Baxter Performance spin on filter adaptor
Discussion in '2.5 Gen Tundras (2014-2021)' started by Kentucky22, Sep 30, 2024.
  1. Sep 30, 2024 at 4:34 PM
    Kentucky22
    Kentucky22 [OP] New Member
    21 Tundra Limited 4x4
    Anybody try the Baxter Performance spin on oil filter adaptor?
    I’m not a fan of the cartridge style filter my Tundra uses.
    Mdl likes this.
  2. Sep 30, 2024 at 5:29 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    JBA Longtubes, Snivs 2.0 SC pulley, ASP crank overdrive pulley 6.71 in, DD Full 3inch dual exhaust, IPT valve body, Airbox mod, 4.5inch intake, Denso 750, 450 Walbro, W/M injection, GM 95mm TB, SABM, Camburg UCA, Icon shocks, Speedmaster LSD, Motive 5.29 Gears, Mickey Thompson Baja Legend EXP 35's, DIY Traction Bars, Tuning by snivspeedshop.com
    I have it with an engine oil cooler sandwich plate. Works great. I spoke with Baxter tech and the only issue they ever had were with loose sway bars coming in contact with the oil filter. I'm running a filter that is 3/4 of an inch shorter than the wix that they recommend. The sandwich plate is 1 inch thick and didn't want filter too low.
  3. Sep 30, 2024 at 6:01 PM
    Dave8699
    Dave8699 Trackrat
    David
    NJ
    04 Tundra AC, 2014 Tundra 1794 Crew Max
    Whole truck Raptor liner in olive green, leer camper cap, 5100 with OME, Wheelers AAL and Firestone Air bags.
    Was just looking at this over the weekend, didn't find to much information. Seems like it's a 50-50 decision. I personally was looking to see if anyone had any issues and I believe the spin on filter is better then a cartridge.
  4. Oct 1, 2024 at 2:50 AM
    Kentucky22
    Thanks for the replies
  5. Oct 1, 2024 at 4:58 AM
    Dave8699
    Dave8699 Trackrat
    David
    NJ
  6. Oct 2, 2024 at 4:22 PM
    seydou
    seydou Distinguished Member
    Why do you believe that?
  7. Oct 2, 2024 at 4:25 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    If I could of found a Lexus RCF cartridge remote oil cooler setup I would of kept it. I only went with Baxter to be able to run an engine oil cooler.
    bulldog93 likes this.
  8. Oct 2, 2024 at 4:26 PM
    Dave8699
    Dave8699 Trackrat
    David
    NJ
    Better I meant like it's faster and easier not better like it functioning.
    ForceV4 likes this.
  9. Oct 2, 2024 at 4:33 PM
    seydou
    Gotcha. Although there are ways to make draining the oil from the filter
    housing easier prior to its removal
  10. Oct 2, 2024 at 4:35 PM
    Dave8699
    Dave8699 Trackrat
    David
    NJ
    Yea going to look some options up. Just came from a 1st gen so I haven't had the need to change oil yet. Just want to be prepared
  11. Oct 2, 2024 at 4:39 PM
    seydou
  12. Oct 2, 2024 at 5:59 PM
    Jaypown
    Jaypown New Member
    Justin
    Rubber City
  13. Oct 2, 2024 at 5:59 PM
    pursuit2550
    pursuit2550 New Member
    2020 Tundra SR5 Maggie 1900
    What's the reason your not a fan? When I ran across the Baxter design, all I could think was, that only positive thing I could see is, that you can add an external oil cooler. Other than that, it's still filters the oil the same as the OEM cartridge filter. What I didn't like was the video on the site. He lies and says that Toyota cartridge filter suck because there is no drain back valve like a spin on filter. Apparently Kevin didn't do his research. The majority of all the cartridge filter always have oil. So his selling point of getting oil quickly to the engine is not a selling point. I personally didn't see the point of spending $280 just to have a spin on filter.
  14. Oct 3, 2024 at 5:04 AM
    ejes
    ejes New Member
    2020 1794 Tundra / 2023 4Runner TRD PRO
    I personally like the fact that I can examine the filter cartridge at each OCI without having to cut open a can.
    bulldog93, pursuit2550 and Dave8699 like this.
  15. Oct 3, 2024 at 5:06 AM
    Dave8699
    Dave8699 Trackrat
    David
    NJ
    Very good reason
  16. Oct 3, 2024 at 5:53 AM
    BreyTundy
    BreyTundy Big 4Lo Guy
    Andrew
    Colorado Springs
    2016 White DC TRD
  17. Oct 3, 2024 at 6:39 AM
    pursuit2550
    When I ordered that kit it came with a different oil filter cap wrench. It wasn't the one pictured. It sucks and gets stuck to the cap. Not a big deal since I have another one that works good. The other parts are great for the oil change.
  18. Oct 3, 2024 at 6:43 AM
    BreyTundy
    Andrew
    Colorado Springs
    2016 White DC TRD
    Damn, good to know. Does the bolt replace the oil drain full time like the fumoto valve? Probably should have done a little more homework before I clicked order
    pursuit2550[QUOTED] likes this.
  19. Oct 3, 2024 at 7:03 AM
    ejes
    ejes New Member
    What I think you are referring to as a "bolt" is not for draining the oil pan. That's a valve tool for draining the oil out of the oil filter housing. You screw it into the drain plug access and it pushes the ball valve in there "up". Then unscrew it to open the bottom portion which is it's valve to drain out the housing. It makes more sense once you use it.
