Back up lights... which wires to splice?
Discussion in 'Lighting' started by 2020cement_tundra, Dec 28, 2020.
  1. Dec 28, 2020 at 7:40 AM
    2020cement_tundra
    2020cement_tundra [OP] New Member
    Nick
    SC
    2020 tundra
    I’m fairly good with wiring etc. just wondering if anyone had a wiring diagram or know which color wires to splice for led backup lights and where to splice. I want the lights to come on when in reverse. Some boat landings around here have zero lights. Thanks
    Tundra2 likes this.
  2. Dec 28, 2020 at 7:59 AM
    The blue reverse wire
  3. Dec 28, 2020 at 8:11 AM
    Tap into the rear of the trailer plug, center wire. Much easier.
  4. Dec 28, 2020 at 8:27 AM
    Zebruaj
    Zebruaj New Member
    MN
    08 CM SR5
    I made mine elaborate. Relay and 3 way switch. On /off/reverse trigger.
    NewImprovedRon likes this.
  5. Dec 28, 2020 at 8:57 AM
    2020cement_tundra
    Nick
    SC
    2020 tundra
    So the center wire is bright green in color I assume? And splice the ground into the ground wire on the plug? Thanks
  6. Dec 28, 2020 at 9:01 AM
    Center wire, color doesn't matter since the plug is universal for all trailers. Why run the ground that long? Just attach the ground to the nearest bolt.
  7. Dec 28, 2020 at 9:23 AM
    2020cement_tundra
    Nick
    SC
    2020 tundra
    10-4 Now I just got to find which LEDs I want I would go with the flush mount that goes in my bumper, however I believe I will get sick cutting a hole in a brand new bumper.
  8. Dec 28, 2020 at 9:52 AM
  9. Dec 28, 2020 at 10:20 AM
    2020cement_tundra
    Nick
    SC
    2020 tundra
    The cheap eBay slim bars hold up pretty well, I have a couple on my boat for 3 years now and no issues. May get a couple 7” slim bars
  10. Dec 28, 2020 at 10:40 AM
    Motor71
    Motor71 teufel hunden
    Rob
    New Jersey
    2016 tundra platinum
    TRD sway bar, matching mirror cover, 20% tint, esp aluminum box, Line-X premium, Undercover Flex tonneau cover, led interior lights, winjet smoked tail lights. Road armor rear bumper w/ road armor shackles, go rhino front bumper.
    Can I run led back up lights and a light strip off of this or you think it might suck up to much juice?
  11. Dec 28, 2020 at 10:42 AM
    Motor71
    Rob
    New Jersey
    I got this.
  12. Dec 28, 2020 at 10:49 AM
    BlueRibbon4x4
    Geno
    2015 Blue Ribbon 4x4
    Might be too much juice. LEDs don’t draw too much power, but check your amperage ratings on everything including the current reverse lights and add them up. Too much draw and you’ll just pop fuses. I’m running LED pods with reverse lights the exact way Jim posted. Everything works great, but I’m already close to max amperage- which you only want about 75% of your rated fuse. I can’t remember if the reverse light run on the same circuit as the trailer plug, but I know I accounted for it.
    Motor71[QUOTED] likes this.
  13. Dec 28, 2020 at 10:56 AM
    jr1016
    jr1016 New Member
    Ric
    Sacramento, CA
    2020 CM TRD Sport
    How about replacing the reverse bulb with some LED bulbs. I swapped mine out and it lights up my driveway when backing up.
    BlueRibbon4x4 likes this.
  14. Dec 28, 2020 at 11:03 AM
    2020cement_tundra
    Nick
    SC
    2020 tundra
    That might be an option do you have a part number?
  15. Dec 28, 2020 at 11:16 AM
    jr1016
    jr1016 New Member
    Ric
    Sacramento, CA
    2020 CM TRD Sport
    I got mine from Lasfit.com, they're still having a 15% sale til new years. You can also change the cargo lights, that should help as well.
  16. Dec 28, 2020 at 11:40 AM
    2020cement_tundra
    Nick
    SC
    2020 tundra
    What part number? Look like they have several variety’s
  17. Dec 28, 2020 at 11:53 AM
    2020cement_tundra
    Nick
    SC
    2020 tundra
    Ok I finally got someone one phone looks like 921 for cargo and 7443 for reverse
    jr1016 likes this.
  18. Dec 28, 2020 at 12:02 PM
    Stumpjumper
    Stumpjumper Not a new member
    Fate, Tx
    2017 Tundra TSS 4x4
    I have Led bulbs in reverse light sockets, 4" flush mount in bumper, Mictuning 8" single row on back of trailer, and some 12" submersible marine lights on side of trailer. No problem with amp draw. I spiced in to reverse wire behind taillight and grounded to bumper. I decided cutting plastic was easier then metal. There is really no need for a separate switch. Just turn key on and shift to reverse. The backup lights on truck do no good with my boat. That is why I have the Mictuning on trailer. My trailer has disc surge brakes so it was easy to just splice in to the backup wire on brake actuator.
  19. Dec 28, 2020 at 12:09 PM
    Motor71
    Rob
    New Jersey
    Thanks!
  20. Dec 28, 2020 at 12:12 PM
    Yes, LED'S draw very little.
  21. Apr 7, 2024 at 3:16 PM
    Gamer68
    Gamer68 New Member
    2016 Toyota Tundra limited
    2.5 front lift//Hooke Road Front Bumper w/lightbar//20" Black spoke Fuel Wheels//Weather Tech Floor mats//Black Waterproof seat covers//Hard tri-fold tonneau cover//
    Nice. Way easier to tap into the trailer plug. You are a god among men. Thansk for the tip.
  22. Apr 7, 2024 at 3:28 PM
    :hattip:
