Bed Rack with BAKFlip?
Discussion in 'Tonneau Covers, Caps and Shells' started by Ericakrum, Jan 19, 2023.
  1. Jan 19, 2023 at 9:47 AM
    Ericakrum
    Ericakrum [OP] New Member
    Mount Vernon Wa
    2016 LTD White Tundra
    Does anyone know if there is a bed rack that is compatible with BAKFlip? I just bought a 2016 LTD that already had it and I like that no water gets into the bed but I want to be able to put a rooftop tent in the back as well. I have attached what I am looking for. I saw that there was cross bars that were compatible but you wouldn't be able to open up the cover with them. Thanks for your help!
  2. Jan 19, 2023 at 10:28 AM
    ARMYGREEN
    ARMYGREEN New Member
    2014 CrewMax MGM
    I had the same issue.
    I went with Retrax sliding tonneau and Up Top Overland rack that slides into the rails.
    Not a cheap date but it is awesome.
    Like the Retrax way more than the Backflip
  3. Jan 19, 2023 at 3:39 PM
    Ericakrum
    Mount Vernon Wa
    Awesome thank you I will look into that!!
  4. Jan 19, 2023 at 3:41 PM
    RobertD
    Robert
    DFW, Texas
    You can make a rack fit with a Bakflip but you have to cut the edge seals that sit on the bed cap. Not the cleanest look and you have to get it right the first time. Hit up @memario1214 about a Retrax and if you tell him the brand of your rack I'm sure he can suggest the correct feet to make it work with the cover.
    memario1214 and Ericakrum[OP] like this.
  5. Jan 19, 2023 at 3:42 PM
    RickyBobbysTundra
    RickyBobbysTundra New Member
    Phoenix
    2023 Solar Octane TRD Pro
    I actually went to a shop today that had a bunch of tonneau covers on display. For the roll-up series I believe they'll work they just need to install special rails to allow the rack system. If you want to trifold they now make rack systems that are taller and at 90° to allow the tri-fold to function.
    The guy that own the shop had the retrax installed on his personal truck.
    Ericakrum[OP] likes this.
  6. Jan 21, 2023 at 12:29 PM
    KB Voodoo
    KB Voodoo New Member
    Chad
    2017 Tundra Pro Crewmax, Cement
    Many KB Voodoo Fabrications accessories!!
    This is the only rack that will allow you to open the BakFlip: https://www.max-modular.com/toyota-...sent-11/utility-rack-for-tonneau-covers-arlwc
    If you were inclined to go with a retractable cover, all of our racks work with those.
