Bed Extender
Discussion in '2.5 Gen Tundras (2014-2021)' started by soarvet, Jan 3, 2018.
  1. Jan 3, 2018 at 9:55 AM
    soarvet
    soarvet [OP] New Member
    2017 Silver Tundra Crewmax 4x4 XSP package
    Hey Guys,
    Just wanted to post this just in case you are on the fence on adding a bed extender and you have the BAK Revolver X2. Because of the aluminum catches that lock the tonneau down you won't be able to swing the bed extender in to the bed or out onto the tailgate. It hits the catches. I had to just sit the extender in the slots and I just remove it and flip it if I need it on the tailgate or inside the bed. Still works great, just lose the rotating feature.
    I was kinda bummed after I installed it, but decided to keep it because it does help with the groceries.
    T500 likes this.
  2. Mar 14, 2018 at 8:29 PM
    Tony v
    Tony v Member
    2017 SR5 CrewMax
    The manufacturers of the covers need to consider the use of bed extenders. I had a similar issue with the Extang 2.0 and had to cut in the latches to make it work.
  3. Mar 15, 2018 at 3:52 AM
    Njmike13
    Njmike13 New Member
    Hunterdon county, NJ
    2021 PRO Lunar Rock
    I have the revolver x4. I bought a tailgate net and attached it to the rail system and the bed tie downs. I mainly use it to keep thing from sliding forward. The other plus is the net was $20 instead of $250 for an extender.
    mlucas555 and SocaliTundra958 like this.
  4. Mar 15, 2018 at 4:02 AM
    SocaliTundra958
    SocaliTundra958 New Member
    Temecula
    2018 SR5 CREWMAX TUNDRA
    stock
    Do you have the link for the net your talking about and picture by any chance
  5. Mar 15, 2018 at 4:30 AM
    71_340
    71_340 The German
    Hans
    FLW, MO
    That is really a great idea. Could you post a photo of your setup?
  6. Mar 15, 2018 at 5:09 AM
    Njmike13
    Njmike13 New Member
    2021 PRO Lunar Rock
    I'll post s a pic later this afternoon
    71_340 likes this.
  7. Mar 15, 2018 at 1:47 PM
    Njmike13
    Njmike13 New Member
    2021 PRO Lunar Rock
    Here's what I use. Got it on Amazon for about $20. My main use is to keep things from sliding forward.
    SouthBoundSteve, mlucas555 and 71_340 like this.
  8. Mar 16, 2018 at 5:08 AM
    71_340
    71_340 The German
    Hans
    FLW, MO
    That looks like a very good and cheap way to keep stuff from sliding forward. I will copycat your idea since I am the one doing all the grocery shopping.
    How do you secure the bottom corners?
  9. Mar 16, 2018 at 5:58 AM
    Njmike13
    Njmike13 New Member
    2021 PRO Lunar Rock
    I used a piece of flat webbing to attach both straps to one another. The webbing then goes under the mat. It hasn't moved and works well for what I need.
  10. Mar 16, 2018 at 6:00 AM
    ChucklesToy
    ChucklesToy Retired
    Chuck
    Round Rock, TX
    2024 Tundra Limited 4X4 Nightshade Blueprint
    DiamondBack SE, AMP PowerSteps,
  11. Mar 19, 2018 at 1:55 PM
    Hermel
    Hermel New Member
    Mark
    Virginia Beach
    ‘15 White DC TRD Pro
    I like this idea. Just need to figure a way to secure the bottom corners without a mat.
  12. Mar 19, 2018 at 2:55 PM
    Njmike13
    Njmike13 New Member
    2021 PRO Lunar Rock
    Even without the bottom corners tied down it will easily hold a small box or a gallon of water sized something from getting under the net.
  13. Mar 19, 2018 at 3:13 PM
    mlucas555
    mlucas555 New Member
    Mark
    San Antonio, Tx
    2016 MGM Double Cab
    Still rocking the stock height.
    I like this idea! I may have to steal it.
  14. Mar 19, 2018 at 4:22 PM
    Njmike13
    Njmike13 New Member
    2021 PRO Lunar Rock
    There's no such thing as stealing here. I have yet to find someone here who wouldn't share ideas or tell you exactly how something was done. That's why this is the best forum.
    Take it come up with a better design than me and let me know how you did it.
    mlucas555[QUOTED] likes this.
