Backup Camera stopped working
Discussion in 'Audio & Video' started by 14crewmaxSR5, Nov 7, 2019.
  1. Nov 7, 2019 at 6:44 AM
    14crewmaxSR5
    14crewmaxSR5 [OP] New Member
    NorthEast
    2014 Tundra Crewmax SR5 TRD
    Lift Blocks Onboard Air Air Bags Leer Cap Warn Hidden Hitch Bumper Badlands 12000 Synthetic Winch
    Hi Guys,
    Longtime Lurker here :)
    Parked in the garage yesterday morning, using the backup camera, and when I went back 8hrs later, and drove 10ft, then tried to backup (tiny parking garage requires alot of moves) the camera was blank.
    Tried a number of things so far:
    1. Searched the forum, and found one post that had some ideas, but no solutions for me.
    2. Checked inside tailgate that camera is plugged in fully
    3. Checked under bumper that camera is plugged in fully.
    4. Disconnected battery overnight to reset everything, hoping it would come back.
    5. Followed the cable as far as I could to see if something broke it, but it's in good condition.
    I'm getting a black screen most of the time. If it's not black, then it's white, with multi-colored almost vertical lines.
    The truck is a 2014 crewmax, no electrical system mods, except battery is tapped for lights etc, but not using any relay triggers anywhere within the stock system.
    Got any ideas of other things to try? I'm trailering alot next week, and my pampered self can't imagine backing up to the trailer without that little camera on.
    Thanks!
  2. Nov 7, 2019 at 6:46 AM
    blizz86
    blizz86 New Member
    Its most likely the actual camera unit itself that is messed up. I had a similar thing happen to my dads 4runner, it would either blue screen or only work periodically. I ended up taking it apart and ordering the same camera part # vs ordering the entire housing.
  3. Nov 12, 2019 at 8:34 AM
    14crewmaxSR5
    NorthEast
    Figured I'd update this incase someone else found it searching for a solution. This weekend I was driving the truck, and heard a loud noise, and the radio all of a sudden got louder.
    I wondered if the camera was working again, so I pulled over and tested it. Sure enough, back to normal. I later dissasembled the dash, but nothing out of the ordinary in there, looked like everything was fully connected.
    Who knows what it was, but glad its working again.
    Thanks
    mbarton557 likes this.
  4. Dec 28, 2019 at 6:49 PM
    SuperWhite20
    SuperWhite20 New Member
    Robert
    Georgetown TX
    2020 Tundra Crewmax SR5 4X4
    TRD Sway bar. Deck Rails, Maxliner rear floor mat, Driver side grab handle. Dee Zee bed mat
    I was on my creeper looking under my 2020 and the camera wire was hanging down on my tailpipe just behind the rear axle. Might start there.
  5. Dec 28, 2019 at 6:59 PM
    rznhales
    rznhales New Member
    Randy
    Southern Utah
    2014 Tundra Crewmax Limited TRD
    Bilstein 5100's
    Mine stops working if the maintenance alert pops up on my screen. When I shut that off the camera works fine. Weird!
  6. Dec 18, 2021 at 3:22 PM
    mbarton557
    mbarton557 New Member
    Mary
    08 Tundra
    I just bought a 08 SR5 and camera dead. According to Toy Dealer here they have had about 30 of these and have yet to find the fix. I understand that it is a port installed option. I just knew that it was going to b something simple but no surprise it still doesn’t work. Any help appreciated. This is my Second Tundra and I also had an 08 Sequoia. No backup on either.
  7. Dec 18, 2021 at 3:29 PM
    alb1k
    Left Coast
    05 2WD DC w/ attitude
    It's good
    RCAs sometimes need to be disconnected, re-connected as they can lose their continuity. Probably what happened to your video RCA connection.
    Edit: not sure if yours is factory and/or has this connection.
  8. Dec 18, 2021 at 5:26 PM
    mbarton557
    Mary
    08 Tundra
    Mine has a 2x3” screen in overhead console. Port installed in pkg
  9. Dec 18, 2021 at 5:31 PM
    alb1k
    Left Coast
    It's good
    Does it have a usually yellow RCA plug at the video unit and or near the camera? Try unplugging and reconnecting.
  10. May 7, 2023 at 11:53 AM
    gchliu
    gchliu New Member
    Vancouver, BC
    2015 Tundra CrewMax SR5
    My reverse video display on my 2015 Crewmax went black a week ago. With a multimeter, it was impossible to trace the wiring by probing the miniature connector pins. I bought an used OEM camera with harness off eBay. It turned out the camera was not the problem but the wiring between the camera and the first plug connector near the rear bumper was at fault. I am glad it was a cheap simple fix and didn't need to pay the dealership to troubleshoot for hours. Hope this helps for anyone who has the same problem.
