Backflip MX4 Quality Rant!
Discussion in 'Tonneau Covers, Caps and Shells' started by Woz 23, Jan 5, 2023.
  1. Jan 5, 2023 at 6:45 AM
    Woz 23
    Woz 23 [OP] New Member
    2023 Tundra Platinum
    I have been reading these threads for weeks deciding on a new cover for the Tundra I had ordered, and when it finally arrived I decided to purchase the Bakflip MX4. Installation was fairly easy and the Youtube videos the manufacturer provided were useful. However, it quickly became very clear that the quality processes at Bakflip were lacking entirely.
    The left latch/rail that attaches to the side of the truck came bent, and had a piece of rubber seal that was cut too short in the factory, leaving an opening. The cover had an existing scratch on it, despite being packages pretty well. The end caps were also bent out of place. The foam piece that seals above the center bed rail was a very cheap, thin piece of foam that came bent and ripped and looked like it would last a few days. When it rained, the cover leaked in around 6-7 different locations into the bed of the truck.
    I called Bakflip, and their customer service representative was not great. He said they would open a claim and that their product is not intended to keep water out. I indicated that I had a similar cover with another brand on my prior truck that never leaked once.
    Take 2 - I received my replacement cover yesterday. The rails on the side came bent again despite being packaged very nicely. The rubber seals on them were also cut short and were lacking the needed length. The outside top pieces of the side rail were also deformed and bent upwards creating a big opening. When installed, you could see daylight through numerous spots from inside the bed. The actual length of the cover seemed shorter then the prior one as there were sections by the tailgate that I could see into the back. The icing on the cake was when installation was complete, I went to hook up the drain line and realized they installed two different sized pieces on the cover so the provided attachment was only compatible on one side.
    Very disappointing to see this, especially after all the positive comments and beautiful photos I had seen of them installed here! With that said, I was wondering if the other brands (Solid Fold, Toyota OEM), with similar covers are all built by the same company or if perhaps I would have better experiences with them?
    Oey12 likes this.
  2. Jan 5, 2023 at 7:56 AM
    joescho
    joescho New Member
    Joe
    Scranton,PA
    2024 Supersonic Red Platinum
    I think I have a Truxedo, and knowing me its not a super expensive one because it wouldn't bother me much if it leaked, but its proven to be a leak-proof good cover.
  3. Jan 5, 2023 at 8:08 AM
    MedCityMoto
    MedCityMoto SciTech Nerd
    2.5gen CM SR5 TRD OffRoad
    I've been wanting a Bak Revolver X4S ever since I bought my truck, not a fan of the complete lack of security that my Truxedo LoPro soft rollup provides. However, I've been steadily reading review after review that indicates Bak's service and quality has dipped tremendously since, hmmm, 2019, mystery as to why.
    I've decided to go with a Truxedo Sentry CT when the time comes. I want something with hard slats and a flush profile that also quickly unlatches from the front of the bed, giving unfettered access if I haul something larger in there. This checks all the boxes and still ranks excellently with quality. I've subsequently removed the X4S from my wishlist.
  4. Jan 5, 2023 at 8:25 AM
    memario1214
    Colton
    Missoula, MT
    '21 Limited MGM CrewMax
    On this note the "unfortunate" thing is that if the quality is slipping for BAK folks pretty much all of these bed cover companies are owned by the same outfit. RealTruck owns BAK, Extang, Retrax, Roll n Lock, Tonno Pro, Truxedo, Undercover, Gator, Et al. So I kinda figure if one's gonna suffer... That said, manufacturing for each line is scattered all over the place so there may be some separation of build quality. :notsure:
    bulldog93 likes this.
  5. Jan 5, 2023 at 8:27 AM
    DrZoidberg
    DrZoidberg New Member
    Dave
    SATX
    Tesla MYP
    Yeah my 21 f150 bak was great but my 22 tundra one had a lot of aesthetic blemishes
  6. Jan 5, 2023 at 10:06 AM
    MedCityMoto
    I can't help but suspect some of these manufacturing arms use different amounts of locally-USA sourced assembly of foreign-derived parts, and have variable levels of QA.
  7. Jan 5, 2023 at 10:13 AM
    FortyNorth
    FortyNorth New Member
    Northern ON
    2014 Tundra Super White SR5
    Interesting! Is that who makes the oem covers too? I’ve read generally positive things on them.
  8. Jan 5, 2023 at 10:26 AM
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
    I believe the OEM covers are also made by the same group. I removed my Undercover Armorflex and replaced it with a Diamondback SE, which I like MUCH better.
  9. Jan 5, 2023 at 10:36 AM
    Roctane84
    Roctane84 Tread On Them
    Louisiana
    ‘22 TRD Pro Solar Octane (SOLD)
    Bummer. Mine was fine, QC-wise, but I did waterproof the front end by the cab a little extra with silicone when installing. I just wasn’t confident in the rubber up there (TWSS).
    7 months and 16,000 miles with no issues.
  10. Jan 5, 2023 at 10:46 AM
    War Machine
    War Machine SSEM # 5 3MW
    Put mine on last week. No issues at all. This is the third one I’ve had and they do all leak some, but I’ve never really needed it to be watertight. I only need it so I can keep things locked up in the bed.
  11. Jan 17, 2023 at 3:02 PM
    TheSS712
    TheSS712 New Member
    Shayne
    2022 Army Green Tundra Limited
    If it makes you feel any better, Bakflip is sending me 3rd one on 1/24. First one was great with minimal leaking in the front corners and the tailgate(knew it would but didn't affect me) but one of the rubber hinges was defective and cut short. They sent me a new lid only... Installed it and this thing leaks quite a bit. Emailed the same thread from the previous warranty claim and some pics of the water in the bed. Now they are sending me a complete kit. Let's see if third time is the charm. Love the functionality of it and know it is not water tight so hopefully this next one will have been built a little better.
