BATTERY CHANGE...
Discussion in '2.5 Gen Tundras (2014-2021)' started by BCB, Apr 27, 2025 at 12:14 PM.
  1. Apr 27, 2025 at 12:14 PM
    BCB
    BCB [OP] New Member
    Yesterday
    BRADLEY
    '21 TUNDRA SPORT
    RUNNING BOARDS & WINDOW VISORS
    Recently had to change the battery in my '21 Tundra...
    I contacted the service department where I purchased the truck and asked if disconnecting the battery would cause problems--They said "no"...(I heard it might)
    Well, all's well, EXCEPT, the "Range" in miles of gasoline in tank...
    When I fill the truck, it says I have a range of 590 miles--Ahhhhh, NO way...
    Usually it said 420 or there about after fill up, before battery change...
    Any thoughts--Is there a reset on it...
    Thanks...BCB
  2. Apr 27, 2025 at 12:16 PM
    Tyman
    Tyman Isaiah 41:10
    Tyler
    Indiana
    2020 Tundra Sport 4wd MGM
    It’s fine. It will recalibrate.
    23Tundy, NewImprovedRon and 1lowlife like this.
  3. Apr 27, 2025 at 12:19 PM
    1lowlife
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    @Tyman is correct, it will recalibrate.
    Might take 3 or 4 tankfuls of gas until the ECU figures your average MPG..
    How do you reset it?
    You reset it when you disconnected the battery..:thumbsup:
    You can also press and hold the ENTER button on the steering wheel to reset it.
    23Tundy and NewImprovedRon like this.
  4. Apr 27, 2025 at 12:22 PM
    Joe333x
    Joe333x Member
    Boston
    2019 Tundra CrewMax Platinum
    As stated, it will recalibrate, but if you'd like to change your battery seamlessly next time, if you have a jumper back or another battery you can connect the cable to the power and ground leads before disconnecting the battery and make sure they stay connected until the new battery is connected.
  5. Apr 27, 2025 at 12:32 PM
    BCB
    BCB [OP] New Member
    Yesterday
    BRADLEY
    '21 TUNDRA SPORT
    WoW, that was quick...
    I was hoping it would reset once it figured out what type of average mileage I get...
    Sure wish it got 590 miles from a full tank of gasoline...
    Thanks All Who Replied...
  6. Apr 27, 2025 at 12:34 PM
    1lowlife
    DADA
    2014 MGM DC SR5
    My 26 gallon tank will read over 400 with a reset.
    It comes down to around 315 after a couple weeks..:mad:
