Bed liner from 3rd gen to 2nd gen?
Discussion in '2nd Gen Tundras (2007-2013)' started by Gto7419, Jul 29, 2020.
  1. Jul 29, 2020 at 8:08 PM
    Gto7419
    Gto7419 [OP] New Member
    2010 Tundra
    Found a cheap bedliner from a 2018 for my longbed 2010. Will it fit?
  2. Jul 30, 2020 at 6:21 AM
    bleach
    bleach MEME Fiend
    DJ
    Battle Ground, WA
    1991 White Xtra-cab SR5 4X4 V6 5 speed 148K
    Depending on where you live any kind of bed liner is a bad idea. You're better off spraying the bed.
  3. Jul 30, 2020 at 7:45 AM
    Gto7419
    2010 Tundra
    Thanks for the advice. The previous owner used the bed without any sort of liner. I'm going to roll paint it and put in a liner. Lots of people complain about stuff sliding around. Not an issue with tie downs. I like to slide heavier stuff in and out.
    Anyway, a good drive away is a $20 liner from a 2018. I really need to know if it will fit. Local dealer wants over $400
  4. Jul 30, 2020 at 8:20 AM
    bleach
    bleach MEME Fiend
    DJ
    Battle Ground, WA
    I have a liner in my '07 and it helped rust the bed. I'm only using to hide the unsightly rust until I get around to fixing it.
  5. Jul 30, 2020 at 8:36 AM
    Gto7419
    2010 Tundra
    Yup. I know it can cause moisture to sit in there. Still need to know if it will fit!
  6. Jul 30, 2020 at 8:45 AM
    Midmo_tundra
    Midmo_tundra New Member
    Missouri
    The interior of the bed, to my knowledge, is the same 07-20. I know the Truxedo LoPRO tonneau cover I have is listed for 07-current. The only thing that changed is the outside of the bed (tailgate and bedsides)
  7. Jul 30, 2020 at 8:55 AM
    bleach
    bleach MEME Fiend
    DJ
    Battle Ground, WA
    Best thing to do is to see if the part numbers are the same for all the interior sheet metal.
  8. Jul 30, 2020 at 11:45 AM
    Gto7419
    2010 Tundra
    I called a dealership and confirmed the part numbers are the same. Thanks guys!
  9. Jul 30, 2020 at 12:15 PM
    bleach
    bleach MEME Fiend
    DJ
    Battle Ground, WA
    Hope it works out for you. You may need to remove something from your rails to install it. I don't know what they were since mine came with the liner.
  10. Jul 30, 2020 at 5:14 PM
    Gto7419
    2010 Tundra
    Lol. Turns out he had the sliding track system on the bed rails. I do not and the liners are different. On the hunt again.
  11. Jul 30, 2020 at 6:19 PM
    biebs96
    PA
    just grab this one for cheap and add a set of bed rails.
    even if you bought the rails new it would still be the price of just an oem bedliner.
