Bad day so far for Tundra :(
Discussion in 'General Tundra Discussion' started by Mountun Goat, Mar 9, 2019.
  1. Mar 9, 2019 at 11:17 AM
    Mountun Goat
    Mountun Goat [OP] She baaaaaahd
    EhBerta, Canadia
    It’s a Goat.
    Well. Found the box rust this morning. Then parked my trailer after pulling it down the highway and found it was covered in grease. Drivers side cv joint has failed too!
    At first I was hoping for just the boot to be ripped. But at about 50 kph it has a violent shake.
    The only advantage to any of this is that I’ll be able to work on the tundra before my house Reno’s are done haha. While I replace cv, I’ll add my diff drop and driver side coach builder shim to take care of tundra lean.
    Who has replaced a cv joint? Fairly doable? I’m very mechanical so not worried. Any special tools needed? TIA
  2. Mar 9, 2019 at 11:24 AM
    Outbound
    Aaron
    Northern Alberta
    Man that sucks! I haven't done a CV so I'm no help there. I can only offer moral support and sarcastic comments.
  3. Mar 9, 2019 at 11:24 AM
    Ouch! Sorry this happened, hope ya fix quickly, mine went out on my T100
    Mountun Goat[OP] likes this.
  4. Mar 9, 2019 at 11:25 AM
    trayday
    trayday New Member
    Oregon
    2015 limited CM 5.7
    A big socket in the 30+mm's, can't remember the size but it's in the garage. An air impact will definetely help with that hub nut.
  5. Mar 9, 2019 at 11:28 AM
    Mountun Goat
    EhBerta, Canadia
    It’s a Goat.
    Good to know thanks. The air impact is covered. I’ll have to pull it to get the socket size.
    trayday[QUOTED] likes this.
  6. Mar 9, 2019 at 11:30 AM
    trayday
    trayday New Member
    Oregon
    2015 limited CM 5.7
    39mm socket. There's a snap ring on the diff side, Youtube for a tutorial or a welding a plate to the cv housing to help pry off off. I've blown 2 driver sides.
  7. Mar 9, 2019 at 11:37 AM
    Mountun Goat
    EhBerta, Canadia
    It’s a Goat.
    Gross! That’s for the info
  8. Mar 9, 2019 at 11:42 AM
    Mountun Goat
    EhBerta, Canadia
    It’s a Goat.
    I wonder why the drivers twice? More pot holes in middle of road?
  9. Mar 9, 2019 at 11:43 AM
    TheBeast The Beach
    pretty common on Toyotas as soon as you start lifting and playing with suspension angles. It sucks but it's not the end of the day.
  10. Mar 9, 2019 at 11:49 AM
    Mountun Goat
    EhBerta, Canadia
    It’s a Goat.
    Think I should change the passenger one while I’m under there?
    Slayer likes this.
  11. Mar 9, 2019 at 12:27 PM
    trayday
    trayday New Member
    Oregon
    2015 limited CM 5.7
    Taking woops offroad at highway speeds. This was all before an air locker. Now I do the same in 2wd with the rear locked and no more blown cv joints.
  12. Mar 9, 2019 at 12:30 PM
    Mountun Goat
    EhBerta, Canadia
    It’s a Goat.
    Well. I ordered both sides with heavy duty boots for $420. Masel do both while I’m under there!
    Wrongside and Y0TA PR0 like this.
  13. Mar 9, 2019 at 12:30 PM
    trayday
    trayday New Member
    Oregon
    2015 limited CM 5.7
    Depending on the mileage I'd guess. I paid less than $50 shipped from low mileage passenger side damaged trucks from Ebay.
  14. Mar 9, 2019 at 12:32 PM
    Mountun Goat
    EhBerta, Canadia
    It’s a Goat.
    Oh mine is miled out for sure. 470000km on those cv joints. 10000 of which had a 3.5” lift haha. Gotta get the diff drop installed
    Wrongside likes this.
