Bad steering rack leak has anyone replaced the seal ?
Discussion in '2.5 Gen Tundras (2014-2021)' started by bajatundra53, Mar 20, 2020.
  1. Mar 20, 2020 at 1:32 PM
    bajatundra53
    bajatundra53 [OP] New Member
    My steering rack boot on my 2017 Tundra 4x4 with 14K miles got a tear in the boot at some point and now the seal is leaking badly. The dealer wants $2700 for new rack - insists the engine has to be removed . An independent Toy specialist shop is saying the same thing. Saw a utube on replacing just the seal on an early gen model. Has anyone done this with success? Alternatively I'm reading that it's possible to replace the rack without pulling the engine or dropping the differential ?
    831Tun likes this.
  2. Mar 20, 2020 at 1:46 PM
    fisherman951
    fisherman951 MT dreams
    Tony
    2017 crewmax 4x4
    No warranty?
  3. Mar 20, 2020 at 1:49 PM
    Darren509
    Darren509 New Member
    Darren
    Dayton NV
    2016 White Tundra TRD
    My entire steering rack was replaced around 30k and the motor did not have to be removed. If it was the tech and service manager did not inform me
    Kywildman likes this.
  4. Mar 20, 2020 at 2:14 PM
    bajatundra53
    They said the torn boot let dirt in which ruined the seal
  5. Mar 20, 2020 at 2:19 PM
    timsp8
    NY
    The book says to pull the engine and the dealer will charge you for the hours that takes. They wanted $3k to do mine. Insurance paid for it and they did it in half the time the book quoted, but still charged the full amount. There are posts on here of people doing it in their driveway without pulling the engine. If you don’t have the time or tools, find another shop that’ll do it that way.
    chugs likes this.
  6. Mar 20, 2020 at 2:23 PM
    fisherman951
    Tony
    2017 crewmax 4x4
  7. Mar 20, 2020 at 7:31 PM
    Neutron
    Neutron Parrothead
    James
    New Bern, NC
    2020 Tundra Limited CM Smoked Mesquite
    S&B intake, Corsa exhaust, TRD rear sway bar, Spec-D tail lights, wireless center console charger.
    Engine doesn't have to be removed. The front diff has to be lowered and the oil filter adapter housing has to be removed also. Then the rack is unbolted and with the outer tie rods removed or just unscrewed from the inners you slide the rack to the passenger side till the left side can be slid out of the frame forward and out it comes
    texasrho83, TXTundra2722 and jeremyd like this.
  8. Mar 20, 2020 at 7:45 PM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    To pull them without removing the engine and diff you need to remove at least the passenger side inner tire rod. And even then it’s a stupid tight fit to sneak out
    oil housing has to come off too
  9. Mar 20, 2020 at 8:59 PM
    Big_Ed
    Big_Ed New Member
    Spring, Tx
    2016 Tundra
    Might as well have them reseal the cam towers while they have the motor out.
    jtwags likes this.
  10. Mar 20, 2020 at 9:06 PM
    Ruggybuggy
    Ruggybuggy Seasoned Veteran
    Dave
    NW ON, CANADA
    2016 Tundra OR
    Good god.
  11. Mar 20, 2020 at 9:08 PM
    TXTundra2722
    2015 Black Tundra
    I think pulling the engine is what he's trying to avoid.... literally having them pull the engine is several thousand dollars vs the $1200 or whatever the steering rack costs and doing it yourself
  12. Mar 20, 2020 at 11:31 PM
    Overisland
    Overisland New Member
    Tony
    Polson, MT
    2020 Tundra Voodoo Blue Sport
    I replaced the rack on my first Tundra, a 2010 Rock Warrior. I had a 7" BDS lift on it and I knew the rack had shit the bed on me. I decided to test out the dealership anyways and brought it in and pretended I didnt know exactly what was wrong. They called me and told me it was my power steering rack and due to the lift they would not be replacing it haha. I paid about 1,000 for a new power steering rack from the dealer and put it in myself in about 3 or 4 hours and most certainly did not need to remove the engine.
    TXTundra2722 likes this.
  13. Mar 21, 2020 at 6:45 AM
    osidepunker
    osidepunker OsidePunker
    Alex
    2013 Tundra DC 4x4
    Full LT, full armor, fully self contained Speed Glamper
    swap it yourself, pretty easy if you have basic garage mechanic skills. If you dont, take it to an independent toyota shop. BUT DO NOT PAY THE STEALERSHIP:
    https://www.tundras.com/threads/the-truck-by-osidepunker.26649/page-7#post-1225433
    831Tun and ColoradoTJ like this.
  14. Mar 21, 2020 at 7:48 AM
    bajatundra53
    Anyone have any experience with replacing the seal without removing the rack ? There's rebuild kits out there .
    Yotaholic likes this.
  15. Mar 21, 2020 at 4:57 PM
    papasmurf
    papasmurf Savage Fabrication
    Bruce
    San Diego
    2007 4x4 Tundra
    07 Silver Sky 4x4 | Total Chaos LT | 2.5 King Coil overs & Bypasses | Camburg Bed Cage | 3.0 King Bypasses | 2.0 King Bumps | Custom Deavers | Nitro 4.88's | ARB Locker | Demello Sliders | 17" Double Standards | BFGKO2 37's |
    @bajatundra53 let me put this whole thing to bed, Ive done 8 steering racks on these trucks, pull the axles drop the diff. super easy, i can do the whole job in 6 hours.. where are you located??
