Bad blower motor?
Discussion in '2.5 Gen Tundras (2014-2021)' started by Thattundradude, Sep 8, 2018.
  1. Sep 8, 2018 at 10:11 AM
    Thattundradude
    Thattundradude [OP] New Member
    Platinum Tundra
    Lifted
    Hi guys. I have this really really really annoying sound that comes when I turn the ac on. I can't have a quiet drive because the noise drives me nuts
    It gets louder as the fan speed is increased.
    https://youtu.be/YiXckHHHRik
  2. Sep 8, 2018 at 10:24 AM
    AndyCBR
    AndyCBR New Member
    Baton Rouge, LA
    How old is the truck?
    Sounds like a high pitched whine from a bearing. Seems to vary pitch with rpm so it seems like it would be part of the rotating assembly.
    My $.02
  3. Sep 8, 2018 at 10:24 AM
    Thattundradude
    Platinum Tundra
    Lifted
    2014. When the ac is completely off there's no noise
  4. Sep 8, 2018 at 10:28 AM
    AndyCBR
    AndyCBR New Member
    Baton Rouge, LA
    Replace the blower motor and see if that fixes it? Swap one from a buddys truck or buy a used one.
    You can take the blower motor out and also bench test it to see if that is the source of the noise.
    A new blower motor is only $110 from mail order toyota dealers if you take it somewhere you'll toss that much down the drain in labor for diagnostics.
  5. Sep 8, 2018 at 10:33 AM
    trdprobped17
    trdprobped17 New Member
    I had a similar sound in my truck coming from the ac. It was located on the passenger side. So, I had to remove the vent cover to see what it were. Come to find out that a dried leaf was stuck in the line. I got small bits and pieces out with a needle nose. But some pieces broke off in there because the leaf was all dried and brittle. So, I got my shop vac and sucked it all out. That solved the problem.
    I don’t believe that it’s your ac motor being bad.
  6. Sep 8, 2018 at 10:50 AM
    Sas
    Sas Humor is everywhere
    OKC, OK
    '17 SR5 CM TSS 4WD MGM 5.7 FF
    Lost track after #1.
    When you open the glove box does it sound louder from there?
  7. Sep 8, 2018 at 11:02 AM
    Thattundradude
    Platinum Tundra
    Lifted
    I haven't tried that
  8. Sep 8, 2018 at 11:13 AM
    Sas
    OKC, OK
    I'm just wondering if there's something stuck in the cabin filter, or if it hasn't been changed in a while, if it's dirty and air is now whistling passed it. On a positive note, it sounds like a jet engine powering up when you turn it up, which is kind of bad ass.
  9. Sep 8, 2018 at 11:21 AM
    G10dra
    G10dra Not a New Member
    sounds like something is stuck in the blower fan (NOT THE AC). The noise only increases when you raise the fan speed. Open the fan that's below/behind the glove compartment and see if there's something stuck.
  10. Sep 8, 2018 at 11:28 AM
    Thattundradude
    Platinum Tundra
    Lifted
    Lol I just watched this video last night
  11. Sep 8, 2018 at 11:28 AM
    Thattundradude
    Platinum Tundra
    Lifted
    I'm going to check out the cabin filter see if there's anything.
    Sas likes this.
  12. Sep 8, 2018 at 11:30 AM
    Sas
    OKC, OK
    :fingerscrossed:
  13. Sep 8, 2018 at 12:35 PM
    Dabutcher
    Dabutcher New Member
    D
    Twin Cities
    2008 Nautical Blue Tundra SR5 CM 4x4 Beauty
    Toytec Boss coilover, Ray10’s ,Ridge Grapplers,Bilstein 5100,BAM 8”,TRD sway,
    When I bought my used Tundra. I replaced the cabin filter and it was above the blower motor and blower wheel and filter had a bunch of leaves and dog food in it. If you do not have really large hands? You can reach down it it and pull anything out of it. Good luck. D
  14. Sep 8, 2018 at 12:37 PM
    G10dra
    Oh yes, I Forgot to mention if you're going to do all this work and depending on the age of your truck you might as well replace the in cabin air filter
    Thattundradude[OP] and Sas like this.
  15. Sep 25, 2018 at 11:34 AM
    callymanjrod
    callymanjrod New Member
    Jared
    Surprise
    2017 Tundra Crewmax SR5 MGM
    Raptor grille, spyder head and tail lights, LED all interior/exterior lighting, led third brake light, Pioneer mixtrax touch screen, AFe exhaust and K&N intake. 4” lift, front and rear TRD sway bars, LED bumper light-bar, LineX color match bumpers.
    Sounds like a 747 getting ready to take flight! Custom install! Lol j/k. I have the same issue in my 2017 Tundra and everyone says something is stuck in it but I have tried cleaning the filter and blower motor and still exists. No clue
  16. Sep 25, 2018 at 12:04 PM
    TacoWuzzaTurd
    TacoWuzzaTurd Loving my Tundra
    Scottsdale AZ
    2018 SR5 4x4 Crewmax, TRD Offroad
    6112s @1.9", TRD Dual Exhaust, rims, tires, jl audio system
    Dog food. WTH
  17. Sep 25, 2018 at 12:06 PM
    15whtrd
    15whtrd Mr. Blonde
    Lol Probably rats were getting in there
    TacoWuzzaTurd[QUOTED] likes this.
  18. Sep 25, 2018 at 12:10 PM
    TacoWuzzaTurd
    Scottsdale AZ
    My neighbor bought a used 2016 or 2017 tundra from a guy who had a pecan orchard. It drove great but started throwing some idiot lights on the dash so he took it to the dealer. Turned out the wiring was all chewed up from rodents. They like the soy based wire coating more than the damn pecans I guess. He ended up trading it in that same day for a new 2018...didnt even want to fuck with it.
    15whtrd[QUOTED] likes this.
  19. Sep 25, 2018 at 2:20 PM
    snarkscarbine
    snarkscarbine New Member
    Alex
    Dallas
    2014 Silver Sky CM Ltd 4x4
    Bilstein 5100s Footwell LEDs Fold-A-Cover g4 elite TRD 18s
    I bought my 2014 used and noticed once I got it home that the a/c sounded like a C5 on take-off with the blower all the way up. Pulled the blower out and it had a handful of acorns in it. Sounded like new with those gone. It's super easy to pull the motor. I'd do that and see what's up in there. Your motor sounds fine to me.
    1UPPER and 15whtrd like this.
  20. Sep 25, 2018 at 3:19 PM
    15whtrd
    15whtrd Mr. Blonde
    I don’t blame him!
  21. Aug 5, 2019 at 4:06 AM
    NJ Cement TRD Pro
    NJ Cement TRD Pro My Tundra has a Raptor bodykit.
    Ben
    Bergen County, NJ
    2019 Ford Raptor
    My truck did the same thing...dealer said it was normal (It was not).
    I replaced the blower motor with an OE one (About $100) and the sound went away...until now. It’s back again. However, the dealer won’t replace it unless it is non-functional.
    That’s 2 blower motors in 27k miles.
    The truck will go back to the dealer for its next oil change...and I’m sure the blower motor will be inop by then.
