Battery Gauge Dancing Around
Discussion in '3rd Gen Tundras (2022+)' started by joescho, Oct 24, 2022.
  1. Oct 24, 2022 at 10:00 AM
    joescho
    joescho [OP] New Member
    Joe
    Scranton,PA
    2024 Supersonic Red Platinum
    I'm sure all of us once in a while get the "Battery Charging" message. Seems that for the past few days my battery gauge has been moving up and down between the tick to the left of center to the tick right of center. When I'm on the gas, its to the left of center. When I leave off, the needle move to the right of center for about 5 seconds, then moves back. If I'm still coasting after that, a few seconds later its back to the tick right of center. When I go back on the gas, it moves back to the tick left of center, and so on...
    Battery? Alternator?? I need to make an appointment I guess. I think something is about to die.
    Joe
  2. Oct 24, 2022 at 10:03 AM
    HulkSmurf14
    2014 Tundra Limited
    Tastefully enhanced...
    I'd check your connections on your alternator and if "good" I would default your assumptions to needing a new battery...
  3. Oct 24, 2022 at 10:45 AM
    timsp8
    NY
    There was another thread about this where the consensus was that’s it’s normal for the 22s. My 18 moves up when giving it gas and back down when RPMs drop like when I’m coasting or idling.
    But since you’re under warranty, you could get it checked out so it’s documented if something fails later. Just make sure they don’t charge you a diagnostic fee.
  4. Oct 24, 2022 at 11:33 AM
    joescho
    Joe
    Scranton,PA
    That's a good idea. Once its documented I would at least have some leverage.
  5. Oct 24, 2022 at 2:45 PM
    Coasty
    Coasty New Member
    Pat
    Oregon
    2022 SRS Crew Max 6.5 4x4
    Thats modern electronics at work. Apparently that's how modern vehicles charge the batteries now, it's on demand rather than a constant 13 volts. My wife's Ridgeline's voltmeter is rock solid when it's running but when you plug in a voltmeter to the charging port or even the battery you will see it's actually pulse charging the battery as well. If you do a search on here, a guy has a full spreadsheet that dives deep into this.
    Snomej likes this.
  6. Oct 24, 2022 at 4:28 PM
    xc_tc
    xc_tc New Member
    That’s normal, the alternator charges the battery on deceleration because it doesn’t use any fuel and it stops charging the battery on acceleration or cruising to improve fuel economy. This will depend on the state of charge of the battery though. If the charge in the battery is too low, the alternator will keep a steady voltage on it. The left tick mark is around 12V and the center is around 14V.
    Snomej likes this.
  7. Oct 24, 2022 at 6:21 PM
    Snomej
    Snomej New Member
    Justin
    2022 Celestial Silver Platinum
    This is all normal. If it never fluctuated (or was in the bottom or top 25% when it shouldn’t be), I’d be more concerned. If it seems drastic, I’d blame that on hyper-accuracy with data on demand and a “zoomed in graph” if you will, if anything. The alternator is not constantly generating, your battery is under constantly variable loads, and your oil pump is going to work harder as you gas it so you’ll see pressure increase every time you increase in RPM
  8. Oct 24, 2022 at 7:25 PM
    aj350925
    aj350925 New Member
    They fill these trucks with very thin oil. They do this for MPG. These trucks will idle with very low oil pressure and it will go up when on the throttle.
    Snomej likes this.
  9. Oct 25, 2022 at 6:17 AM
    joescho
    Joe
    Scranton,PA
    I have learned all of the above seems true. I had them look at it this morning. Battery is fine, and the alternator is putting out what it should. I've had the truck since April and have never seen the battery gauge jump around like that but I guess that's how it all works
    Snomej likes this.
  10. Nov 5, 2022 at 4:15 PM
    Duke_962
    Duke_962 New Member
    Nwnj
    2022 tundra sr5 4x4
    Rci skid plate,
    100% normal. It’s for fuel mileage. Most new cars do this. No charge on acceleration. Full charge on braking. Just remember when you replace a battery it needs to be programmed or the truck will fri the new battery thinking it’s old.
  11. Nov 7, 2022 at 4:37 AM
    joescho
    Joe
    Scranton,PA
    what needs to be programmed? How would it fry it? Wouldn't the computer just measure the voltage in the battery and act accordingly?
    HulkSmurf14 likes this.
  12. Nov 7, 2022 at 3:01 PM
    Duke_962
    Duke_962 New Member
    Nwnj
    2022 tundra sr5 4x4
    Rci skid plate,
    So the module on the negative battery terminal monitors amps in and out(it’s a shunt). New cars and our truck use a flooded or agm battery which shouldn’t be charged at a steady voltage. They need high charge then low charge. When you accelerate the alternator drops for fuel and power then when you brake they load up for engine braking/regen if you want to call it that. When battery’s age the charging profile changes. If you just put a new battery in without telling the ecu it could overcharge or damage the battery with its charge profile. There are good YouTube videos about this with bmws killing batteries within a year or so. I’m vw Land we have to have speical 12 volt chargers/maintainers that vary load for these battery’s. These chargers are not cheap also. It’s all in telling the ecm it has a new battery to modify the algorithm. We scan the batteries bar codes and serial numbers to let the ecm know it’s been changed in vw I assume Toyota is similar. I can ask one of the toyota tech at my dealer tomorrow if it’s the same if you want.