    I can either talk you through it, or you can come by and i can do it for you. That being said, you need an alignment afterward because you mess with the tie rods.
    Shoot me a PM and I can give you my cell and help you out. The dealer is full of shit. you can tell them i said so.
    Thanks,
    Bruce
  16. Mar 21, 2020 at 4:57 PM
    papasmurf
    Bruce
    San Diego
    2007 4x4 Tundra
    our racks are not rebuildable, you have to replace the whole rack sorry to tell ya that, im on my 5th on my truck...
    osidepunker and TXTundra2722 like this.
  17. Mar 21, 2020 at 5:00 PM
    papasmurf
    Bruce
    San Diego
    2007 4x4 Tundra
  18. Apr 4, 2020 at 7:46 AM
    Stap0607
    Stap0607 New Member
    2011 Black Rock Warrior CM
    @papasmurf does this part number rack fit a 2011 as well? When I look up the 2011 rack it's a different part number and about $250 more expensive. For the 2011 I'm showing -0C160. It would be nice to spend less on a new rack and have the updated design.
  19. Apr 4, 2020 at 9:16 AM
    bleach
    bleach MEME Fiend
    DJ
    Battle Ground, WA
    1991 White Xtra-cab SR5 4X4 V6 5 speed 148K
    Why would you need to replace the rack so many times? Is there a serious design flaw or is it because of some very rough use?
  20. Apr 4, 2020 at 9:47 AM
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    It's usually a result of a lift, bigger tires and off road use. Puts an increase load on the rack.
    bleach[QUOTED] likes this.
  21. Apr 4, 2020 at 9:57 AM
    bleach
    bleach MEME Fiend
    DJ
    Battle Ground, WA
    I was thinking that was the probably the issue. I personally dislike steering racks. I still have nightmares from a rack job I did on a 78 Audi back in 1983.
  22. Apr 4, 2020 at 10:03 AM
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    They are great if you leave the Tundra stock and very reliable with a good steering feel. When you lift, it angles the inner tie rods and with the larger tires exerts forces the rack was never designed to handle.
  23. Apr 5, 2020 at 3:57 AM
    osidepunker
    Alex
    2013 Tundra DC 4x4
    None of that is true. I've wheeled with literally hundreds of Tundras. Ive personally seen 3 or 4 rack failures on the trail and I have several close friends who have had rack failures. These failures have happens on all different kinds of suspension setups, including one stock 2016 that was only 2 years old.
    Early on there were some batches of racks with bad seals. Then Toyota corrected that with new part numbers. Nowadays, the rack failures are less frequent. but they still happen. The problem is randomly some racks will have the inner tie rod seals manufactured improperly and they blow. This will fill the boot with fluid.
    I have a 2013. The rack lasted 6 years and 70k hard off road mile on a 4" long travel lift. I had to replace it last year because I broke some rack teeth when I was wheeling. The new rack has a year of hard wheeling on it and so far so good.
  24. Apr 5, 2020 at 5:53 AM
    Now if I can only find that video of Bruce’s truck swallowing whoops.....
    831Tun and papasmurf like this.
  25. Apr 5, 2020 at 7:01 AM
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    Believe what you want. Its very rare at the dealership that we change out racks. The only ones that had issues were lifted with larger tires. You said it yourself, "had a 2013 that the rack lasted 6 years". If your truck wasn't lifted it would never had failed. I'm not saying it's a common problem but it does happen more often than a stock Tundra.
    bleach likes this.
  26. Apr 5, 2020 at 7:12 AM
    ginocara74
    ginocara74 New Member
    North Carolina
    2017 SR5 5.7 V8 FFE 4WD magnetic gray with front bench seat and off road package
    TRD dual exaust, TRD drop in air filter, Weather Tech rain GUARD, tri-fold bed cover
    I've noticed a weered noice when steering to the left from being stop while tacking off. It sound rubber friction. Is this a sign of the rack failing? How can you actually tell is the rack you're having issue with? Thanks.
  27. Apr 5, 2020 at 7:13 AM
    osidepunker
    Alex
    2013 Tundra DC 4x4
    Dude. I told you why my rack failed. I was wheeling. Actually, I rolled the truck. That caused the teeth in the rack to break. It still steered but there was a pop in certain spots.
    When the "bad" racks fail its the inner tie rod seals. Suspension has nothing to do with it
  28. Apr 5, 2020 at 7:14 AM
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    Have a nice day.
  29. Apr 9, 2020 at 12:23 PM
    papasmurf
    Bruce
    San Diego
    2007 4x4 Tundra
    The first 3 were caused by BDS gen 1 spindles which had a back ackerman angle that put extra stress on the tie rods and seals(they have since fixed that issue). the 4th was because I crashed the truck into a wall on the freeway, the 5th was over 80k miles later, and had some issues with my pump, and resi and fluid which caused me to question the rack may have debris in it, and I wanted to upgrade to new poly bushings so I replaced the entire PS system.
    The other three were on friends trucks
  30. Apr 9, 2020 at 12:24 PM
    papasmurf
    Bruce
    San Diego
    2007 4x4 Tundra
    absolutely nothing to do with tires, a lift or offroad use.. sorry but you are wrong
    osidepunker likes this.
