Backing up trailer issues.
Discussion in '3rd Gen Tundras (2022+)' started by JerseyGeorge, Sep 26, 2024.
  1. Sep 26, 2024 at 11:23 AM
    JerseyGeorge
    JerseyGeorge [OP] New Member
    2024 Platinum
    When backing up boat trailer I get beep beep beep then brakes slam on. I am in trailer mode on shift, and the tundra says “trailer detected”. Yet the vehicle thinks I’m about to hit person or object and keeps slamming brakes on. There is a red brake warning also.
    I have turned off all 5 protections on the maintenance screen. Even with all off, boom… brakes slam on.
    Toyota says bring to dealer. There has to be something I’m doing wrong or that others have experienced.
  2. Sep 26, 2024 at 11:27 AM
    DRP
    DRP Old Member
    Dave
    You have turned off the one that has the little traffic cone icon I assume? If that's off it could be that the sensors need to be re calibrated. There was another thread a while back with the same complaint and the dealer fixed it under warranty.
  3. Sep 26, 2024 at 11:31 AM
    Tunrod
    Tunrod New Member
    Rod
    2021 SR5 CM 4x4
  4. Sep 26, 2024 at 11:38 AM
    JerseyGeorge
    2024 Platinum
    That is exactly my problem, but unfortunately that fix does not work. I turn off the little cone, but still get brakes. And trust me. It makes a person say bad words really loud.
    woods likes this.
  5. Sep 26, 2024 at 11:39 AM
    teab
    teab 2023 Platinum w/ PRO bits
    Ty
    Denver
    2023 Platinum MGM 6.5
    TRD Pro Wheels, Go Rhino D6, Airlift bags/compressor, Talons Alum Cat Shield, Cheap-o Amazon Mud Flaps, Fastop Tonneau/Topper, Rear TRD Pro Shocks
    Sounds like you already know what to do^^^^^
    GODZILLA and Breathing Borla like this.
  6. Sep 26, 2024 at 3:13 PM
    JerseyGeorge
    2024 Platinum
    Actually I dont
  7. Sep 26, 2024 at 3:27 PM
    DRP
    DRP Old Member
    Dave
    I do believe a trip to the dealer is in your future. The traffic cone is all you should have to turn off.
  8. Sep 26, 2024 at 3:33 PM
    PNW Tundra Mike
    Southern Cal
    MX4 Tonneau, Talon's Trans/Cat Shield
    Yes. A few others here have reported the same issues that Trailer Mode and the Auto Collision button are not bypassing auto collision braking. Dealer has a fix.
  9. Sep 27, 2024 at 6:39 AM
    teab
    Ty
    Denver
    You said it your self.."Toyota says bring it to the dealer" so bring it to the dealer.
    GODZILLA likes this.
  10. Sep 27, 2024 at 7:05 AM
    g6t9ed
    g6t9ed Novice Tundra Modder
    2017 Black CrewMax 1794 4x4
    Instructions unclear.
    GODZILLA and woods like this.
  11. Sep 27, 2024 at 7:06 AM
    Rngr188
    Rngr188 Ranked the best new member of all time
    Chad
    Harrison AR
    2020 1794 MGM TRD OR
    Does your boat have surge brakes?
  12. Sep 27, 2024 at 3:55 PM
    JerseyGeorge
    2024 Platinum
    Yes. And it's the Tundra braking not the trailer. The solenoid that prevents braking when in reverse is working fine.
  13. Sep 28, 2024 at 4:04 PM
    Rngr188
    Chad
    Harrison AR
    Just to confirm, are you getting reverse lights on the trailer?
  14. Sep 29, 2024 at 6:03 AM
    JerseyGeorge
    2024 Platinum
    Yes. It's not the trailer locking up. I know what that is right. I am getting the "beep, beep, beep", then the red BRAKE warning on the display and the brakes SLAM on.
  15. Sep 29, 2024 at 7:27 AM
    Matt2015Tundra
    Matt2015Tundra New Member
    2023 1794 CrewMax
    If turning off the parking sensors (button with car backing into a cone) doesn't solve your problem, you need to visit the dealership. I tow trailers and boats a lot, so I just leave the parking sensor button off permanently.
