Bed Liner----Gen 1 consensus opinion: remove bed liner or leave it in?
Discussion in '1st Gen Tundras (2000-2006)' started by SmokinJoe, May 30, 2021.
  1. May 30, 2021 at 7:08 PM
    SmokinJoe
    SmokinJoe [OP] New Member
    Jordan
    2005 Toyota Tundra, Access Cab, 4WD, Stepside
    I have a new (to me) 2005 Tundra step side. Are most of you guys leaving in the bed liner or removing it and applying some sort of coating in its place?
  2. May 30, 2021 at 7:12 PM
    Bubbadog
    Bubbadog New Member
    What does the bed without the liner look like? Is it in good shape?
  3. May 30, 2021 at 7:21 PM
    SmokinJoe
    Jordan
    Yes, it is in good shape. The truck has had a tonneau cover on it for a long time it appears.
  4. May 30, 2021 at 7:24 PM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    I took mine out after a year. It didn't do much damage but it scuffed the paint up a bit. Had lots of mulch under it too.
  5. May 30, 2021 at 7:32 PM
    SmokinJoe
    Jordan
    Did you leave the plastic rail caps on?
  6. May 30, 2021 at 8:05 PM
    Nueces
    Nueces New Member
    Texas Hill Country
    2002 Tundra SR5 AC
    I bought my 2002 AC in December and embarked on setting it up as a clean, reliable truck. Kudos to this board for many good ideas. It came with a fitted rubber bed liner that I initially liked, though it did reduce bed depth a bit. There was no cover, though, so I suspected rust under the liner. I intended to install a Diamondback SE cover and decided to remove the liner in favor of a spray coating after any necessary surface rust treatment. My shop took care of all bed rust before applying the liner. The rail caps were left in place, as recommended by Diamondback. I much prefer the painted liner under the cover now.
  7. May 30, 2021 at 8:06 PM
    Sunnier
    Sunny
    San Diego, CA
    Remove it. Probably you can keep it if you live in SoCal or Arizona but anywhere not really dry, remove it.
    mountainpete, Darkness and potoghi like this.
  8. May 30, 2021 at 9:03 PM
    tdrich7
    tdrich7 New Member
    2006 Tundra DC 4wd SR5
    I bought mine bare with just the metal bed and I've been wondering what to do myself. I've already hauled a load of dirt and taken two trips to the dump and feel like I'm scratching it up a good bit but not going to matter much if I go with some line-x in the end.
  9. May 30, 2021 at 11:49 PM
    SmokinJoe
    Jordan
    Whatever gives better gas mileage, I'm all-in!;)
  10. May 31, 2021 at 4:21 AM
    Professional Hand Model
    Hand Protectors
    2002 Tundra owner since new. Removed my Original Bed Liner (Plastic) about two years ago for the first time. Inspected things with only a couple little spots of surface rust (no bubbles) and mostly paint scuff from liner rub on paint. Lots of mulch was trapped, as well. My truck is 1D6 in color with solid paint. My area receives lots of rain and is subject to coastal storms.
    As I always liked the Plastic Liner due to its ruggedness, I cleaned things up and Sprayed Rustoleum Bedliner on the Bed as well as both sides of the Plastic Liner and then reinstalled it. Holding nicely and total cost of 5 cans at $7 each.
    Most bed rust is unfairly attributed to the Plastic Bedliner when in all actuality the rust usually bubbles up from under the bed at the cross bars supports. You can crawl under and look for that.
  11. May 31, 2021 at 4:11 PM
    SharkDog
    SharkDog New Member
    Denver
    2006 Gray DC Tundra SR5
    Dobinson Twin Tubes. Stock.
    Take it out. It’s loud when the rear window is down/open.
  12. May 31, 2021 at 4:14 PM
    Outbound
    Aaron
    Northern Alberta
    Remove it. Personally, I've always hated the plastic lines. Spray-on is where it's at, preferably Line-X. My truck came with Armorthane and while it's better than a plastic liner it's nowhere near the quality of Line-X.
  13. May 31, 2021 at 4:25 PM
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    Yup, and the part for the tailgate
  14. Jun 1, 2021 at 8:49 AM
    Rocko9999
    Rocko9999 New Member
  15. Jun 1, 2021 at 9:48 AM
    Durbin7
    Durbin7 New Member
    Ohio
    Pull the plastic. I had line x for 16 years in my previous truck. Last summer I went with Bullet liner, made by the man who came up with Line x. Just as happy and it was cheaper. I recommend it.
  16. Jun 1, 2021 at 10:39 AM
    Rocko9999
    Just got a Line-X quote-ouch. $645 for standard, $795 for premium. That is for new condition beds...
  17. Jun 1, 2021 at 11:04 AM
    Durbin7
    Durbin7 New Member
    Ohio
    I think I did $525 for my bullet liner last year
    Rocko9999 likes this.
  18. Jun 1, 2021 at 11:04 AM
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    This thread should've had a poll.....
  19. Jun 1, 2021 at 11:09 AM
    10TundraSR5
    10TundraSR5 Happy Tundra owner
    Tennessee
    2010 Black Tundra SR5
    Curse you Perry the Platypus!
    Perhaps THAT can be the poll!
  20. Jun 1, 2021 at 1:39 PM
    Hand Protectors
    For a second there, I thought you posted a picture of a Turd.
  21. Jun 1, 2021 at 1:49 PM
    mountainpete
    mountainpete Explore more
    2018 Cement Crewmax TRD
    Function before sparkle.
