things showing.
    Guess it depends on what you want,clean look with double sided tape or screw things showing through the shield?
  21. Nov 27, 2023 at 7:29 PM
    Rocco1522
    Rocco1522 New Member
    NWFLATundra likes this.
  22. Nov 28, 2023 at 10:07 AM
    BlueCrushSC16
    BlueCrushSC16 New Member
    Charleston, SC
    I ordered one a month back. I haven't installed it because I remembered I have the clear PPF on. I'm worried the bug deflector would heat up and cause the PPF and/ or the bug deflector not to stick well to the hood. Thoughts...???
