Bad inner tie rod after replacing?
Discussion in 'Suspension' started by Nbab23, Aug 17, 2024.
  1. Aug 17, 2024 at 10:30 AM
    Nbab23
    Nbab23 [OP] 2020 SR5
    Nathan
    PA
    2020 SR5 crewmax
    Stillen CAI, DD 8” exhaust, Toytec Aluma coilovers, Icon leaf springs, SCS SR8 18x9 wheels, Cooper Rugged Trek 275/70/18 A/T Tires, Ecoological bumper shellz and grill surround, AJT interior black out kit, AJT shift knob. TRD pro style grill, VLED aqua blue footwell lights, MESO custom dome and map LED lights, swing case, Rough country bed mat, TRD pro headlights and fog lights, Morimoto XB tail lights and 3rd brake light.
    So a few weeks back I noticed that it felt like I was in a boat driving my truck. Real bouncy, steering would pull a bit on any bumps. I found the inner tie rod on the drivers side to be the culprit. Pretty significant left to right play on the tire. So I went with moog parts and swapped out it all on both sides. Was good for about 2 weeks after the alignment and now it starting to do it again. Jacked it up again today and took a video. There is some play and a slight clunking noise on the drivers side. Not as much as before. Does this amount of play constitute a bad inner tie rod? I know moog has gone downhill a bit over the years. Just wanted to see others thoughts. https://youtube.com/shorts/Q1O5zHYTkr4?feature=share
  2. Aug 17, 2024 at 12:36 PM
    frichco228
    frichco228 Valued Member
    2016 Crewmax 4WD, TRD Offroad
    that is a lot of play. Maybe it was a defective part out of the gate, happens. Maybe wheel bearing?
    Whenever I have removed or messed with wheels like that I didnt notice any perceivable play, not enough to really see or feel anyway.
    Nbab23[OP] likes this.
  3. Aug 17, 2024 at 2:40 PM
    Nbab23
    Nathan
    PA
    2020 SR5 crewmax
    It’s definitely better than it was the first go around which leads me to believe it is the tie rod. Plus the clunk I hear is right where the inner tie rod connects to the steering column. Here’s the video I took of the OEM inner that was bad….there was a ton of play on that one. https://youtu.be/3uGZC9_YLBQ
