Bed liner on your roof
Discussion in '2nd Gen Tundras (2007-2013)' started by tjinaz, Feb 16, 2021.
  1. Feb 16, 2021 at 12:19 PM
    tjinaz
    tjinaz [OP] New Member
    2011 RW
    In AZ our paint gets beat up. Mine is nearly 10yrs old and burning through clear coat (bought used) and am considering doing bed liner on the roof instead of repainting. Anyone else see this or think about the same thing? I didn't even notice the oxidization until i looked down on my truck in a parking lot.
    lctrk118 likes this.
  2. Feb 16, 2021 at 12:28 PM
    frichco228
    frichco228 Valued Member
    2016 Crewmax 4WD, TRD Offroad
    I have seen folks bed liner an entire truck or Jeep.
    One thing to know, bed liner is pretty heavy, heavier than you would expect. Not an issue for just a roof, but I bet it would add several hundred pounds spraying on the entire truck. There was someone here that I remember did their hood and it added considerable weight, making opening the hood a bit of a chore.
  3. Feb 16, 2021 at 12:45 PM
    Rex Kramer
    Rex Kramer Vinyl Spinner
    Georgia
    I had the hood & roof on my 2002 sprayed with Line-X last fall.
    It did add noticeable weight to the hood, but it's not a problem and I am happy with the results.
    My Super White 2007 doesn't have clear coat, so all I have to worry about is oxidation.
    The bed on the '07 was sprayed about 3 years ago, and it extends several inches over the rail & tail gate. I have decided to have the rest of the bed & tailgate sprayed because Line-X captures dirt & dust, any moisture will cause streaking on the exposed paint. The sides of the bed and tailgate start to look like a faded Zebra if I don't clean it regularly.
    I will not spray any part of the cab on my 2007, so I will end up with a Super white cab and a Line-X black bed.
    OlRazzl, JMB and Darkness like this.
  4. Feb 16, 2021 at 12:51 PM
    TheBeast The Beach
    wrap it. You can probably DIY
    BTBAKER and TheBlackPearl like this.
  5. Feb 16, 2021 at 1:07 PM
    tjinaz
    2011 RW
    Bedliner guy showed this.
  6. Feb 16, 2021 at 1:22 PM
    LarryDangerfield
    Tyler
    Northern Wisconsin
    You just wait
    Sincere question, not trying to be rude, how could bedliner add lots of weight? Wouldn't it just weigh as much as however much the container weighs when you buy it?
    Eric6621, chugs, Hbjeff and 1 other person like this.
  7. Feb 16, 2021 at 1:33 PM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    Thats what I was thinking as well. I can't imagine it is more than 10lbs per gallon, and maybe takes 4 gallons to cover a truck. I will be doing my roof this year, it takes less than half a gallon considering a gallon can do the whole bed.
  8. Feb 16, 2021 at 1:36 PM
    frichco228
    LarryDangerfield and Darkness like this.
  9. Feb 16, 2021 at 1:58 PM
    TheBeast The Beach
    line x is very durable. I have it on my bumpers and looks the same as it was put on (3+ years ago)
    Rex Kramer likes this.
  10. Feb 16, 2021 at 2:23 PM
    Rex Kramer
    Georgia
    Agreed... I had the bed of my 2002 work truck sprayed in '03 and it still looks great 18 years later.
    Picture taken of the bed last year before I installed the commercial ARE cap. The thick rubber bed mat is really nice.
    This picture was taken after the cap was installed, and after the cap, hood and roof were sprayed.
  11. Feb 16, 2021 at 2:28 PM
    Check out Durabak.com
  12. Feb 16, 2021 at 2:30 PM
    vl184009
    vl184009 Cheers Boys!
    Vicky
    Southern, Ca.
    2016 MGM CM SR5 4x4 w/Tow Pkg
    That is freakin cool!
  13. Feb 16, 2021 at 2:51 PM
    BigAl
    BigAl New Member
    2014 SR5 Magnuson SC
    Great idea! Now you've got me thinking I need to do this for my roof.
  14. Feb 16, 2021 at 2:55 PM
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
  15. Feb 16, 2021 at 7:00 PM
    Cruiserpilot
    Cruiserpilot New Member
    Jon
    Ladysmith
    2010 5.7 RCSB 4WD
    What model of ARE cap is that? It looks somewhat taller than the offerings I see online?
    Also, is it aluminum and how much does it weigh?
  16. Feb 16, 2021 at 7:07 PM
    BTBAKER
    BTBAKER .
    Brad
    Castle Rock
    2022 Ram TRX Level 2
    I think that looks damn good!
  17. Feb 16, 2021 at 7:37 PM
    Rex Kramer
    Georgia
    ARE DCU High Wedge... it is lighter than either of the fiberglass LEER caps that once were on this truck, I'll have to dig around for the exact weight.
    Cruiserpilot[QUOTED] and JMB like this.
  18. Feb 16, 2021 at 7:41 PM
    bleach
    bleach MEME Fiend
    DJ
    Battle Ground, WA
    1991 White Xtra-cab SR5 4X4 V6 5 speed 148K
    I have a feeling it would really absorb heat, especially from the dark color. That's not something you want in AZ, especially in summer.
    Failure2comply likes this.
  19. Feb 16, 2021 at 8:36 PM
    Cruiserpilot
    Jon
    Ladysmith
    2010 5.7 RCSB 4WD
    Thx, I like that. Would work well for my needs.
  20. Mar 2, 2021 at 6:29 AM
    Forcefed
    Forcefed New Member
    2007 Tundra Limited
    6 inch lift, ADS suspension, Alcan custom rear springs, 46 gallon metal gas tank, Full Line-x body, Wheels with 35's, Smittybilt bumpers front and rear, 10k warn winch, custom rack.
    I have my whole truck coated in LINE-X and it's black. Yes it does add weight, but it does not get very hot. In comparison, I also have a black Volkswagen for my daily. I live in New Mexico and I can't even touch my black VW during summer. But the Truck with black line-x stays cooler. The part that is the hottest on the truck is the trim for the window. That little black trim will be ten times hotter than the line-x on the door. I even noticed that my cab doesn't seem to get as hot. The line-x does get hot, but not so hot you can't touch it. Honestly I can still climb all over my truck during summer without having to put gloves on. Now I did not get the clear coat finish they can do so that might be why my truck doesn't get hot. It's just the regular coating and after time the gloss goes away and it's turns a matte black color. My newer parts that I have had coated still have the shine to them and they are a bit hotter to the touch. This stuff was put on in 2010 and it's still good. I don't have any problems with it. If you want it to last like mine have a shop do it. The prep work is the most important, and if you don't set it up right, it's not going to last.
  21. Mar 3, 2021 at 5:39 PM
    Eric6621
    Eric6621 New Member
    2007 Tundra Extra Cab TRD
    Where does a DIY'er get his hands on Line-X? Looked it up on Amazon and ebay without success?
  22. Mar 5, 2021 at 6:41 AM
    Forcefed
    Forcefed New Member
    2007 Tundra Limited
    I think you have to order it from the company, or dealers. I don't think you can just get it on Amazon.
  23. Mar 5, 2021 at 8:49 AM
    Cruiserpilot
    Jon
    Ladysmith
    2010 5.7 RCSB 4WD
    Line-X is dealer installed as it requires preheating to product upon application. In a similar way
    to RhinoLiner.
