Axle nut size?
Discussion in '1st Gen Tundras (2000-2006)' started by ajdahun, May 11, 2023.
  1. May 11, 2023 at 5:44 PM
    ajdahun
    ajdahun [OP] New Member
    AJ
    02 Tundra SR5 SC 4.7 4WD
    SS Long tube headers, magnaflow. KN Air Filter
    So I need to redo outer cv boot, my 36mm socket is way too small. Google tells me it’s 35mm. My cheap pos plastic caliper measures around 40mm. So what size socket do I need?
  2. May 11, 2023 at 6:37 PM
    scooterprint
    scooterprint Idiot with a wrench
    Jeremy
    Conway, AR
    ‘04 DC 4x4
    Bone stock
    Sounds like it has an aftermarket CV and nut. OE is 35mm.
    FrenchToasty and shifty` like this.
  3. May 11, 2023 at 6:51 PM
    OEM typically has pink band like what you'll see here: https://www.tundras.com/threads/do-these-look-like-oem-cvs.109810/
    If you need to re-order OEM, they're way more bulletproof than aftermarket. Reman part number is 43430-0C010-84. Sometimes you can get them as cheap as $125 at the Toyota Parts site, on pickup from a local dealership.
    Sunnier likes this.
  4. May 11, 2023 at 9:40 PM
    ajdahun
    AJ
    Just have a boot to slap onto axle, not swapping axle
  5. May 12, 2023 at 5:43 AM
    Right, but identifying if your axle is OEM would help answer why you're seeing a different fastener size.
  6. May 12, 2023 at 6:17 AM
    ajdahun
    AJ
    Agreed, priority is to redo boot, no problem with axle, aftermarket or not. Probably going to drive it to auto parts/tool store and pop off dust shield in parking lot to size the socket needed
  7. May 12, 2023 at 11:50 AM
    TX-TRD1stGEN
    TX-TRD1stGEN Privileged
    Seth
    South East Texas
    2000 Tundra 4x4
    I bought an axle nut socket kit at harbor freight. Has several sizes
    bmf4069, ajdahun[OP] and scooterprint like this.
  8. May 15, 2023 at 7:30 AM
    metalpete
    metalpete New Member
    ID
    2001 Tundra 4.7 4x4 SR5
    Toytech 2.0 Coilovers Camburg UCA's JBA headers Dynomax cat-back exhaust 90-221HD Leafs
    When I did mine it was a 41MM and almost impossible to find. Just get it from the Amazonians.
    Item # 423841
    FrenchToasty and ajdahun[OP] like this.
  9. May 16, 2023 at 6:26 PM
    ajdahun
    AJ
    Bought a big socket set from HF so I’ll be putting on new boot this weekend . Thanks y’all
    TX-TRD1stGEN and bmf4069 like this.
  10. May 17, 2023 at 6:59 AM
    metalpete
    ID
    Good luck! I would order that 41mm too, just to be safe. Not sure which set you ordered, but I walked through HF for an or so and none of their kits have the right size. I tried 38mm-40mm, all too small.
    When you do get the right socket and get ready to do the job, make it easy on yourself. Take the center cap off the wheel and break the nut loose with the truck on the ground. :thumbsup:
  11. May 17, 2023 at 1:12 PM
    ajdahun
    AJ
    Yeah, the gal at the register helped me remove cardboard/plastic n I popped it open to carry a couple sockets out to the truck in parking lot to size em. When I saw it was a 41mm I went back in n bought it. Yeah I’ll be leaving it on its weight. More concerned bout the cheapness of the set, specifically the breaker bar.
    JasonC. likes this.
  12. May 17, 2023 at 1:24 PM
    metalpete
    ID
    Nice, sounds like you have a more laid back HF than I do!
    I bet they will be alright. At least you aren't buying jack stands or a spring compressor.