  15. Mar 9, 2019 at 12:34 PM
    chugs
    chugs New Member
    Ciao
    Central Cali
    2007 Tundra Blue Streaker
    Make sure to replace input axle seals on front diff and take ur time not to screw it up.
    Mdjamesd and Mountun Goat[OP] like this.
  16. Mar 9, 2019 at 12:39 PM
    Mountun Goat
    EhBerta, Canadia
    It’s a Goat.
    Perfect thank you!
  17. Mar 9, 2019 at 2:03 PM
    Woofer
    Woofer New Member
    Toyota has a box rust problem. Showed my dealer the rust on my 2011 tundra. Toyota replaced the complete box and tailgate, no cost to me.
  18. Mar 9, 2019 at 2:54 PM
    Liquid unlucky
    Liquid unlucky New Member
    North east Texas
    2019 Toyota Tundra
    None....yet few decals and a five star dragon Ball. Lift 4.5" in two years is the plan
    Change the whole axel it's easier and doesn't cost much more.
  19. Mar 9, 2019 at 3:20 PM
    TheBeast The Beach
    SDHQ has heavy duty boots too.
    Wrongside and Mountun Goat[OP] like this.
  20. Mar 9, 2019 at 3:25 PM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    Sounds like you've already ordered complete axles. I just rebuilt mine and it's a super messy job. I'm glad I now know how to do and next time I'll farm it out to someone else.
  21. Mar 9, 2019 at 6:22 PM
    TheBeast The Beach
  22. Mar 9, 2019 at 7:33 PM
    trayday
    trayday New Member
    Oregon
    2015 limited CM 5.7
    So much easier to replace the complete unit as Liquid said. Rebuilding sucks and is messy as hell, I won't ever do it again. CV boots for $33 plus shipping with a headache or $40 w/free shipping for a low mileage complete unit.
  23. Mar 9, 2019 at 8:32 PM
    Pudge
    CT
    2015 Blue Ribbon Platinum
    I wanna pull my drop in liner this summer. I might try my hand at a diy bedliner then put the drop in back in, or maybe just fluid film and put it back in. It stays dry under my tonneau back there but I wanna be one step ahead. Paying for linex is not an option unfortunately
  24. Mar 9, 2019 at 8:34 PM
    Mountun Goat
    EhBerta, Canadia
    It’s a Goat.
    Linex was a waste as it seems anyways!
    Y0TA PR0 and Pudge[QUOTED] like this.
  25. Mar 9, 2019 at 8:35 PM
    Mountun Goat
    EhBerta, Canadia
    It’s a Goat.
    Ya I bought full new axles. I’m mechanical but don’t like getting dirty haha. There’s a fine line
    trayday[QUOTED] and Y0TA PR0 like this.
  26. Mar 9, 2019 at 8:40 PM
    Y0TA PR0
    Y0TA PR0 Oil & Gas
    Rafael
    2017 TRD PRO
    :thumbsup:
  27. Mar 9, 2019 at 8:41 PM
    Y0TA PR0
    Y0TA PR0 Oil & Gas
    Rafael
    2017 TRD PRO
    Man that sucks bud! But for the amount of km you have on that sweet truck, IMO that’s minor problem!
  28. Mar 9, 2019 at 8:45 PM
    CaptSpaulding
    CaptSpaulding ...ain't nothin but nothin
    Jake
    2010 White DC 4x4
    Bummer man, thankfully you're mechanical and can tackle this
  29. Mar 9, 2019 at 8:45 PM
    Mountun Goat
    EhBerta, Canadia
    It’s a Goat.
    Absolutely it’s a fair fail for sure. Especially since I jumped the front end a few weeks ago haha:anonymous:
    Wrongside and Y0TA PR0[QUOTED] like this.
  30. Mar 9, 2019 at 8:46 PM
    Mountun Goat
    EhBerta, Canadia
    It’s a Goat.
    Yes thank goodness! At the end of the day my favourite place in the world is my shop. So it’s really not the end of the world :)
