Bed Rack WITH tonneau cover?
Discussion in 'Tonneau Covers, Caps and Shells' started by Tattundra, Jul 16, 2023.
  1. Jul 16, 2023 at 12:18 PM
    Tattundra
    Tattundra [OP] New Member
    2020 TRD Pro Tundra
    Tires, tint, tonneau cover, raptor lights
    I have an existing hard top, tri-fold tonneau cover that I love and really don’t want to have to get rid of/replace. Are there bed rack/bed rack mounting systems that will still mount with my existing cover?
  2. Jul 16, 2023 at 12:20 PM
    You're going to have to give more info. Some racks work with some covers, but not with others. Pics of your cover and the brand and model will go a long way toward getting you proper answers.
  3. Jul 16, 2023 at 12:52 PM
    SD Surfer
    Bruce
    So Cal
    I was surprised how few options there are to run racks and tonneau together... fewer still if you want a tri-fold rather than roll-up or retract.
    I went with Elevate racks and T-Slot rails, and a BakFlip.
    Had some Yakimas off my old Tundra so I MacGyvered the landing pads to the the cleats that came with the Elevate system, so I have the option to run the Yakima bars down low if I want. May mount bike fork mounts to that.
    I bought the Elevate rails ($200) so they could get installed at the same time as the tonneau cover, then I added the racks later.
    The racks come with a high and low setting, but the low was an inch or two too short to let my tri-fold fold, and the high was way too high and kinda' goofy looking, so I drilled a new set of holes for the med height you see pictured.
    I wanted them just high enough that my cover would open and my SUP's and surfboards would clear the cab.
    I'm real happy with the set-up so far.
    High position... Ummmm, No.
    Florida AF and Tattundra[OP] like this.
  4. Jul 16, 2023 at 1:08 PM
    Tattundra
    2020 TRD Pro Tundra
    It is a Truck Hero Armor Flex by Under Cover
  5. Jul 16, 2023 at 1:11 PM
    Full disclosure, I don't run and never have run a tonneau cover, but that doesn't like like it leaves any way for a bed rack to be installed. I can't see any way to mount a rack and keep that cover in place. I'm guessing you'll have to get a different cover that has some kind of rails/tracks like what @SD Surfer posted.
    Tattundra[QUOTED][OP] likes this.
  6. Jul 16, 2023 at 6:17 PM
    SD Surfer
    Bruce
    So Cal
    https://truck-hero.com/truck-hero-rack-system
    Truck Hero makes the Elevate Rack System I'm running so it might work. (Hard to tell from those pics)
    You'd have to uninstall your tonneau and reinstall it using the thinner weatherstripping they provide with the Elevate T-slot rails.
    GODZILLA likes this.
  7. Jul 16, 2023 at 6:25 PM
    Tattundra
    2020 TRD Pro Tundra
    Good tip! Thank you, I’ll look into it.
  8. Jan 21, 2025 at 4:15 PM
    TunLTRD4Me
    TunLTRD4Me New Member
    OEM is made by BAK and is compatible the Elevate Rack System and T Rails.
  9. Feb 25, 2025 at 7:38 AM
    Tundraman479
    Tundraman479 New Member
    2024 Tundra Crewmax TRD Sport Lunar Rock
    TRD Pro Suspension 275/60r20 Wildpeaks
    KBVoodoo bed bars. I ran them with a tent and bike and bed cover. They work great!
