Bad steering pumps or rack & pinion?
Discussion in '1st Gen Tundras (2000-2006)' started by Jdison03, Jan 6, 2016.
  1. Jan 6, 2016 at 5:37 PM
    Jdison03
    Jdison03 [OP] New Member
    Joe
    2003 toyota tundra
    I have a 03 tundra and I've put 3 power steering pumps on it in less than a month could I be getting bad pumps or could it be the rack & Pinion??
  2. Jan 6, 2016 at 5:42 PM
    3 of any product that consecutively says it has to be something else. Are they after market pumps or?
  3. Jan 6, 2016 at 5:43 PM
    Jdison03
    Joe
    2003 toyota tundra
    Yes they was aftermarket
  4. Jan 6, 2016 at 6:42 PM
  5. Jan 6, 2016 at 6:48 PM
    LOTSOFTOYS
    LOTSOFTOYS Toyota Whisperer
    Jace
    Mile high
    2005 Tundra DBL cab
    What's it doing orginally and now?
  6. Jan 6, 2016 at 6:51 PM
    Jdison03
    Joe
    2003 toyota tundra
    When I put the first pump on it started whining and went out the second one didn't work at all and the 3rd one whined as soon as I started the truck but it worked for about 10 miles and went out
  7. Jan 6, 2016 at 6:58 PM
    Virgils12
    Virgils12 New Member
    Camburg Fox factory 2.5" lift Xd monsters with 295/70/18 nitto terra graplerrs Corsa cat back Weather tech liners Wet okole covers
    So the whining is why you replaced the first one? Or was it hard to steer or?
  8. Jan 6, 2016 at 6:59 PM
    Jdison03
    Joe
    2003 toyota tundra
    No it went completely out
  9. Jan 7, 2016 at 12:07 PM
    LOTSOFTOYS
    Jace
    Mile high
    2005 Tundra DBL cab
    Have u flushed your lines? I've seen racks cause pumps to fail... ur also using aftermarket parts. They are crap. Toyota is the way to go. I went thru 2 Oreillys pumps before I learned my lesson and bought a Toyota one. Also use good fluid.
  10. Feb 11, 2016 at 6:06 PM
    Rkcruza
    Rkcruza New Member
    Bob
    2002 Tundra AC 4WD TRD OR SR5
    De Badged / Decaled, Firestone Ride Rite Air Bags w/ Daystar Cups, 17" Rims, Big Brake kit w/ slotted & drilled rotors, plus lots of work related stuff.
    What the last post said. If you are getting the pumps from the same place, try another vender, or better yet, go Toyota. Several OEM parts online for a discount price.