    GODZILLA, Tundrastruck91 and DRP like this.
  16. Sep 29, 2024 at 8:14 AM
    GoHuskers
    GoHuskers New Member
    Nebraska
    '24 iForceMax, '17 RX350, '15 GX460
    I got this same issues the first few times I used the trailer. Yes, there's a button above your left knee, turn it off and everything is working as designed.
  17. Sep 29, 2024 at 8:19 AM
    dklehman
    dklehman New Member
    Darin
    2024 sr5 Tundra
    Did you set up your trailer profile? Also I'm sure you are but make sure your trailer electric is plugged in. I had the same issue when I was trying to move the trailer around the yard real quick without plugging it in.
  18. Oct 1, 2024 at 4:25 AM
    tundramh
    tundramh New Member
    OHIO
    Mine won't back if my door isn't closed. Are you a boat backer hanger outer??
  19. Oct 1, 2024 at 4:52 AM
    DRP
    DRP Old Member
    Dave
    If you have the door open and then put the truck in gear it will hit the brakes if you move the truck. The work around is after you put the truck in gear, put it back in park then back in gear. A bit of a PIA but at least there is a bypass.
  20. Oct 1, 2024 at 5:40 AM
    tundramh
    tundramh New Member
    OHIO
    yep....just thought it may be pretty easy at a boat ramp to not realize the open door was the problem.
    DRP[QUOTED] likes this.
  21. Oct 1, 2024 at 6:43 AM
    DRP
    DRP Old Member
    Dave
    Ha! Didn't put two and two together when you said "boat backer hanger outer". Hadn't had any coffee yet....
    Two pieces of advice I always gave to the kids of my fishing buddies: Marry rich and learn how to back up a trailer with your mirrors.:thumbsup:
  22. Oct 1, 2024 at 11:59 AM
    tundramh
    tundramh New Member
    OHIO
    Years ago my Dad told me "the back wheels of the truck are the front wheels of the trailer". Problem solved.
    GODZILLA and DRP[QUOTED] like this.
  23. Oct 4, 2024 at 4:07 PM
    gnc1017
    gnc1017 New Member
    22 Tundra Platinum Hybrid 6.5 Blueprint
    1.75 leveling kit Nitto Ridge Grappler tires (305/55/20) Black Rhino Arches Gunmetal wheels Truxedo Deuce cover w/ TonneauMate box
    I have this issue also. Doors are closed and I have hit the button lower left of the steering wheel to disable the sensors and still it occasionally does the brake slam warning thing. And whether I'm at the ramp or blocking the street backing into my driveway, it really sucks when it does.
    Saw this in another thread:
    I mainly just tow a boat trailer with surge brakes and a 5 pin connector (5th pin for trailer brake reverse override which works properly).
    So I guess my questions are:
    • Even with the truck identifying my trailer and me pushing the button, is it correct that I should not be getting this warning and per LayK's post, is it likely a bad sensor?
    • Anyone else have this actual issue (not operator error) with a positive resolution?
    • Is there a good diagnostic procedure for the tech to test this?
    • Is there a TSB on this?
    My dealer says I need to bring the boat trailer to them and reproduce the issue. Since they aren't close, that would be a PITA so I'm hoping to be able to come to them with more definitive info and ability to troubleshoot that doesn't require me to drag the boat to them.
  24. Oct 4, 2024 at 4:11 PM
    gnc1017
    gnc1017 New Member
  25. Oct 4, 2024 at 5:07 PM
    DRP
    DRP Old Member
    Dave
    @SDHNTR
    Wasn't it you that had the bad senor causing this issue? (Apologies if my memory is incorrect)
  26. Oct 5, 2024 at 4:23 AM
    LayK
    LayK New Member
    Layton
    Baton Rouge
    2022 Silver Tundra TRD 4x4 Limited Hybrid
    So someone rear ended me my 3rd week of owning this truck, and when they repaired my rear bumper my rear sensors were bad. They said sometimes they also come bad. It sucks but you might have to just drive to the dealer with your boat. I live 10 minutes from mine and had a small 10 foot trailer I brought to replicate the issue.
    Tundrastruck91 likes this.
