Back Revolver X4S or Peragon Tonneau Cover
Discussion in 'Tonneau Covers, Caps and Shells' started by TruPatriot, Apr 17, 2021.
  1. Apr 17, 2021 at 3:36 PM
    TruPatriot
    TruPatriot [OP] New Member
    Lee
    Northeast Texas
    2020 TRD Pro MGM Mall Crawler & Trail Riding Queen
    I’ve narrowed it down to the above 2 covers. What I would like to know is how they are holding up after a year and more later. If you happen to be the owner of either, please share your experience.
  2. Apr 17, 2021 at 4:52 PM
    RickPlatinum2020
    RickPlatinum2020 New Member
    Rick
    Eastern PA
    2020 Barcelona Red Platinum 4x4
    Front and rear TRD sway bars, 18" TRD OR wheels. ESP underseat storage
    The revolver x4s just came out, I installed it last week. Not sure all the improvements from the x4, I know the aluminum slats are now black and their are wing nuts to attach to rails. I assume the material of the cover itself is the same or similar to the x4...
    Maybe someone can talk about the condition after a year with that?
    619Tundra likes this.
  3. Apr 17, 2021 at 4:58 PM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    The peragon requires removal of the deck rails. Thats a killing point imo
    IsaiahCanada and Saltyhero13 like this.
  4. Apr 17, 2021 at 5:26 PM
    RickPlatinum2020
    Rick
    Eastern PA
    The x4s brackets have threaded holes to remount the deck rails after cover rails are installed. Moved the rails down about an inch or two.
  5. Apr 17, 2021 at 9:33 PM
    TruPatriot
    Lee
    Northeast Texas
    What are your thoughts regarding the X4S? Does it look like it’ll last for many years without the warping, tearing buckling, etc?
  6. Apr 18, 2021 at 3:31 AM
    Njmike13
    Njmike13 New Member
    Hunterdon county, NJ
    2021 PRO Lunar Rock
    I've had the revolver X4 for a few years now. Still looks good no issues with the cover bending or warping. Unfortunately my truck lives outside year round and even with snow load no issues. One thing I can tell you is in the winter it can get stiff and be kinda a pain to roll up. As fast as water getting in it's not 100% but it better than any other cover I've had. I would buy it again if I got a new truck.
    Gunship Guy likes this.
  7. Apr 18, 2021 at 5:13 AM
    TruPatriot
    Lee
    Northeast Texas
    Thank you for sharing!
  8. Apr 18, 2021 at 5:27 AM
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
    This is not the case. I installed mine with modified mounting brackets that slid into the bed rails. I found that trick on this site.
    HOWEVER, if you do get the Peragon, make sure to keep all the packaging to take advantage of their 100 day return policy. I found it to be flimsy and sent it back because I didn't think it would last a year, much less 10.
  9. Apr 18, 2021 at 5:40 AM
    TruPatriot
    Lee
    Northeast Texas
    I’m interested in the modified mounting brackets. Can you share that link? What tonneau did you go with after sending back the Peragon?
  10. Apr 18, 2021 at 7:32 AM
    RickPlatinum2020
    Rick
    Eastern PA
    Seems to be good quality, time will tell. I like that it is very low profile, decently waterproof, just tailgate corners leak some water. See what happens after a few seasons.
  11. Apr 18, 2021 at 8:16 AM
    TrooperDC4x4
    TrooperDC4x4 New Member
    Nor Cal
    2017 BBP Double Cab 5.7L TRD 4X4 OR
    Bilstein 5100 2.5", 1.5"
    https://www.youtube.com/watch?v=_3stVjQ0kWI
    I believe this video has the bracket modification. I have the Peragon and kept my bed rails, had to buy smaller plastic handle lock bolts off of Amazon. Mine has been installed for over a year, I use it every day as I carry tools for work that require daily access. Even had lumber fall off my rack onto the cover with no damage. If I had to do it again I would still buy the Peragon, has been great for my needs.
    Hbjeff likes this.
  12. Apr 18, 2021 at 8:25 AM
    RobertD
    Robert
    DFW, Texas
    When I learned about the paragon inwas initially excited but the more I've learned and more reviews I've seen, I wouldn't waste my money on them. A few members have bought and returned due to poor quality or it not functioning correctly. I know there are a few that like it but it seems like a smaller number.
    For me, the biggest negative is that if you load your bed all the way up with your cover covering the bed, you then have no way to retract the cover to get things out of the bed.... for the cost of the peragon, I think you have better options out there.
    Just do your research and good luck :thumbsup:
  13. Apr 18, 2021 at 10:00 AM
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
    Here is the link to what I used as an example. I just used my bench grinder to modify the clamps.
    https://www.tundras.com/threads/trd-pro-tonneau-recommendation.67380/#post-1751341
    I ended up going with the Armor Flex. I like it ok, but I wish I had know then that the Diamond cover came in black. I would have gotten that one instead.
  14. Apr 22, 2021 at 11:46 AM
    TruPatriot
    Lee
    Northeast Texas
    After much deliberation, I decided to go with a Lomax Hard Tri-Fold Cover. Ordered from autoanything.com
  15. Apr 24, 2021 at 2:26 PM
    TruPatriot
    Lee
    Northeast Texas
    Just installed Lomax Hard Tri-Fold Cover and just came out of car wash with no problems!
    Bakershack likes this.
  16. Apr 24, 2021 at 3:00 PM
    TruPatriot
    Lee
    Northeast Texas
    Hbjeff likes this.