    MedCityMoto likes this.
  12. Nov 16, 2023 at 6:02 PM
    JohnDeere55
    JohnDeere55 New Member
    Sandown, NH
    2023 Tundra Limited
    It seems there are still quality control issues ... I recently took delivery of the BAKFlip MX4 and, upon unpacking, found that the cab end of both rails were bent; one down and the other up. There was no indication of damage to the packaging. Called BAK and without question they agreed to ship two replacement rails. The BAK agent seemed to not be surprised with the bent rails, as if it's a problem they're aware of.
  13. Nov 24, 2023 at 7:23 AM
    Redseal199
    Redseal199 New Member
    2021 CM NightShade
    My Truxedo Sentry CT should be here Monday 11/27/23. Sure hope it comes in decent shape as I have spent way too much time down the rabbit hole on what would be the best bang for the $$$$
  14. Nov 24, 2023 at 7:45 AM
    MedCityMoto
    This is the one I've pretty much settled on, and got a quote from TonneauCovered.com for $859 / shipped, will probably buy in the spring! Let me know how you like yours!
  15. Nov 24, 2023 at 9:00 AM
    Redseal199
    2021 CM NightShade
    That's a way better deal than what I found! Best I found it for was $1049.00 shipped.
  16. Nov 24, 2023 at 1:52 PM
    MedCityMoto
    To even get a quote, one has to email Shaun there, as their site doesn't advertise the prices outright - but that was also like 6 months ago and might not still be that low anymore!
  17. Dec 5, 2023 at 12:32 PM
    Redseal199
    2021 CM NightShade
    Finally got the chance to install this Sunday. Install is beyond easy! Quality is top notch. With that said, I have a soon to be son driving in Feb so I normally drive his little car to and from work so the truck sits in the garage. We are taking the kids skiing in January and will be driving the truck Mo so i'll let you know how it does keeping the weather out of the bed from our luggage then lol.
    MedCityMoto[QUOTED] likes this.
  18. Dec 9, 2023 at 6:55 AM
    JohnWhicker
    JohnWhicker New Member
    My brand new MX4 was leaking in the middle somewhere. Warranty was an absolute PAIN in the arse to deal with. They send me a lid replacement and just had it installed. Will see how this goes, else I till Feb 1st for a full refund and send it back.
  19. Dec 9, 2023 at 7:08 AM
    JohnDeere55
    Sandown, NH
    2023 Tundra Limited
    While I'm not trying to defend BAK, no where (that I could find) do they state that the MX4 is waterproof. What they state is, "Rain or shine, the MX4 provides confident cargo storage that’s complete with dual drain tubes to divert water away from the truck bed, as well as full perimeter seals to help protect against water intrusion." I had my own quality issue in that the cab end of the both of the side rails were bent, which BAK quickly replaced without question. Anyway, glad they honored your warranty claim.
  20. Dec 17, 2023 at 9:55 AM
    DeepH2O
    DeepH2O New Member
    Ryan
    Mississippi
    6” RC lift 37x12.50x20 Tires 20x10 Fuel Wheels BakFlip MX4 bed cover Westin Outlaw Steps JB4 Tuner TRD Shift Knob
    I’ve had nothing but great customer service from Bak. I’ve had 4 of their covers, and numerous times needed parts and they’ve sent them free of charge and no questions asked!
  21. Dec 17, 2023 at 10:51 AM
    Buster1
    Buster1 New Member
    Oregon
    2019 Cavalry Blue Limited TRD Off Road Double Cab
    Anyone who thinks a Bak MX4 is completely waterproof is living in a fantasy world. They don't state they're waterproof and by simply looking at them it's clear they won't be waterproof.
    And as far as securing precious cargo, it'd take someone 30 seconds with a screwdriver to breach your fortress. They'll keep honest people out and prying eyes from seeing what's in your bed but that's about it.
    JohnDeere55 likes this.
  22. Dec 17, 2023 at 6:21 PM
    JohnDeere55
    Sandown, NH
    2023 Tundra Limited
    To my knowledge, BAK doesn't state that the MX4 cover is waterproof ... What they say is, "Rain or shine, the MX4 provides confident cargo storage that’s complete with dual drain tubes to divert water away from the truck bed, as well as full perimeter seals to help protect against water intrusion." I installed the MX4 on my Tundra a couple of weeks ago, and I like it, a lot. I didn't bother installing the drain tubes because I don't particularly care if a little water gets into the bed area. If waterproof is what people want, they need to be looking at another product.
  23. Dec 17, 2023 at 6:35 PM
    Willard
    Willard New Member
    2024 F250
    Bakflip sucks. Junk product, customer service to match. Somewhere on this forum is my whole story dealing with them on an mx4. Avoid at all costs.
  24. Dec 17, 2023 at 6:57 PM
    JohnDeere55
    Sandown, NH
    2023 Tundra Limited
    Not based on my experience, both with the product itself that I installed on my Tundra a couple of weeks ago, and Customer Service who quickly resolved an issue I had with the rails that were damaged in transit.
  25. Jan 4, 2024 at 11:40 AM
    eharri3
    eharri3 New Member
    2021 F150 Powerboost
    I think flush mount covers are inherently harder to waterproof and after 10 years with one I have decided to take a pass going forward. I will take a cover that sticks above the bed an inch and a half and looks a bit less slick in exchange for the naturally superior water shedding ability of seals that are on top of and towards the middle or outside of the rail.
    Recursion and Beach Toy like this.