    I bought this kit 4-5 years ago and have no trouble with the filter housing wrench, but it does not look like the current one pictured. It has the cutouts for the housing, like this: https://ecx.images-amazon.com/images/I/51W7nMcCl+L.jpg?w=650
    The funnel is very helpful, the wrench I have works good, but honestly I don't use the filter housing drain tool. It is more of a pain to use than the little plastic tool that comes with all the filter cartridges. I just use the little plastic tool with a hose attached to it to drain into the pan.
    bulldog93 and BreyTundy[QUOTED] like this.
  20. Oct 3, 2024 at 7:05 AM
    BreyTundy
    Andrew
    Colorado Springs
    2016 White DC TRD
    Gotcha, thanks for the reply!
    ejes[QUOTED] likes this.
  21. Oct 3, 2024 at 11:40 AM
    Jaypown
    Jaypown New Member
    Justin
    Rubber City
    Mine came looking exactly like the one in the Amazon link. Grey with a red section for the ratchet. I haven't had any issues with mine getting stuck.
    My last change, I was able to leave the thin black skid plate on and was able to get a 3/8" ratchet up there to loosen the drain bolt, attach the provided drain hose and drain the oil out into a bucket and was even able to remove the entire filter all at once. For me, this kit makes the job so much easier. Not to mention the fumoto valve on the oil plan is also a nice addition.
    EDIT: I only purchased mine around a year ago or so. So maybe they've changed a little bit since when @ejes bought his.
  22. Oct 3, 2024 at 11:49 AM
    pursuit2550
    Like they said above, it's for the oil filter drain. I did also I stall a fumoto valve. It also makes it much easier and no mess.
  23. Oct 3, 2024 at 11:53 AM
    BreyTundy
    Andrew
    Colorado Springs
    2016 White DC TRD
    Yeah I'm going to pick up a Fumoto valve as well. Seems like a no-brainer
  24. Oct 3, 2024 at 12:02 PM
    Bprose
    Bprose Old member
    VA
    17 Tundra CM TRD
    I used to have fumoto and loved the convenience of it. The one on my truck started a very slow dribble. Never saw a puddle but it was always wet and I’d clean it after oil changes. Switched to valvomax. Only thing is you have to have adapter with you if you do an oil change, not a problem if you’re home. Zero leaks or spills.
    Snert likes this.
  25. Oct 3, 2024 at 12:18 PM
    Snert
    Snert New Member
    2021 SR5
    +1 for the Valvomax and MotivX. Only thing I dislike about the Valvomax is you need the additional screw on thing + hose to open the ball valve, and if you lose that it becomes a very pricey drain bolt plug lol, but other than that I love the design and the drain hose thing. I bought the MotivX and a generic Amazon hose thing rather and it works perfectly. I skipped the blue funnel and just use the Valvomax and MotivX and didn't spill a drop when I changed my oil last time.
    Bprose[QUOTED] likes this.
  26. Oct 4, 2024 at 7:02 PM
    MarkM0369
    MarkM0369 New Member
    Mark
    2017 Tundra SR5 4x4
    275/70 KO2, Pro Hood Bulge and grille, OEM fender flares, Fox rear shocks
    The worse part of the cartridge filters is getting the filter housing off, get a decent Toyota filter wrench that will fit over the “ears” of the housing and not just the lower portion, on the wife’s camery, the thing was on so tight I broke one of the “ears” off and basically ruined the housing as it caused a leak, junked the plastic housings and bought an aftermarket aluminum one, works great, for the tundra it actually has a longer cartridge, the center pipe is a bit longer so has to be moved to the new aluminum housing but easy enough.
  27. Oct 4, 2024 at 7:13 PM
    SoCal_Erik
    SoCal_Erik New Member
    2023 SR5 Sport 4x4, 2016 4Runner
    x2. Every at home mechanic needs this. Game changer.
    Jaypown[QUOTED] likes this.
  28. Oct 7, 2024 at 4:36 PM
    BreyTundy
    Andrew
    Colorado Springs
    2016 White DC TRD
    Received my Motivx kit today, it is as pictured. Haven’t used it yet, but first Impression is that everything is super high quality. Will report back on fitment after I change my oil this weekend
    Leo's first and Dave8699 like this.
  29. Oct 12, 2024 at 5:49 PM
    BreyTundy
    Andrew
    Colorado Springs
    2016 White DC TRD
    First use report: this kit is absolutely worth the money. The fitment over the oil filter housing was right on the money, and the drain tube and screw in funnel were super nice to have. I accidentally snapped off a cheap extension in the center section of the oil filter wrench, but since the red area fist a 24mm socket, I was able to slap one on and spin the filter housing off with an air impact wrench (fkn thing was on there from the last oil change at Toyota). Anyways, if you’re on the fence about buying this kit, don’t be. It’s well worth it
    Motivx Tools Oil Filter Wrench,... https://www.amazon.com/dp/B0791MWXDC?ref=ppx_pop_mob_ap_share
    ejes, BrandonL812 and Jaypown like this.
  30. Oct 13, 2024 at 4:07 PM
    pursuit2550
    No issue with the filter cap getting stuck in the filter wrench? Do you have a plastic or aluminum oil cap?