  17. Apr 27, 2021 at 2:31 PM
    peeruwp
    peeruwp New Member
    Does the Lomax require any modification or lowering of existing bed rails?
  18. Apr 28, 2021 at 3:41 AM
    TruPatriot
    Lee
    Northeast Texas
    The Lomax is a no modification install. It’s very simple and quick.
    peeruwp[QUOTED] likes this.
  19. Oct 11, 2021 at 7:54 PM
    BhamDadTundra
    BhamDadTundra New Member
    2021 MGM Tundra CM SR5
    Did you by chance shim yours per the diagram? I just got a 21 tundra and the X4s and sat a rail on the bed tonight and it looked almost perfectly flush and straight. But was wondering if these instructions were outdated (even though the X4s was released like a year ago) since the Toyota section doesn’t have anything that notes “-current”
  20. Oct 17, 2021 at 6:11 PM
    Bentarm13
    Bentarm13 New Member
    I have the Bak revolver and could not be happier. 30+ years of truck ownership, 12 different covers and I will honestly say this is the best ever. It’s expensive but that is the only negative. Install is a breeze, 99.5 waterproof, bed rails and cleats are still in use.
    STR1 likes this.
  21. Oct 18, 2021 at 6:05 AM
    BhamDadTundra
    Agreed with above for anybody looking in the future. Installed mine with no shims (see two posts above) and it was a perfect fit and lock after making sure it was straight. I had the Extang Solidfold 2.0 on my last truck, and it was great. I loved how sturdy it was, but I like that you can access more bed with this cover fully opened. It’s also easier for my wife to open. She never figured out the solidfold haha. I haven’t tested water proof ness yet, but I asked the Bak chat folks why this one doesn’t have a drain like the BakFlip MX4. Guy said I’m not really supposed to say this, but it’s definitely more water tight than the MX4 so it doesn’t need a drain. That helped sell me on choosing the X4s. Very happy so far.
    Ochoa1801 and RitcheyRch like this.
  22. Oct 18, 2021 at 6:44 AM
    cygan1008
    cygan1008 New Member
    “RIP” 2013 Tundra TRD Rock Warrior, 2018 TRD SPORT CM 4x4 SUPER WHITE Eibach Pro 2.0 275/65/20 Recon Grapplers
    I know the OP ordered something different but for anyone looking still i have had both the paragon and the x4s on tundras. I would take the x4s over paragon simply because if a box or something slides to them front of the bed you can not collapse the cover until you remove the item blocking it. I have experienced this on several occasions.
    I have found no issues with the x4s, yet. Out of all the covers I have owned this one is my favorite so far.
    STR1 likes this.
  23. Oct 18, 2021 at 7:26 PM
    BCTRD
    BCTRD New Member
    B.C.
    2021 MGM Tundra TRD Sport
    18"BBS Forged wheels, factory running boards, VLED's, Rigid Pro Led mod (D2 SAE), diff breather mod, Husky mats, DIY Cquartz UK 3.0, Husky liners, OCD organizers,
    Thinking of the same cover. Had an MX4 for almost 4yrs with no issues other than when they freeze rolling up is pretty much out of the question. What bed lights are you running?
  24. Oct 21, 2021 at 3:42 PM
    BhamDadTundra
    OEM had them install at dealership before I picked up. Figured I could tap into them if I wanted to add an LED strip or something later on! Happy with them so far.
  25. Nov 1, 2021 at 2:51 PM
    ThePolak
    ThePolak 2022 Platinum hunt/tow/haul/family ride on order!
    The Land of the Cobra Chicken
    How do you like that bed extender? Do you find you use it often?
  26. Nov 2, 2021 at 3:11 AM
    BhamDadTundra
    just got the truck a month ago so haven’t had many opportunities yet! I previously had another truck but didn’t have this on it just a cover. Saw someone on here said they did the cover/extender combo to help keep things up front of the bed and then use the Extender when needed so I thought I Would give it a try. Tonneaucovered.com had it for 240 out the door. Nice quality but had to get the spacers so it would fit with the revolver. Have seen others say it got in the way more than they used it and I could see that but it’s really easy to remove when not needed.
  27. Nov 2, 2021 at 4:41 AM
    ThePolak
    Awesome. Thanks for the feedback!
  28. Nov 2, 2021 at 5:11 AM
    BhamDadTundra
    sure thing! I am also thinking about doing this mod to it below. Seems like it could be handy. Although I had my pole saw going through the openings this weekend when I helped my parents with some tree trimming so pros and cons no doubt! Would be useful for Costco trips probably holding stuff in the front of the bed. But I also have so much more room in the crew max back seat than my previous truck that it may have been over kill. Hopefully I get some good use out of it! I plan on a lot of landscape refreshing in the spring rocks and mulch and such. Also I decided to loctite red on the above spacer assembly because the bolts started coming loose after riding around for a few weeks. This probably wouldn’t happen if you drilled into the bed, but might at least need some loctite blue if you did the no drill plate. I figured if I got a different cover down the road and can’t get it apart I’ll just get another $26 no drill plate set.
    https://youtu.be/mNaPUh-yPyo
  29. Jan 26, 2022 at 8:59 AM
    TundraFL
    TundraFL New Member
    2020 Calvary Blue Tundra SR5
    Just got my Bakflip Revolver X4S cover yesterday, and I just installed. It was super easy to install, and it works really well. Incredibly convenient...
  30. Jan 26, 2022 at 2:19 PM
    BhamDadTundra
    looks awesome! I’ve loved mine had it for three months or so. So easy to install
    TundraFL[QUOTED] likes this.
