Ball joint grease type?
Discussion in '1st Gen Tundras (2000-2006)' started by BlueGarden, Jan 26, 2025.
  1. Jan 26, 2025 at 1:58 PM
    BlueGarden
    BlueGarden [OP] New Member
    Paducah, KY
    2002 Tundra Limited 4x4 4.7L
    I've searched and can't find a definitive answer. What type of grease should be used for ball joints? I have found that NLGI #2 grease is needed, but I can't find anything that says whether to get lithium, moly, or whatever the base should be for sure.
    Thanks!
  2. Jan 26, 2025 at 1:59 PM
    NickB_01TRD
    Nick
    KY
    01 Tundra V8 4X4 AC SR5 TRD
    What ball joints are you putting grease in? Lower and upper ball joints don't have grease zerks if they are OEM.
    PNW15 and FrenchToasty like this.
  3. Jan 26, 2025 at 2:09 PM
    BlueGarden
    Paducah, KY
    Ah, well that might explain why I can't find info on that. I have oem lowers.
  4. Jan 26, 2025 at 2:20 PM
    bfunke
    bfunke Tundra Curmudgeon
    South Carolina
    If your LBJs are original. Replace with new OEM ASAP. Also read Shity’s megathread.
  5. Jan 26, 2025 at 2:52 PM
    MT-Tundra
    MT-Tundra Agnostic Gnostic
    Montana
    2002 AC 4wd V8 Limited
    Lowers come packed with grease and should last the life of the joint. Uppers come with a grease packet, you pack it in during install, and it should also last the life of the joint.
    BlueGarden[OP] and KNABORES like this.
  6. Jan 26, 2025 at 5:46 PM
    BlueGarden
    Paducah, KY
    I replaced them myself a while back with oem. Just apparently didn't remember that they don't have zerks.
  7. Jan 27, 2025 at 8:22 AM
    FishNinja
    FishNinja HIDE YOUR DAUGHTERS
    Lee
    TEXAN....big surprise
    06DC2wd
    Life span of OEM LBJ's is 90-100k
    shorter if you take your truck off the beaten path.
