Battery voltage - how low is too low?
Discussion in '2.5 Gen Tundras (2014-2021)' started by TenorTundra21, Jul 22, 2024.
  1. Jul 22, 2024 at 3:38 PM
    TenorTundra21
    TenorTundra21 [OP] New Member
    Eric
    Transmission Oil Cooler TRD rear sway bar
    Hi Everyone, my truck has an original battery in it, exactly 3 years old. I had the alternator tested at Napa yesterday and it’s putting out somewhere around 13.5 volts. Cold crank amps are at 600. The battery charges while the truck is running but when I shut it off and wait a few hours sinks to 11.5 volts, sometimes lower. We are going on a big road trip in hot weather soon…should I replace the battery?
    Thank You
  2. Jul 22, 2024 at 3:44 PM
    Gene_in_FL
    Gene_in_FL SUPER genius
    FLORIDA
    2016 SR5 DC 5.7 2021 SR5 DC 5.7
    Absolutely yes
  3. Jul 22, 2024 at 3:58 PM
    d33pt
    d33pt New Member
    Lower than 12.5 is not good.
    Retired...finally likes this.
  4. Jul 22, 2024 at 3:58 PM
    Retired...finally
    Yep. 12.5 would be a normal reading after a few hours .....unless you have a serious parasitic drain.
    Gene_in_FL and FrenchToasty like this.
  5. Jul 22, 2024 at 4:03 PM
    Bonzen
    Bonzen Solid Offroad motor & transmission mounts
    Lake Havasu City, AZ
    Most EFI systems will not even run correctly or send enough voltage to the fuel injectors to fire if the battery voltage during key-on/crank is around 10 volts. So it sounds like you have a bad cell, that is turning your battery into a resistor as opposed to a capacitor. Definitely replace it.
  6. Jul 22, 2024 at 4:19 PM
    Cruiserpilot
    Cruiserpilot New Member
    Jon
    Ladysmith
    2010 5.7 RCSB 4WD
    Take it to a diagnostic place. This isn't a battery issue. Batteries die for a lot of reasons, but generally not just sitting there
    unless you have an electronic dead short. It could be a dead cell, have the battery tested. Have you installed anything lately or changed anything? Double check connections
    especially any and all grounds.
    But primarily have your alternator load tested and looked at. I suspect you may have a diode issue on your alternator, and
    that will be an ugly road side failure on a road trip. So get it looked at ASAP.
  7. Jul 22, 2024 at 4:26 PM
    BoysandHisToys
    BoysandHisToys New Member
    Central Virginia
    2013 Tundra Crewmax Limited
    12” Bulletproof Lift, AFE CAI, AFE Exhaust, rock lights, Fas-Top tonneau and soft topper, Dasaita 10.2” radio, light bar, ditch lights, LED headlights and fog lights, LED interior lights, Amp Research rear bumper step, dashcam, BT ODBII reader and Torque app on radio
    I’ve been chasing a parasitic draw for awhile on my truck. Doesn’t go dead in hours like you mentioned, so maybe there is an issue with your alternator as Cruiserpilot mentions.
    I think I’ve isolated mine down to a front camera I had in my bumper.
  8. Jul 22, 2024 at 7:42 PM
    TenorTundra21
    Eric
    Thanks everyone! I think I may have jumped the gun. I have one of those VeePeak OBD II Bluetooth diagnostic plugs I got with our Genuine Cooling Systems kit trans cooler kit. I got the OBD fusion app off of the App Store as well as the Toyota extension. This gave me a number of dashboards to look at on my phone. One of them called “Battery” which registered 11.4 volts. I just double checked this with a volt meter at the battery terminals and they actually read 12.5 volts! I wonder why the VeePeak reads so much lower voltage. I now think the battery is probably fine! Strange. Anyhow thanks for all the great battery and alternator info, I learned a lot!
  9. Jul 22, 2024 at 8:51 PM
    Cruiserpilot
    Jon
    Ladysmith
    2010 5.7 RCSB 4WD
    Grrrrr....f'n computers! That's why when I want to go on a long road trip I take my mechanically direct injected JDM diesel
    that will still run without an alternator! Take a portable power booster on your trip, ya know, just in case...
    HulkSmurf14 likes this.
  10. Jul 24, 2024 at 12:26 PM
    frichco228
    frichco228 Valued Member
    2016 Crewmax 4WD, TRD Offroad
    3 year old factory battery = time for a new battery
  11. Jul 24, 2024 at 12:33 PM
    texasrho83
    texasrho83 DGAF#1
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Yup, replace.
    One good reading isn't necessarily proof positive you're in the clear. You need to monitor over a week or two to look at the readings to see if there's an irregularity, and if so, that battery can still be defective.
  12. Jul 24, 2024 at 12:39 PM
    Danman34
    Danman34 New Member
    Danny
    2018 White Tundra TRD Sport
    13.5 running voltage is 100% normal. It’s a voltage regulated system, so you’re never going to see anything at or over 14 volts aside from a brief few minutes on a cold start. 3-4 years is the norm these days for battery life. It’s not going to hurt to get a new one. If anything, it’ll give you peace of mind, which is priceless haha
