Backup camera not working
Discussion in '2.5 Gen Tundras (2014-2021)' started by Tundy14, Jun 10, 2023.
  1. Jun 10, 2023 at 8:20 PM
    Tundy14
    Tundy14 [OP] New Member
    2014 SR5 Tundra
    So I installed the carabc CarPlay system in my 2014 tundra and it ended up breaking. Well my backup camera still worked I took it out and hooked the plugs back into my radio and now it doesn’t work. It’s not displaying a black screen or a the radio doesn’t recognize I even put the truck in reverse. I’ve checked the connections multiple times seems to be no pins out and I’m out of ideas for how to fix this.
  2. Feb 28, 2024 at 7:33 PM
    keller94331
    keller94331 New Member
    2015 Tundra SR5 TRD
    Did you get this figured out? I am having the same issue. Installed Carabc and took it out because it stopped working, now my back up camera does not work. Anyone have a solution or is my factory radio toast?
  3. Feb 28, 2024 at 10:36 PM
    Tundy14
    2014 SR5 Tundra
    I did my issue ended up being I just needed to reset the truck. All I did was disconnect the battery let it sit for a little bit and hook it back up and I had a back up camera again.
  4. Feb 29, 2024 at 12:26 PM
    keller94331
    2015 Tundra SR5 TRD
    Thanks man, I did the reset and the camera is working. Thanks for the reply!
  5. Feb 29, 2024 at 2:28 PM
    Tundy14
    2014 SR5 Tundra
    No problem glad it worked for you.
    keller94331 likes this.
