Bakflip Bed Cover Fitment
Discussion in 'Tonneau Covers, Caps and Shells' started by JayKay, Jan 2, 2024.
  1. Jan 2, 2024 at 3:40 PM
    JayKay
    JayKay [OP] New Member
    Does anyone know if a Bakflip bed cover on a 2017 Dodge Ram with 5' 7" bed will fit a 2014 Tundra Crewmax?
  2. Jan 2, 2024 at 4:42 PM
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    Since the Tundra bed is 5'6", I doubt it.
  3. Jan 5, 2024 at 4:29 PM
    JayKay
    I just took a risk and bought it used for $200. I couldn't pass up on that great of a deal. I installed it with some minor modifications. The Tundra bed from side to side is just a tad bit bigger than the Dodge Ram so I added a 1/8 inch spacer on both of the side rails to make it fit. If I didn't add the spacers then it'll still fit but with a tiny gap to let water leak through.The spacers I used is actually six nickels on each side to space the side rails out a little bit and bolted it down. 2 in front, 2 in the middle, and 2 in back of both side rails. Front to back doesn't make a difference because it was covered completely. The Tundra bed is 5'6" and the Dodge Ram bed is 5'7" so it fit just fine front to back. I also had to re-drill the front plate to get the nut and bolt to fit on the front. Make sure to line up the Bakflip perfectly before drilling. I love these Bakflip bed covers!
  4. Jan 26, 2024 at 9:22 AM
    SD Surfer
    Bruce
    So Cal
    $200 bucks is a good deal... although technically you're into it for $200.60 - that's kinda' steep. :rolleyes:
    That's cool it worked out.
    JayKay[OP] likes this.
  5. Jan 26, 2024 at 3:01 PM
    JayKay
    Lolll
