Battery isolator kit suggestions
Discussion in 'General Tundra Discussion' started by Ghostdriver, Feb 18, 2022.
  1. Feb 18, 2022 at 6:52 PM
    Ghostdriver
    Ghostdriver [OP] New Member
    Hey everyone! Looking to add a second battery to run a winch and some lights and what not, anyone have an isolator kit they would recommend? Looking for plug and play as much as possible but I’m comfortable with wiring! Just checking around before I order parts.
  2. Feb 18, 2022 at 7:34 PM
    AZTundra
    Paul
    Phoenix, AZ
  3. Feb 19, 2022 at 4:44 AM
    Ghostdriver
    Thanks, that does look like a really nice kit. But I’m not looking to spend that much if I can help it. I appreciate the link!
  4. Feb 19, 2022 at 6:32 AM
    WVI
    WVI New Member
    @008 Tundra Limited
  5. Feb 19, 2022 at 6:59 AM
    Ghostdriver
  6. Feb 19, 2022 at 7:19 AM
    helidave
    helidave Hellacopter
    flagstaff
    2015 DC 4x4
    Are you just trying to add battery capacity or do you plan to run a bunch of stuff off the second battery with the truck off?
  7. Feb 19, 2022 at 8:51 AM
    Ghostdriver
    I’d like to run some stuff with the truck off. The lights under my camper shell, cell phone charger. And a few other small things.
  8. Feb 19, 2022 at 9:13 AM
    helidave
    flagstaff
    2015 DC 4x4
    Two problems with that crutchfield kit: There's no disconnect between the two batteries to keeps from running the truck battery down, and a 22ah battery isn't going to last very long before it needs to be charged.
    you can look at the SDHQ kit parts list to get an idea what you'll need: Wire, terminals, a voltage sensing relay (bluesea ACR or similar), some way to mount the battery, and a battery.
  9. Feb 19, 2022 at 9:33 AM
    Ghostdriver
    Ok great information! Thanks! I’ll keep looking around and take another look at that kit
  10. Feb 19, 2022 at 9:37 AM
    Ghostdriver
    I’ve found a few kits on Amazon. Then I’d just need to add a battery.
  11. Feb 19, 2022 at 9:46 AM
    helidave
    flagstaff
    2015 DC 4x4
    Careful, some of those no-name kits come with cheap, small wires that are only good for low current and short lengths.
    http://circuitwizard.bluesea.com/#
  12. Feb 19, 2022 at 9:59 AM
    Ghostdriver
    Thanks! I appreciate the info.
  13. Feb 27, 2022 at 12:39 PM
    Ghostdriver
    Still kinda looking around for a complete kit to run a second battery in the bed of my truck…anyone done this? Suggestions?
