Backup Sensors/Parking Assist
Discussion in '3rd Gen Tundras (2022+)' started by Donontheroad, Apr 7, 2024.
  1. Apr 7, 2024 at 3:01 PM
    Donontheroad
    Donontheroad [OP] New Member
    Don
    2024 White TRD
    I bought my 2024 Base Model (apparently, didn't know) TRD in December. After I got home, I realized it didn't have backup sensors. Those things that beep at you before you wreck your garage door from backing into your driveway. Anyway, I called the salesman and he said to look at the back to be sure. Yep. No sensors. Grr. Anyway, unless I upgrade to a Platinum or something I'm just out of luck.
    Has anyone successfully added any of these types of sensors to their truck or have any other recommendation? I have a rear view cam, but a beep would be nice just to be sure. :)
    Thanks!
  2. Apr 7, 2024 at 3:13 PM
    Dpoll995
    Dpoll995 New Member
    Houston TX
    2024 Tundra Limited
    There are aftermarket systems for that. They would not work them same as the oem they won’t prevent collisions. You just get the beeping
  3. Apr 7, 2024 at 3:14 PM
    Dpoll995
    Dpoll995 New Member
    Houston TX
    2024 Tundra Limited
  4. Apr 7, 2024 at 3:47 PM
    Donontheroad
    Don
    2024 White TRD
    Thanks! All I want is a beep. Thanks! Has anyone actually had one of these installed? I was told by service not to interface with the computer system or it would cause a lot of problems. Thanks!
  5. Apr 7, 2024 at 4:05 PM
    Dpoll995
    Dpoll995 New Member
    Houston TX
    2024 Tundra Limited
    Way back in 2011 I installed a system on my wife’s Camry. Don’t remember the brand but it didn’t have any sort of display. It was just a speaker/ controller mounted over the dash. I just got power from the fuse box, something that was only powered when the car was on. Everything worked fine. It was a little nerve racking drilling the holes. Measure and measure and measure and check clearance multiple times before drilling. I used a step bit to drill the holes, it cuts cleaner than a hole saw.
