Bed holds water
Discussion in '2.5 Gen Tundras (2014-2021)' started by MNdiver, Sep 16, 2022.
  1. Sep 16, 2022 at 7:30 PM
    MNdiver
    MNdiver [OP] New Member
    steve
    Up north Minnesota
    2020 tundra sr5 crewmax Black
    hope this isnt a silly question. but I have always had old Chevys as work trucks. My tundra is the first truck ive had that holds water in the box. is there supposed to be drain holes or no if not has anyone drilled any?
  2. Sep 16, 2022 at 7:43 PM
    Winning8
    Winning8 New Member
    Da Bay Area
    2019 MGM DC 4x4 SR5
    I didn't even notice there are no drain holes...lol
    my first mod was a tonneau cover
  3. Sep 16, 2022 at 7:52 PM
    TILLY
    TILLY Gently Used Member
    Massachusetts
    2019 MGM TRD Sport D/C
    there's drain slots in the bed up front near the cab that can get clogged up with crap. I use an old credit card or something like that to clear them out from time to time.
  4. Sep 16, 2022 at 7:56 PM
    BravoDeltaRomeo
    Bruce
    MB Canada
    2019 Cavalry Blue Tundra CM
    My truck bed is open to the elements and snow, 24/7/65, since I got it.
    No water has ever pooled up. It drains somewhere. As @TILLY said, up front and likely at the hinge open/seam/hinge area of the tailgate.
    GODZILLA likes this.
  5. Sep 16, 2022 at 8:00 PM
    Winning8
    Winning8 New Member
    Da Bay Area
    2019 MGM DC 4x4 SR5
    Hold up, I think OP may have a spray on bed liner...
  6. Sep 16, 2022 at 8:06 PM
    MNdiver
    steve
    Up north Minnesota
    Thanks all, No bed liner will check for the slits mentioned.
  7. Sep 17, 2022 at 2:45 PM
    MNdiver
    steve
    Up north Minnesota
    Washed out the Bed today and found the drains, they work NOW after cleaning out the sand and pine needles, price you pay for living in Northern Minnesota. Going to do a roll on bed liner i will have to be careful not to plug the drains.
  8. Apr 4, 2023 at 7:47 PM
    ACDC2ZZTop
    ACDC2ZZTop Rock n Roll!
    Travis
    Oregon
    2012 MGM Tundra double cab 5.7L V8
    All cosmetic so far see my posts in 2nd gen Black out chrome in progress….
    Standing water in bed of my 2012
    Any suggestions on where I should place drain hole in the floor of the bed vs the wall ones shown?
  9. Apr 4, 2023 at 7:58 PM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    Drill a hole and paint it
    Rigger and FrenchToasty like this.
  10. Apr 4, 2023 at 8:01 PM
    TILLY
    Massachusetts
    Hard to tell from that pic, but don't you have the usual drains between the bed and front wall that was already mentioned here, or is it sealed?
  11. Apr 4, 2023 at 9:16 PM
    ACDC2ZZTop
    Travis
    Oregon
    Sealed with bed liner spray
  12. Apr 4, 2023 at 9:29 PM
    Joe333x
    Joe333x Member
    Boston
    2019 Tundra CrewMax Platinum
    Id definitely try to drill from underneath up into the bed if possible, maybe purposely fill the bed with water and see where it sits the most and drill there, using a self tapping screw to make the hole might make it easier too, or a step bit.
    ACDC2ZZTop[QUOTED] likes this.
  13. Apr 4, 2023 at 9:31 PM
    TILLY
    Massachusetts
    Can you clear away the liner where the stock drains are supposed to be?
  14. Apr 5, 2023 at 7:24 PM
    ACDC2ZZTop
    Travis
    Oregon
    After looking closer I see the slots and will clean them out to see if the liner isn’t the main clogging factor.
    Rdrcr and Joe333x like this.
  15. Apr 6, 2023 at 10:56 AM
    FO LO
    FO LO New Member
    17 CM w/ 5.7 and 4.30s
    Surely they would mask the drains before spraying it if they're that small
    BravoDeltaRomeo likes this.
  16. Apr 6, 2023 at 12:45 PM
    Wallygator
    With the spray in bed liner the slits get clogged pretty easily. Before I got the topper I would just take a screwdriver and clean them out.
    FrenchToasty and TILLY like this.
  17. Apr 6, 2023 at 9:30 PM
    ACDC2ZZTop
    Travis
    Oregon
    Up in nose of the bed and sure enough just clogged up. Guess I can blast off the green this weekend now.
    Demented Canine and TILLY like this.
  18. Apr 8, 2023 at 11:26 AM
    ACDC2ZZTop
    Travis
    Oregon
    Much better!
    Wallygator and TILLY like this.
  19. Apr 8, 2023 at 11:45 AM
    TheBrit
    TheBrit Wrinkly member
    Mark
    2013 Double Cab Tundra 2WD stuckinthemud
    Might sound obvious but how about making an effort to park so that any water drains out the tailgate end? Judging by the amount of green muck up front there (before you cleaned) it looks like you park on a slope steep enough to hold a fair bit of water, ergo by facing the other way...
  20. Apr 8, 2023 at 11:51 AM
    ACDC2ZZTop
    Travis
    Oregon
    I don’t like backing out of my driveway so that’s part of it, also truck stance front end is a little lower than the back.
    Shouldn’t be an issue now with those slots cleaned out.
    Green muck shouldn’t build up now
  21. Apr 8, 2023 at 11:53 AM
    ACDC2ZZTop
    Travis
    Oregon
    When it is dry enough I will recoat the rusty washers and bolts with liner spray.
  22. Apr 8, 2023 at 12:06 PM
    BravoDeltaRomeo
    Bruce
    MB Canada
    See if you can get them all out. I loosened all mine in the fall, sprayed with anti seize.
    There was one I couldn't get out with my tools. I will have the shop loosen it for me on next service. I don't want to strip it, buy my cordless impact wouldn't budge it.
  23. Apr 8, 2023 at 12:10 PM
    TheBrit
    Mark
    That's understandable, trouble is that all the crap that falls out of the air is going to keep blocking your vents unless you clean regularly. A reasonably simple solution might be to create a couple of ramps on the driveway at the position your front wheels sit when you park up - a little care doing it and it shouldn't look like the neighbors thinking they've got rednecks living next door.
