Bad battery connection and error codes
Discussion in '2nd Gen Tundras (2007-2013)' started by *D*, Dec 4, 2021.
  1. Dec 4, 2021 at 3:09 PM
    *D*
    *D* [OP] New Member
    Dimitri
    Rhode Island
    ‘24 DC Long Bed 4x4 SR5
    My truck went into limp mode this week. The codes came back as P0894 (transmission component slipping) and C1201 (brake boost sensor circuit range/ performance).
    It’s a 2007 with 204K miles and it runs great. Definitely no roughness in the tranny. I assumed this was an electrical problem, so I spent the day looking for chewed wires and corrosion. At one point I disconnected my battery and couldn’t get the truck to start after reconnecting. The dashboard lights were flickering, which made me realize it was a bad connection. I cleaned it all up and everything seems back to normal now, the truck runs fine.
    My question then is, can a bad connection to the battery trick the ECM into throwing false codes? I’ve only driven it about 5 miles since I got it going again, so maybe I’m writing this too early.
  2. Dec 4, 2021 at 3:20 PM
    audiowize
    audiowize New Member
    Paul B.
    2008 Tundra SR-5 4x4 5.7
    Yes, a bad battery connection can cause a myriad of random codes to come up that end up being phantom codes.
    *D*[OP] likes this.
