Battery dies after long idle
Discussion in '2nd Gen Tundras (2007-2013)' started by Hi McDunnough, Jan 29, 2022.
  1. Jan 29, 2022 at 4:33 PM
    Hi McDunnough
    Hi McDunnough [OP] New Member
    I have a mystery problem w my 2009 tundra. This has happened 3 times with a good battery. Each time I have the truck idling in park, waiting. Say 25 min then have shut the truck off and kept waiting. When I go to start the truck again the battery is dead. I’m stumped. Any ideas?
  2. Jan 29, 2022 at 5:24 PM
    Danman34
    Danman34 New Member
    Danny
    2018 White Tundra TRD Sport
    Sounds like the alternator is going bad. The battery only starts the vehicle. Once running, the alternator supplies running voltage to keep it running. If the alternator isn’t functioning, power is drawn from the battery. Sitting in idle is just pulling power from the battery so when you turn it off and try to restart, there isn’t enough amperage
  3. Jan 29, 2022 at 5:41 PM
    Cock-A-Doddle-Do
    Cock-A-Doddle-Do New Member
    Brett
    Cypress, Texas
    2021 TRD Off Road CM -Super White
    ^^This^^
    Hi McDunnough[OP] likes this.
  4. Jan 29, 2022 at 7:09 PM
    Danny3737
    Danny3737 New Member
    2012 Tundra Limited Platinum
    You can hook up a volt meter to the battery and check the voltages, but my bet is the alternator as well.
  5. Jan 30, 2022 at 1:26 AM
    NueveTundra
    NueveTundra Mod list in Bio
    Planet Earth
    07, Black Tundra SR5 CrewMax
    If you are still sitting in the truck after its turned off, but no one has gotten out of it. Most likely head lights or DRL is draining the battery. The lights won't auto off unless a door is opened after shut off. (DRL stays on even if lights off) found that out the hard way. If this sounds like your situation/scenario it could be the cause. (Maybe also leaving key in ignition after off with out doors opening was part of it)
    I didn't think about it till it happened to me at a park since I was use to auto off. Played with my dogs some then started my truck to get it warm enough shut it off and toke a nap to pass the time waiting on a random inspection to be done. Woke up freezing and went to start up and realized I never opened the door since it was turned off. Had to wait for AAA to come jump me so I could get home. :rofl:
    Yzed608 likes this.
  6. Jan 30, 2022 at 6:37 AM
    Yzed608
    Yzed608 New Member
    Wisconsin
    That's some good info, didn't know that. I wonder if there's a purpose for it behaving that way?
  7. Jan 30, 2022 at 6:49 AM
    COTundie
    COTundie Whoa Black Betty
    Trey
    Black 5.7 DC TRD 4x4
    Pretty things
    Sounds like Toyota has changed a few things on this platform over the years (duh).
    A couple weeks ago I was unloading materials with the truck was running, as I thought I was going to have to move afterwards. Turns out I didnt have to move and ended up opening the passenger door and reaching through to shut off the truck... About 3 hours later I noticed my lights were still on. So, at least on my 2012, it is specifically the driver's door which needs to be opened after shutoff or the lights will remain illuminated.
    Also think the OP's issue is a gracefully dying alternator.
  8. Jan 30, 2022 at 6:54 AM
    COTundie
    Trey
    Pretty things
    The purpose, I believe, is for "courtesy lights". Should start the countdown (1 minute?) for the auto off feature. Some people dont like walking in dark parking lots
    If you hit the lock button twice it will cancel the courtesy lights and they will turn off upon the second click... In my 2012 anyway.
