Bed Drain Plug
Discussion in '3rd Gen Tundras (2022+)' started by Lunar * Rock, Nov 24, 2023.
  1. Nov 24, 2023 at 4:14 AM
    Lunar * Rock
    Lunar * Rock [OP] New Member
    Hey y’all,
    I’m a new member here and still learning the ropes so please excuse me if these have already been asked.
    So I just purchased a 24 tundra and am planning on putting a bed cover on it. After weighing out the pros and cons I’ve decided to go with the Bakflip mx4.
    But…I have 2 questions.
    1. According to the manual, my bed is 66in (5ft 6in). I see some stores show the same cover for my year as 5.5 and some show 5.7. I’m guessing this is the one I’d want right?
    2. I looked in the bed and don’t see a drain plug. Where do you run the drain tube without drilling into the metal? Please post pics for reference.
    Thanks in advance.
  2. Nov 24, 2023 at 7:59 AM
    Soflo
    Soflo New Member
    Tom
    Miami, FL
    2022 Tundra TRD off road
    What’s wrong with stock?
    The bed is composite, aka tough plastic. There should be 4 pre drilled holes all the way forward by the cab. The hose with my OEM cover fit the holes, others have stated that they needed to make holes bigger especially if they had the spray in liner installed. I cut the hose at an angle and fed it through the hole. This picture is the drivers side. The passenger side is the same. You can see the hole in the corner a the other hole is where tube is fed through.
  3. Nov 24, 2023 at 8:18 AM
    Breathing Borla
    Northern Illinois
  4. Nov 26, 2023 at 8:56 AM
    PNW Tundra Mike
    Southern Cal
    MX4 Tonneau, Talon's Trans/Cat Shield
    Just enter your truck specs. You’ll get the right one. Drains are simple.
  5. Nov 26, 2023 at 9:02 AM
    Lunar * Rock
    I did but can’t even get a 1/4 in barb in the hole of my bed and don’t want to drill
  6. Nov 26, 2023 at 10:08 AM
    gmcguire7220
    gmcguire7220 New Member
    Ontario Canada
    2022 Limited TRD OR Crewmax - WCP- 2019 Toyota RAV4 Hybrid XSE
    TRD running boards & Falken Wildpeak tires
    Drill a new hole above the bed tie down
  7. Nov 26, 2023 at 10:26 AM
    Breathing Borla
    Northern Illinois
    He wants 0 drilling
    going to have to find a barb or fitting that will slide in the existing hole, just go to Menards or something and buy a few, super cheap
    otherwise follow what I did with the drill bit size I had for the existing hole , your only cleaning it out a touch and it take two seconds , good luck op
  8. Nov 26, 2023 at 11:45 AM
    ES Tundra23
    ES Tundra23 New Member
    Eastern Shore, MD
    2023 Tundra HV 4x4 Limited CrewMax 6.5 MGM
    Hey Lunar,
    Just take the correct size drill bit & tap it into the hole & spin it with your finger to clean out over spray from bed liner spray.
    You are not making the hole any bigger or removing any metal/composite/etc, just cleaning it up.
    It's ok man, you are not hurting anything by cleaning out the over spray on your truck bed holes!
    Push drain line hose into holes a good 4-5 inches & they will never come out unless you cut them or pull them out accidentally when removing something from the truck bed.
    BackFlip MX4 instructions say to use the middle holes in the truck bed but I used the ones closest to the corners.
    Looked under truck to make sure drain hoses would not be draining on anything important or pooling up anywhere.
    Just drains to the ground.
  9. Nov 26, 2023 at 11:46 AM
    ES Tundra23
    Eastern Shore, MD
    Why do you want a barb?
    Why don't you just want to stick the drain hose in the truck bed holes like the instructions tell you to?
  10. Nov 26, 2023 at 12:04 PM
    gmcguire7220
    Ontario Canada
    i did see he mentioned that - but I figured someone may have mentioned that he isn’t drilling through metal, as it’s a composite bed. I meant to but forgot to say so myself, ( I was happy I found my old photo truthfully) :)
    As with all things, plans can change - if his did then it’s an option that’s all. :thumbsup:
  11. Nov 26, 2023 at 7:38 PM
    PNW Tundra Mike
    Southern Cal
    Love how that looks/works. I’m gonna do the same. Eliminate the long hoses and free up those two bed drains again. Thanks!!
    gmcguire7220[QUOTED] likes this.
  12. Nov 26, 2023 at 7:44 PM
    Lunar * Rock
    I hope mine comes with that drain line that you have and not the threaded one that’s larger
  13. Nov 27, 2023 at 12:37 PM
    gmcguire7220
    Ontario Canada
    Mine is from the backflip MX4
    PNW Tundra Mike likes this.
