Ball joint issues after leveling kit installation?
Discussion in 'Suspension' started by Toy truck, Apr 25, 2019.
  1. Apr 25, 2019 at 4:09 PM
    Toy truck
    Toy truck [OP] New Member
    2014 SR5
    I have been looking at different forums and about 50% claim to have ball joint issues after installing leveling kit . Any advice would be appreciated . thanks in advance
  2. Apr 25, 2019 at 4:27 PM
    Lots of different UCA's on the market that have more play
  3. Apr 25, 2019 at 4:43 PM
    15whtrd
    15whtrd Mr. Blonde
    A leveling kit as in how much? 2 inches in the front you should be fine. 3 inches is marginal and some need to go after market UCA to get it into spec. The pro comes with a 2 inch lift in the front on stock UCA’s.
    TXRailRoadBandit73 likes this.
  4. Apr 25, 2019 at 5:55 PM
    I run SPC uppers. Zero issues
    Black Wolf likes this.
  5. Apr 25, 2019 at 5:59 PM
    Ahhh.. zero issues......heh...heh...
  6. Apr 29, 2019 at 11:17 AM
    Justin@bajakits
    Justin@bajakits Suspension dude
    Justin
    California
    07-17 Tundra: Bajakits chase kit demo vehicle
    Bajakits Chase kit: UCAs with king 2.5 coilovers Bajakits Rear Chase kit: Deaver F85 pack with King 2.5 Remote Resi.
    So the issue rests strictly on the spacers. This is due to the spacer forcing your suspension downward giving you the leveled look, but ultimately giving you a ticking time bomb. Even for the lightest use only time will permit the fail. Since the suspension is now forced downward making the upper control arm "reaching" if you will. Thus making the ball joint sit at an excessive angle.
    All looks OK. Until, many rail road jumps, parking lot speed bump runs, and driveway entries/exits along with your potential off road adventures leads to the fail. To avoid this an upper control arm will save you the headache like the setup we have below. Giving you ease of travel up and down along with a MUCH stronger UNI-BALL VS a limited ball joint. Feel free to check out our website! WWW.BAJAKITS.COM
    [​IMG][​IMG]
    Darkness likes this.
  7. Apr 29, 2019 at 11:54 AM
    Wiscdave
    Wiscdave New Member
    Northern Wisconsin
    19 Tundra Sport
    Old ride 13 RW BA budget, 3/2 lift JL W7
    ran billy's at 2.5 for 80k, no problems.
  8. Apr 29, 2019 at 12:09 PM
    Justin@bajakits
    Justin
    California
    Here are a few examples of the issue off of a quick google session. Each case is obviously different but the examples below are the most common on any vehicle some are much worse and end up in major body damage to the truck or a major accident as well. personally experienced a spindle rip off due to failed ball joint due to this issue on a fellow truck owners vehicle. Twas a scary day
    IMG_0067.jpg strut_fail.jpg spacer1.jpg damge from spacer lift1.jpg LPOR-SPACER-Lifts-FAIL.jpg
  9. Apr 29, 2019 at 12:13 PM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    Last one is scary
    Justin@bajakits likes this.
  10. Apr 29, 2019 at 12:28 PM
    Berdine
    Berdine Voodoo Sport
    Binghamton, NY
    2020 VooDoo Blue Trd Sport
    2nd pic down doesn't have bump stop extensions. Hard to tell with the others. There are alot factors that go into play also, not just the leveling kits.
    15whtrd and Justin@bajakits like this.
  11. Apr 29, 2019 at 12:33 PM
    Justin@bajakits
    Justin
    California
    Your very right, lots of variables. However the principle is there and many can attest to the affects of a spacer kit. The guy that only sees street and drives 6k a year is going to see different affects than a guy that goes in the dirt daily or jumps train tracks on the way to and from the local beer run at his local market. But take the chance on your daily rig? To each his own LOL :oldglory:
    Berdine[QUOTED] likes this.
  12. Apr 29, 2019 at 12:37 PM
    Berdine
    Binghamton, NY
    Exactly, I'll never go spacer kit again. Do it right the first time, then less problems later on down the road.
  13. Aug 5, 2024 at 8:28 PM
    mkjprice
    mkjprice New Member
    2004 Tundra Crew Cab
    3" Puck Lift - lots of rust repair
    My Son's 2004 Tundra has this exact issue. The ball joint is an OEM Toyota replacement put in by a reputable shop about 1K miles ago. His truck is limited off road use, and mostly a commuter around our small town. We have replaced all bushings, and even the lower control arm on this side of the truck. Do we need the extended upper control arms to remedy the destruction of ball joints?
  14. Aug 14, 2024 at 4:02 PM
    gubbs
    gubbs New Member
    2000 tundra
    Did you find a solution to the Upper ball joint being stuck between the spring? I put a 3 inch leveling kit on my 2000 tundra and can get the Upper ball joint to not rub or get stuck in between the springs.
